    [Plugin][$] FredoScale - v3.7c - 19 Aug 26
    1.2k Posts 347 Posters 3.5m Views 345 Watching
    • romboutR
      rombout
      well ad first i had this error on the mac that i had to upgrade from 30 > 31. Did that and it worked... aslo upgraded on the pc but it doesnt work now!!! ad first it worked with the libfredo 30e but now it doesnt! so any suggestions any one ๐Ÿ‘ฟ
      i dont see any menu's both of them no freescale and no libfredo settings
      • fredo6F
        Maybe you should refer to the following post, which indicates the exact footprint of the plugin in the Sketchup directory.
        http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=17947&p=158341#p158225
          steelers05
          I am running the most recent version on a pc and all of the tools work except the bend tool....half the time it wont even activate when I click the icon and when it does work, it only rotates the object and doesnt bend it. Any ideas what I could be doing wrong?
          • CadFatherC
            CadFather
            Hi Fredo - just to let you know, after replacing the file 'FreeScale_Common.rb' the tool stops working
            it's not a big deal though - whenever you stumble upon it..
            • fredo6F
              Two remarks
              • For the rotation (instead of bend), you need to activate the slicer (toggle F4). This creates intermediate points and make the bending smoother.
              • Before you do any transformation, make sure that your current selection is correct. If you move directly from one tool to another one like Bend, then all geometry at model level may not be selected. This is why it's always better to encapsulate the geometry within groups.
              • CadFatherC
                CadFather
                Thanks Fredo.. strange, it doesn't work - tried changing the toolbar name..
                it doesn't matter - shall i try to find the separators in the files themselves or would i just waste time?
                • fredo6F
                  Strange. It works for me. Do you at least see the option in the Default Parameters dialog box?
                  Please do not change the code. You won't find where the separators are (I am even lost myself).
                  • CadFatherC
                    CadFather
                    sorry Fredo, should have been clearer - the update does remove the separators.. so the toolbar looks great - it just doesn't work! : )
                    ..don't worry about it Fredo, i'll leave it as it is.. i will try and find out if there's some clashing etc.. (Thanks)
                    • fredo6F
                      Is it the whole set of tools not working?
                      Did you try with the version attached in my previous post, just in case?
                      I'd better know, because I checked that 44 people have downloaded the file.
                      • fredo6F
                        @cadfather said:
                        yes, the whole toolset stops - with both versions,
                        i also tried with an empty plugins folder as below, same result..
                        I suggest you then reinstall the standard version 2.0f (and 3.1f for LibFredo6, we never know). I need to investigate.
                        By the way, when you say 'Stops' what does that mean. For instance, if you open the Ruby console, do you see any message when launching the tools?
                        PS: Nice icon for the folders!
                        • CadFatherC
                          CadFather
                          forgot to mention:
                          xp pro sp3
                          sketchup 7 pro
                          • CadFatherC
                            CadFather
                            with the clean latest install (i had it but retried it again now) the toolset works - if i change the 'common' file, it stops..
                            here's the folder icons - i do need some visual clues as to what swims in this folder!
                            Folders.rar
                            • fredo6F
                              I think I found the issue. I have inadvertedly included a statement that only works with another version of LibFredo6.
                              Here is a version that should work hopefully
                              to drop into FREESCALE_Dir_20 folder
                              • fredo6F
                                @cadfather said:
                                Hi Fredo
                                what are the chances i can remove the separators from the icons toolbar?
                                Drop the attached file into the FREESCALE_Dir_20 folder.
                                Then restart Sketchup, set the option in the Default Parameters dialog box, and then restart sketchup again.
                                to drop into FREESCALE_Dir_20 subfolder
                                • fredo6F
                                  It works for me. Could you redownload it and try again.
                                  Just in case, here is the version I use:
                                  By the way, does it do what it is suppose to do, that is remove the separators in the toolbar?
                                  [Edit] See this post http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=17948&p=158953#p158953
                                  • CadFatherC
                                    CadFather
                                    fantastico Fredo - it works! โ˜€
                                    • H
                                      hansschatz
                                      Thank you! It's very useful!
                                      • fredo6F
                                        NEW VERSION 2.0g NOW RELEASED
                                        IMPORTANT: I decided to change the name of this plugin, as the previous name could create confusion with an existing company and infringe their trademark. Please use now the new name FredoScale when referring to this plugin.
                                        This version is identical to the previous one 2.0f, except the possibility to configure the toolbar without separators (a request from CadFather). The option can be selected in the Default Parameter dialog box.
                                        See main post at http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=17948&st=0&sk=t&sd=a#p144180
                                        It works with the current LibFredo6 3.1f
                                        • COSEDIMARCOC
                                          COSEDIMARCO
                                          Updated the Italian Translation File
                                          Italian Translation of FredoScale 2.0g
                                          [floatl:2wjeiugn]COSEDIMARCO - The Website[/floatl:2wjeiugn]
                                            Can the old Freescale folders be deleted?
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 58
                                            • 59
                                            • 15 / 59
