    [Plugin][$] FredoScale - v3.6a - 01 Apr 24
    1.1k Posts 345 Posters 2.4m Views 342 Watching
    • fredo6F Offline
      @cadfather said:
      Thanks Fredo.. strange, it doesn't work - tried changing the toolbar name..
      it doesn't matter - shall i try to find the separators in the files themselves or would i just waste time?
      Strange. It works for me. Do you at least see the option in the Default Parameters dialog box?
      Please do not change the code. You won't find where the separators are (I am even lost myself).
      • CadFatherC Offline
        CadFather
        sorry Fredo, should have been clearer - the update does remove the separators.. so the toolbar looks great - it just doesn't work! : )
        ..don't worry about it Fredo, i'll leave it as it is.. i will try and find out if there's some clashing etc.. (Thanks)
        • fredo6F Offline
          Is it the whole set of tools not working?
          Did you try with the version attached in my previous post, just in case?
          I'd better know, because I checked that 44 people have downloaded the file.
          • fredo6F Offline
            @cadfather said:
            yes, the whole toolset stops - with both versions,
            i also tried with an empty plugins folder as below, same result..
            I suggest you then reinstall the standard version 2.0f (and 3.1f for LibFredo6, we never know). I need to investigate.
            By the way, when you say 'Stops' what does that mean. For instance, if you open the Ruby console, do you see any message when launching the tools?
            PS: Nice icon for the folders!
              CadFather
              forgot to mention:
              xp pro sp3
              sketchup 7 pro
                CadFather
                with the clean latest install (i had it but retried it again now) the toolset works - if i change the 'common' file, it stops..
                here's the folder icons - i do need some visual clues as to what swims in this folder!
                Folders.rar
                • fredo6F Offline
                  I think I found the issue. I have inadvertedly included a statement that only works with another version of LibFredo6.
                  Here is a version that should work hopefully
                  to drop into FREESCALE_Dir_20 folder
                  • fredo6F Offline
                    @cadfather said:
                    Hi Fredo
                    what are the chances i can remove the separators from the icons toolbar?
                    Drop the attached file into the FREESCALE_Dir_20 folder.
                    Then restart Sketchup, set the option in the Default Parameters dialog box, and then restart sketchup again.
                    to drop into FREESCALE_Dir_20 subfolder
                    • fredo6F Offline
                      @cadfather said:
                      Hi Fredo - just to let you know, after replacing the file 'FreeScale_Common.rb' the tool stops working
                      it's not a big deal though - whenever you stumble upon it..
                      It works for me. Could you redownload it and try again.
                      Just in case, here is the version I use:
                      By the way, does it do what it is suppose to do, that is remove the separators in the toolbar?
                      [Edit] See this post http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=17948&p=158953#p158953
                        CadFather
                        fantastico Fredo - it works! β˜€
                        • H Offline
                          hansschatz
                          Thank you! It's very useful!
                          • fredo6F Offline
                            NEW VERSION 2.0g NOW RELEASED
                            IMPORTANT: I decided to change the name of this plugin, as the previous name could create confusion with an existing company and infringe their trademark. Please use now the new name FredoScale when referring to this plugin.
                            This version is identical to the previous one 2.0f, except the possibility to configure the toolbar without separators (a request from CadFather). The option can be selected in the Default Parameter dialog box.
                            See main post at http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=17948&st=0&sk=t&sd=a#p144180
                            It works with the current LibFredo6 3.1f
                            • COSEDIMARCOC Offline
                              COSEDIMARCO
                              Updated the Italian Translation File
                              Italian Translation of FredoScale 2.0g
                              [floatl:2wjeiugn]COSEDIMARCO - The Website[/floatl:2wjeiugn]
                                Can the old Freescale folders be deleted?
                                • Jean-FrancoJ Offline
                                  Jean-Franco
                                  Yes, I did it and it works, no problem.
                                  Jean-Franco
                                  • utilerU Offline
                                    utiler
                                    The reason for my latest posts, Thom.
                                    301 Moved Permanently
                                    (www.sketchucation.com)
                                    Just Curious...
                                    • fredo6F Offline
                                      Yes, in general you can safely erase the subfolder (here FREESCALE_Dir_20) once you have installed a more recent version.
                                      • david_hD Offline
                                        david_h
                                        Anybody else having a problem getting the install to work? Mine deosn't show up. The old one worked fine. .. but the new one. . .nuthin'.
                                        EDITGot it figgered out. Crisis averted. πŸ˜„
                                        • marleusM Offline
                                          marleus
                                          THANK YOU Fredo!!!!!!
                                          You're brilliant.
                                          Finally I get my chair seats right πŸ‘
                                          Markus Sillander
                                          Vantaa, Finland
                                          I'm on FormFonts now
                                          http://www.formfonts.com
                                            Marinho
                                            Hi Fredo, morning, meu name is Marinho, and I live in Luciara, Mato Grosso state, Brasil (nearly 11Β°30'00"S - 50Β°30'00"W at side of Araguaia River). I want you if you can send me please the your famous plugin, now with changed name, FREDOSCALE 2.0f. I use the Sketchup 6.0 and lake very match can use this plugin.I dont find it to download in anyplace in internet.
                                            Tanks a lot,
                                            Best regards
                                            Marinho.
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 56
                                            • 57
                                            • 15 / 57
