    • Anmelden
    [Plugin] Simple Loft alpha 0.1b -- UPDATED May-15-09
    Geplant Angeheftet Gesperrt Verschoben Plugins
    251 Beiträge 88 Kommentatoren 154.8k Aufrufe 88 Watching
    Lade mehr Beiträge
    • Älteste zuerst
    • Neuste zuerst
    • Meiste Stimmen
    Antworten
    • In einem neuen Thema antworten
    Anmelden zum Antworten
    Dieses Thema wurde gelöscht. Nur Nutzer mit entsprechenden Rechten können es sehen.
      abspandey
      zuletzt editiert von
      works perfectly now. Thanks a ton....!
      1 Antwort Letzte Antwort Antworten Zitieren 0
        abspandey
        another query...uve already mentioned that the number of nodes in the different curves needs to be the same... is there a way to change the number of nodes in a curve to match the other ?
        A
        • F Offline
          fakircho
          Thanks man, have only been waiting for this for like 5 years 😄
          It is a very good start and i am looking forward to this becoming a real loft tool.
          Thanks again!
          • Chris FullmerC Offline
            @abspandey - glad its working now. Check back regularly or in a few days or something. I'm working on making it work with splines of different segment lengths, but currently its still a little buggy. It works about 90% of the time, but that 10% has been difficult to pin down. So once I get it debugged, I'll post the working version. And that will hopefully be in a few days.
            @fakircho - Glad you like it. and yes, its just a simple loft tool for now. I have some VERY big plans for it, assuming a find some VERY big chunks of time in my life to devote to it. So hopefully over the next year or so I'll get a full version released. But I make no promises.
              AcesHigh
              you mean... by 2010???? 😢 😢
              and I was thinking it would be like... next month...
                remus
                Theyre very time consuming things, these ruby scripts.
                  If I had your math brain Remus, it might be easier. And in fact, what I have in mind to implement should simplify some of the script, while exponenetially increasing the "awesomeness" of it. But seriously, I have to learn some math first.
                  And I'm sorry I haven't released the version that accepts splines of any amount of segments. Its still being worked on.....grrrr
                    pr0
                    Guys, don't know what to tell you, the combination of working plugins by the community especially this one!! and the free transform 2 tools make sketchup more powerful than 3ds max and hopefully soon even rhino. I can't believe it, thanks alot!
                      Theehee! I just had an image of me and Chris as zombies drooling over Remus' brain. Braaaaaaain! Maaaath-Braaaaaaain!
                        silver_shadow
                        Great stuff
                        What you should look at is this.
                        Can you try to let the plugin look for the highest amount of divisions in the selection, say you have 3 curves.
                        one has 25 divisions the next one has 10 and the third one has 6. Now instead of going manually of dividing those other curves to 25 divisions, it should re divide those other curves to match the 25 which is the most.
                        or
                        can someone make a plugin that recognizes a welded line and re divide it. on second thought..its kind of an impossible one request lol
                        Pretty cool plugin i must say.
                          pibuz
                          Thank you Chris.
                          This is simply amazing. You're really turning Sketchy into a professional tool.
                          The version Google releases should be called "Google almost-Pro"... 😒
                          GREAT WORK!
                          WEB (ita) - https://filipposcarso.wixsite.com/ordinentropico
                            Thanks everyone! Silver, that is what my first idea was, but when I got into programming it, but then I decided to make each spline transpose its endpoints onto each other line. Its has a few added benefits, but its essentially the same idea. And I've got it working.
                            Tig, I think what I've done is similar to what you're showing there - except I have not got it erasing coplanar faces yet. This new overkill method of adding segments is creating so much more geometry than before that it is becoming VERY slow. Checking for coplanar faces at this point might not be desirable.
                            So its working with varying segments counts. Just every once in a while, it will encounter something that will break it. And I haven't quite put my finger on what the problem is. Because I've done some very complex shapes that work, then I'll try something more simple and it won't work. And I play around with it and determine it to be one of the splines will crash it for no apparent reason. So once I figure that out, I'll release it. With a sweet new icon from Free Agent!
                              Deleting coplanar edges is relatively quick - it just sorts the edges that are dispensable...
                              ### assumes you have made the faces and now have an array of these new edges called 'edges' - that's all that needs checking.
                              edges.each{|e|
                                if e.faces.length == 0 ### for some reason it hasn't faced !!!
                                  e.erase! if e.valid?
                                elsif e.faces.length == 2
                                  if (e.faces[0].normal == e.faces[1].normal or e.faces[0].normal == Geom;;Vector3d.linear_combination(-1,e.faces[1].normal,1,[0,0,0])) and e.faces[0].material == e.faces[1].material
                                    ### you'll probably not need the material check, as it's all new stuff, but it's useful generally so that materials' dividing coplanar edges aren't removed...
                              Quickest way without 'a safety-net' is...
                              edges.each|e|e.erase! if e.valid? and e.faces.length==2 and (e.faces[0].normal==e.faces[1].normal or e.faces[0].normal==Geom;;Vector3d.linear_combination(-1,e.faces[1].normal,1,[0,0,0]))
                                AcesHigh
                                You ruby geniuses should work together in creating ruby awesomeness... speeding up plugin creation... you know... like a softhouse... haha, I have no idea on the workflow of writing rubies, I am just daydreaming 😄
                                  mike d
                                  created with simple loft
                                  The grass is always GREENER on the roof.
                                    driven
                                    Hi Chris,
                                    I've been having real problems trying to download this for hours, do I need special permissions for your stuff?
                                    I can download everything else I've tried today?
                                    cheers
                                      My thinking for joining curves with unequal numbers of edges is this:
                                      [list]Let's say curve1 has 3 edges and curve2 has 4 edges
                                      Split (divide) each of curve1's edges into 4 equal bits
                                      Split (divide) each of curve2's edges into 3 equal bits
                                      Taking the pairs of vertices for curve1 and curve2 starting at the same end (find curve1's ends and then pair curve2 start with the nearer of curve1's ends) make edges between the vertices pairs, make diagonals between pairs with one offset so face is triangulated...
                                      Use find_faces on the edges and you should now have a form
                                        Nope John, my stuff is just the same as everyone else'e. I don't know why it doesn't ever seem to work for you. If you don't get it downloaded, I can email you a copy later.
                                          driven
                                          Still no joy, tried all sort of things from this end, so if you can forward that's great,
                                          I took advantage of selectbylength with xformclone to make a quick, low poly candy-stripe pole and then animate it spinning..link over on that topic..
                                          cheers
                                          • I Offline
                                            ideas_arte
                                            incredible…. a million thanks..!
                                            • 12
                                            • 13
                                            • 7 / 13
                                            • Erster Beitrag
                                              Letzter Beitrag
