    [Obsolete] BZ__Arc for BezierSpline 1.2
    54 Posts 31 Posters 27.7k Views 31 Watching
    • fredo6F Offline
      @cadfather said:
      Hi Fredo, i could be wrong but it seems BZ 1.2 only works with the default su7 installation
      if i have SU installed in a different folder the tool will start but it will not draw a line upon clicking..
      (i have multiple copies of SU one for working, one for experimentation)
      You are right. BezierSpline asumes it is located in the default Sketchup Plugin folder.
      For FreeScale and LibFredo6 I have arranged to support alternate folders however, provided you configure Sketchup for an alternate folder (via script acting on $:).
      When I refresh Bezierspline, it should work.
      • N Offline
        numerobis
        @thomthom said:
        "Sketchup Fredo Edition" πŸ‘ πŸ˜„ πŸ‘
        +1 πŸ’š
        Thank You very much Master Fredo!
        Really Useful! 😎
          putnik
          Moderators, shouldn't Fredo's name be highlighted in a different colour on this forum, or something, like the names of other people who distinguished themselves in some way? He obviously is some kind of demigod at the very least but has an appearance of a mortal.
          http://keshas.info
          • X Offline
            xrok1
            maybe in neon 🀣
            • CadFatherC Offline
              CadFather
              Thanks Fredo, is there no way to make it folder independent? or perhaps specified in a txt file?
              • soloS Offline
                On my machine if one enables the sound every time you hover your mouse over his name you get a choir like "halelujia" sound clip. πŸ˜‰
                  CadFather
                  that's amazing - i've got aretha franklin's 'Fredoo'
                  • I Offline
                    ideas_arte
                    Thank you very much..! Fredo.. πŸ‘
                    • FrederikF Offline
                      Frederik
                      Off topic
                      I assume that it's only mods who can get direct access into a user profile, when clicking the username... πŸ˜•
                      Being a "regular mortal" nothing happens when pointing on a username... 😞
                      Cheers
                      Kim Frederik
                      • N Offline
                        notareal
                        Thank you!
                        Welcome to try [Thea Render](http://www.thearender.com/), Thea support | [kerkythea.net](http://www.kerkythea.net/) -team member
                          mpowell1234567890
                          Wow! Thia is amazing. Thanks for sharing this cool script. 😍
                            tonyL
                            thanks Fredo.
                            one question : how do u convert polyline to polyline arc corners?
                              @tony
                              just an idea πŸ’­
                              Group your existing curve
                              use polyline Arc corner and redraw points over the curve
                              kill the group et voilΓ  πŸ˜„
                              Not sure that is you want that πŸ˜’
                                Daniel S
                                Right click on the polyline and choose: convert to polyline arc corners.
                                Daniel S
                                  yes maybe more speedy πŸ˜†
                                    tonyL
                                    hey guys,
                                    thanks for the pointer. πŸ˜„
                                    • H Offline
                                      han_seller
                                      thank you for your info
                                      • Bob JamesB Offline
                                        Bob James
                                        Alas! I've loaded BZ_Arc.rb into the BZ_Dir_12 folder and the icon files into IMAGES_standard and IMAGES_CadFather but still get only the original icons and no context command.
                                        Moreover, it seems that BoolTools icons have become blanks!!
                                        • fredo6F Offline
                                          Bob,
                                          As you are on Mac, there maybe some specificities that have never been signaled by Mac users.
                                          Just to understand more:
                                          1. before you dowloaded and drop the BZ__Arc extensions, did you have a correct behavior of Bezierspline (i.e., icons, contextual menu, all extensions available), and possibly presence of the BoolTool icons?
                                          2. Can you also check you do have the version 1.21 installed.
                                            Bob James
                                            I'm on an iMac (Intel) here at home: I haven't had a chance to load it on my MacPro at work.
                                            Yes, Bezierspline, icons and contextual menu worked fine and BoolTools icons were okay (The "blank" icons still "work", they just don't have the graphic face).
                                            I downloaded and installed the latest 1.21 version pf BezierSpline and added the BZ_Arc and icons (I also re-installed BoolTools).
                                            • 2 / 3
