    [Obsolete] BZ__Arc for BezierSpline 1.2
    54 Posts 31 Posters 27.2k Views 31 Watching
    • david_hD Offline
      david_h
      Cool Plugin. thanks.
      D
      πŸ‘
      PS. I think we need a smilie emoticon of hands clapping in thunderous applause for just these types of occasions.
      πŸ˜„
      • fredo6F Offline
        @cadfather said:
        Hi Fredo, i could be wrong but it seems BZ 1.2 only works with the default su7 installation
        if i have SU installed in a different folder the tool will start but it will not draw a line upon clicking..
        (i have multiple copies of SU one for working, one for experimentation)
        You are right. BezierSpline asumes it is located in the default Sketchup Plugin folder.
        For FreeScale and LibFredo6 I have arranged to support alternate folders however, provided you configure Sketchup for an alternate folder (via script acting on $:).
        When I refresh Bezierspline, it should work.
        • N Offline
          numerobis
          @thomthom said:
          "Sketchup Fredo Edition" πŸ‘ πŸ˜„ πŸ‘
          +1 πŸ’š
          Thank You very much Master Fredo!
          Really Useful! 😎
            putnik
            Moderators, shouldn't Fredo's name be highlighted in a different colour on this forum, or something, like the names of other people who distinguished themselves in some way? He obviously is some kind of demigod at the very least but has an appearance of a mortal.
            http://keshas.info
            • X Offline
              xrok1
              maybe in neon 🀣
              • CadFatherC Offline
                CadFather
                Thanks Fredo, is there no way to make it folder independent? or perhaps specified in a txt file?
                • soloS Offline
                  On my machine if one enables the sound every time you hover your mouse over his name you get a choir like "halelujia" sound clip. πŸ˜‰
                    CadFather
                    that's amazing - i've got aretha franklin's 'Fredoo'
                    • I Offline
                      ideas_arte
                      Thank you very much..! Fredo.. πŸ‘
                      • FrederikF Offline
                        Frederik
                        Off topic
                        I assume that it's only mods who can get direct access into a user profile, when clicking the username... πŸ˜•
                        Being a "regular mortal" nothing happens when pointing on a username... 😞
                        Cheers
                        Kim Frederik
                        • N Offline
                          notareal
                          Thank you!
                            mpowell1234567890
                            Wow! Thia is amazing. Thanks for sharing this cool script. 😍
                              tonyL
                              thanks Fredo.
                              one question : how do u convert polyline to polyline arc corners?
                                @tony
                                just an idea πŸ’­
                                Group your existing curve
                                use polyline Arc corner and redraw points over the curve
                                kill the group et voilΓ  πŸ˜„
                                Not sure that is you want that πŸ˜’
                                  Daniel S
                                  Right click on the polyline and choose: convert to polyline arc corners.
                                  Daniel S
                                    yes maybe more speedy πŸ˜†
                                      tonyL
                                      hey guys,
                                      thanks for the pointer. πŸ˜„
                                      • H Offline
                                        han_seller
                                        thank you for your info
                                        • Bob JamesB Offline
                                          Bob James
                                          Alas! I've loaded BZ_Arc.rb into the BZ_Dir_12 folder and the icon files into IMAGES_standard and IMAGES_CadFather but still get only the original icons and no context command.
                                          Moreover, it seems that BoolTools icons have become blanks!!
                                          • fredo6F Offline
                                            Bob,
                                            As you are on Mac, there maybe some specificities that have never been signaled by Mac users.
                                            Just to understand more:
                                            1. before you dowloaded and drop the BZ__Arc extensions, did you have a correct behavior of Bezierspline (i.e., icons, contextual menu, all extensions available), and possibly presence of the BoolTool icons?
                                            2. Can you also check you do have the version 1.21 installed.
                                            • 2 / 3
