    [Plugin][$] FredoScale - v3.6a - 01 Apr 24
    1.1k Posts 345 Posters 2.4m Views 342 Watching
    • McGyverM Offline
      McGyver
      Brilliant,intuitive and simply fantastic... this should have come with SU to begin with.... heck google should beg you to make stuff for them! You are the Ruby-Master!! Thanks a million!!
      Visit My ShareCG Freebie Gallery
      • david_hD Offline
        david_h
        For some strange reason the Radial Bend feature just stopped working? everything else seems fine. Or maybe I am not using it right? Any ideas?
          remus
          Your not trying it on a highly grouped/compenented model by any chance? As far as i can tell things start to go funny when youve got more than 2 levels of groups.
          • fredo6F Offline
            David,
            What is the exact problem:
            • does it crash or bug splat?
            • Do you see the protractor and can you use it?
            • do you see the wireframe?
            • bagateloB Offline
              bagatelo
              I liked that plugin a lot, this is saving a lot of my time. But...
              I don't know if I will get to explain the problem of behavior of the plugin that doesn't please me, but I will try.
              My displeasure is regarding the Icon "Stretching with Box by matching an origin and the target." After it is chosen the plan where Stretch should happen, I cannot use a relationship of distance among distant objects as it could use the command MOVES common of Sketchup. I need to draw a line or object to the close origin point and the close target point to make Stretch. It would be interesting if it went as in the command it MOVES of the sketchup, where I can use points of it distances wanted distant of the object that desire to make Stretch.
              • fredo6F Offline
                NEW VERSION 2.0d
                It fixes a major bug introduced in 2.0c for the target mode of Scale, Stretch, Shear, and also for setting the dimensions via the dialog box. Sorry for inconvenience.
                So it is strongly advised to upgrade.
                As a bonus, you'll get the Korean translation by Couque D`asse.
                All details are in main post http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=17948&st=0&sk=t&sd=a#p144180
                Note: You will also need to download LibFredo6 3.1d
                • utilerU Offline
                  utiler
                  'Thanks Fredo' seems so insignificant!!!
                  Just Curious...
                  • david_hD Offline
                    david_h
                    Fredo. . .
                    Downloaded the latest version and the bending works now. But the Icons don't show up on the tool bar. I had them before just fine . . .now I don't.
                    I just didn't get a chance to mention it. I had this problem with 2.0c as well.
                    DO they icons png's belong in their own subfolder?
                    • jcharltoncarpJ Offline
                      jcharltoncarp
                      OK I've Dealt with it
                      I'm reposting this from the Newbie forum. I've been taking advantage of the current economic down turn, to, amongst other things learn Sketchup. The reason I joined the forum is my interest in Fredo's amazing freescale tool. I'm very new to SketchUcation. A few months into Shetchup, and less than six months back to Mac after an absence since OS 4. I'm using a Mac running Leopard and have been unable to install the downloads correctly in my plugins folder. I was wondering if someone could post a screen shot of the folder hierarchy properly installed? I have been following the posts on the Ruby forum and have tried several ways to do the installation, but no joy. All suggestions gratefully accepted.
                      John
                      • jeff hammondJ Offline
                        they should be in a folder called 'IMAGES_Standard' which is inside the 'FREESCALE_Dir_20' folder.
                        if you want daniel's icons, they will be in a folder called 'IMAGES_DanielS' which goes in the freescale folder and you activate them via the parameters dialog.
                        • david_hD Offline
                          david_h
                          Success!!! Thanks a lot.
                          D
                            Matt666
                            Hi Fredo!
                            I just tried your new version (v2.0d), but it seems to bug when I want to move some points...
                            • Procedure:
                            • Start scale tool
                            • Select a cube
                            • Try to move a corner (with one of your points). Impossible to move any point.* Error message in the ruby console:Sans titre 1.jpg 😉
                            Frenglish at its best !
                            My scripts
                            • fredo6F Offline
                              Matt,
                              I don't know what this is, as I cannot reproduce it on my machine.
                              Just in case, I slighlty modified the code around the "round" function.
                              Can you try it, and tell if you can reproduce the bug.
                              to drop in FREESCALE_Dir_20 folder
                              • fredo6F Offline
                                NEW VERSION 2.0e NOW RELEASED
                                It fixes a bug recently found for Stretch in Target mode.
                                See details in main post http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=17948&st=0&sk=t&sd=a#p144180
                                You also need to download LibFredo6 3.1e
                                  Click Draw
                                  Fredo6,
                                  Was twist just added?
                                  Thanks,
                                  Jeff
                                  Have I mentioned how much of a laugh I get out of some of the Signatures on here!
                                  • fredo6F Offline
                                    Jeff
                                    No, it was in the first release 2.0a.
                                    Do you have any issue with the tool?
                                    • massimoM Offline
                                      massimo Moderator
                                      Fredo, some problems with this new version. Draw a rectangle, pushpull it then stretch. Use the bend tool. It doesn't works properly anymore.
                                      • utilerU Offline
                                        utiler
                                        Incredible, Fredo!!!!!
                                        Just Curious...
                                        • COSEDIMARCOC Offline
                                          COSEDIMARCO
                                          @Fredo6
                                          New Italian translation is ready.
                                          You should add a string for "Donation...". The translation is "Donazioni...".
                                          Ps. My nickname is "COSEDIMARCO" and not "Marco Cosedi". 😄 it means " Things of Marco" in Italian.
                                          Italian translation for the new version
                                          [floatl:2wjeiugn]COSEDIMARCO - The Website[/floatl:2wjeiugn]
                                          • fredo6F Offline
                                            Massimo,
                                            This is not really a bug of FreeScale (and not of the version 2.0e), but a problem of Selection.
                                            When you exit the Stretch, only the edges are selected, not the faces.
                                            Then applying the Bend would only operate on these selected edges.
                                            You can try by deselecting All after stretch, before using Bend.
                                            This is why I recommend to enclose the geometry in a group (or component), because with geometry at native level, it is very difficult in Ruby to maintain properly the selection for faces (due to the fact that SU changes the object Ids when faces are deformed).
                                            • 11
                                            • 12
                                            • 13
                                            • 56
                                            • 57
                                            • 11 / 57
