    [Plugin][$] FredoScale - v3.7c - 19 Aug 26
    1.2k Posts 347 Posters 3.3m Views 345 Watching
    • fredo6F
      For some strange reason the Radial Bend feature just stopped working? everything else seems fine. Or maybe I am not using it right? Any ideas?
      David,
      What is the exact problem:
      • does it crash or bug splat?
      • Do you see the protractor and can you use it?
      • do you see the wireframe?
      • bagateloB
        bagatelo
        I liked that plugin a lot, this is saving a lot of my time. But...
        I don't know if I will get to explain the problem of behavior of the plugin that doesn't please me, but I will try.
        My displeasure is regarding the Icon "Stretching with Box by matching an origin and the target." After it is chosen the plan where Stretch should happen, I cannot use a relationship of distance among distant objects as it could use the command MOVES common of Sketchup. I need to draw a line or object to the close origin point and the close target point to make Stretch. It would be interesting if it went as in the command it MOVES of the sketchup, where I can use points of it distances wanted distant of the object that desire to make Stretch.
        • fredo6F
          NEW VERSION 2.0d
          It fixes a major bug introduced in 2.0c for the target mode of Scale, Stretch, Shear, and also for setting the dimensions via the dialog box. Sorry for inconvenience.
          So it is strongly advised to upgrade.
          As a bonus, you'll get the Korean translation by Couque D`asse.
          All details are in main post http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=17948&st=0&sk=t&sd=a#p144180
          Note: You will also need to download LibFredo6 3.1d
          • utilerU
            utiler
            'Thanks Fredo' seems so insignificant!!!
            Just Curious...
            • david_hD
              david_h
              Fredo. . .
              Downloaded the latest version and the bending works now. But the Icons don't show up on the tool bar. I had them before just fine . . .now I don't.
              I just didn't get a chance to mention it. I had this problem with 2.0c as well.
              DO they icons png's belong in their own subfolder?
              • jcharltoncarpJ
                jcharltoncarp
                OK I've Dealt with it
                I'm reposting this from the Newbie forum. I've been taking advantage of the current economic down turn, to, amongst other things learn Sketchup. The reason I joined the forum is my interest in Fredo's amazing freescale tool. I'm very new to SketchUcation. A few months into Shetchup, and less than six months back to Mac after an absence since OS 4. I'm using a Mac running Leopard and have been unable to install the downloads correctly in my plugins folder. I was wondering if someone could post a screen shot of the folder hierarchy properly installed? I have been following the posts on the Ruby forum and have tried several ways to do the installation, but no joy. All suggestions gratefully accepted.
                John
                • jeff hammondJ
                  they should be in a folder called 'IMAGES_Standard' which is inside the 'FREESCALE_Dir_20' folder.
                  if you want daniel's icons, they will be in a folder called 'IMAGES_DanielS' which goes in the freescale folder and you activate them via the parameters dialog.
                  • david_hD
                    david_h
                    Success!!! Thanks a lot.
                    D
                      Matt666
                      Hi Fredo!
                      I just tried your new version (v2.0d), but it seems to bug when I want to move some points...
                      • Procedure:
                      • Start scale tool
                      • Select a cube
                      • Try to move a corner (with one of your points). Impossible to move any point.* Error message in the ruby console:Sans titre 1.jpg 😉
                      Frenglish at its best !
                      My scripts
                      • fredo6F
                        Matt,
                        I don't know what this is, as I cannot reproduce it on my machine.
                        Just in case, I slighlty modified the code around the "round" function.
                        Can you try it, and tell if you can reproduce the bug.
                        to drop in FREESCALE_Dir_20 folder
                        • fredo6F
                          NEW VERSION 2.0e NOW RELEASED
                          It fixes a bug recently found for Stretch in Target mode.
                          See details in main post http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=17948&st=0&sk=t&sd=a#p144180
                          You also need to download LibFredo6 3.1e
                          • C
                            Click Draw
                            Fredo6,
                            Was twist just added?
                            Thanks,
                            Jeff
                            Have I mentioned how much of a laugh I get out of some of the Signatures on here!
                            • fredo6F
                              Jeff
                              No, it was in the first release 2.0a.
                              Do you have any issue with the tool?
                              • massimoM
                                massimo Moderator
                                Fredo, some problems with this new version. Draw a rectangle, pushpull it then stretch. Use the bend tool. It doesn't works properly anymore.
                                • utilerU
                                  utiler
                                  Incredible, Fredo!!!!!
                                  Just Curious...
                                  • COSEDIMARCOC
                                    COSEDIMARCO
                                    @Fredo6
                                    New Italian translation is ready.
                                    You should add a string for "Donation...". The translation is "Donazioni...".
                                    Ps. My nickname is "COSEDIMARCO" and not "Marco Cosedi". 😄 it means " Things of Marco" in Italian.
                                    Italian translation for the new version
                                    [floatl:2wjeiugn]COSEDIMARCO - The Website[/floatl:2wjeiugn]
                                    • fredo6F
                                      Massimo,
                                      This is not really a bug of FreeScale (and not of the version 2.0e), but a problem of Selection.
                                      When you exit the Stretch, only the edges are selected, not the faces.
                                      Then applying the Bend would only operate on these selected edges.
                                      You can try by deselecting All after stretch, before using Bend.
                                      This is why I recommend to enclose the geometry in a group (or component), because with geometry at native level, it is very difficult in Ruby to maintain properly the selection for faces (due to the fact that SU changes the object Ids when faces are deformed).
                                      • massimoM
                                        massimo Moderator
                                        Ok, thanks. That works.
                                        Massimo
                                        • daikuD
                                          daiku
                                          Confirming that stretch to target now works correctly. Excellent work, as always, Fredo. CB.
                                          Clark Bremer
                                          http://www.northernlightstimberframing.com
                                          • fredo6F
                                            NEW VERSION 2.0f NOW RELEASED
                                            It fixes remaining issues for Mac compatibility of web dialog boxes and includes the full translation in Italian by COSEDIMARCOhttp://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=17948&st=0&sk=t&sd=a#p144180
                                            You also need to download LibFredo6 3.1f
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 58
                                            • 59
                                            • 13 / 59
