    New API doc - typos and questions
    370 Posts 35 Posters 269.9k Views 35 Watching
      remus
      Jim, is there a way that I could be granted edit rights just to this thread? Then I could add a FIXED note inside the reports as I correct them?
      I'll ask gai if he can make you a mod for the ruby forum πŸ‘
      • scottliningerS Offline
        scottlininger
        @thomthom said:
        ToolObservers? How are they related to onClose and onOpen?
        I meant to say, InstanceObservers. πŸ˜›
        In any case, they fire fine for me.
        • Scott Lininger
          SketchUp Software Engineer
          Have you visited the Ruby API Docs?
          Jim
          Scott, there's no way to give edit-rights on a single topic. So you get edit rights to the whole Ruby Forum.
          If you have a list of changes, we can take care of marking them fixed. I'd hate to see you spend time doing it if you have more important work to do.
            Hi Scott, I have sent you a PM, too, about it. The mods have also be informed to welcome you in the team.
            πŸ˜†
              Hmm... When I tried to implement it in my plugin the onClose never fired. I also tried Jim's observer test script: http://sketchuptips.blogspot.com/2008/03/plugin-oberver-tests.html - and that never fired either. Could you post a working sample where onClose fires? (The onOpen always works though.)
                scottlininger
                Give this a go... Could be that we're seeing a sneaky bug...
                class MyInstanceObserver < Sketchup;;InstanceObserver
                   def onOpen(instance)
                     UI.messagebox("onOpen; " + instance.to_s)
                   def onClose(instance)
                     UI.messagebox("onClose; " + instance.to_s)
                model = Sketchup.active_model
                model.definitions[0].instances[0].add_observer(MyInstanceObserver.new)
                • Scott Lininger
                  Nopes. Doesn't work.
                    Jim
                    Works for me...
                      Scott just found out that it works if the script loads when SU loads. But if you put it a subfolder for instance, and then manually load it, it won't work.
                      Jim's Observer tests never fire the event in SU7. However, in SU6 it works fine.
                        Jim
                        Just wondering if you have Dynamic Components on, and what happens if you turn them off?
                          Well I'll be! After disabling DCs the onClose even works!
                          btw, the DefinitionObserver works in SU6. But not SU7. Noticed that when I tested this observer in SU6.
                            scottlininger
                            Self note: need to add an explanation of how add_face works in relation to which "side" of the face is inside vs. outside, and document the exception where faces drawn at z=0 are always drawn with inside facing upward.
                            πŸ˜„
                            -Scott Lininger
                            • Scott Lininger
                              scottlininger
                              From Didier's post:
                              301 Moved Permanently
                              (www.sketchucation.com)
                              Need to add an FAQ for getting to installation directory of SU, for folks trying to build installers (and find out a mac equivalent.)
                              • Scott Lininger
                                avariant
                                BoundingBox.valid?
                                text says
                                status
                                    true if the bounding box is valid (not empty), false if it is not valid (empty)
                                but the code example has it exactly the opposite:
                                 bbox = Sketchup.active_model.bounds
                                 status = bbox.valid?
                                 if (status)
                                   # If true, bounding box is empty.
                                 else
                                   # If false, bounding box contains entities.
                                • Chris FullmerC Offline
                                  The introduction to RenderingOptions class states:
                                  The majority of the rendering information returned exists in the Model Info > Display section of SketchUp.
                                  There is no longer a Model Info > Distplay section of SketchUp. I suppose it should say its in the styles inspector or something like that.
                                  http://code.google.com/apis/sketchup/docs/ourdoc/renderingoptions.html#introduction
                                  Also, the API doesn't list these:
                                  DisplayQueWidth
                                  DisplayDims
                                  DisplaySketchAxes
                                  DisplayText
                                  DisplayWatermarks
                                  DrawDepthQue
                                  DrawLineEnds
                                  DrawProfilesOnly
                                  DrawUnderground
                                  EdgeType
                                  FogEndDist*- listed as FogEnd in the API*
                                  FogStartDist - listed as FogStart in the API
                                  HideConstructionGeometry
                                  LineEndWidth
                                  LockedColor
                                  SectionTransparencyMode
                                  ShowViewName
                                  And the API lists these which don't appear to be valid:
                                  DisplayFogEdges
                                  FogDensity
                                  FogEnd - appears to actually be FogEndDist
                                  FogStart*- appears to actually be FogStartDist*
                                  FogType
                                  I tried to be thorough, but perhaps I missed something. It might not be bad to double check my work πŸ˜„
                                    http://code.google.com/apis/sketchup/docs/ourdoc/tool.html#onReturn
                                    the onReturn method is showing an example for onMouseLeave
                                      http://code.google.com/apis/sketchup/docs/ourdoc/view.html#zoom_extents
                                      Does not give an example of view.zoom_extents. It gives an example of view.zoom
                                        ModelObserver.onExplode
                                        http://code.google.com/apis/sketchup/docs/ourdoc/modelobserver.html#onExplode
                                        The onExplode method is invoked whenever a component anywhere in this model is exploded. This is an easier way to watch explode events vs. attaching an InstanceObserver to every instance in the model.
                                        The docs in InstanceObserver http://code.google.com/apis/sketchup/docs/ourdoc/instanceobserver.html doesn't mention any explode event. All though, I imagine there used to be. ModelObserver.onExplode is new to SU7, and I'm sure there was an explode related event in SU6. But it's MIA atm.
                                          Face.position_material
                                          http://code.google.com/intl/nb/apis/sketchup/docs/ourdoc/face.html#position_material
                                          Doesn't explain the difference between using 2,4,6 or 8 points.
                                            Vector3d.samedirection?
                                            http://code.google.com/intl/nb/apis/sketchup/docs/ourdoc/vector3d.html#samedirection?
                                            vector = Geom::Vector3d.new 0,0,1
                                            vector2 = Geom::Vector3d.new 0,1,0
                                            status = vector.sime_direction? vector2
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 18
                                            • 19
                                            • 12 / 19
