    New API doc - typos and questions
    370 Posts 35 Posters 269.7k Views 35 Watching
      ToolObservers? How are they related to onClose and onOpen?
        remus
        Jim, is there a way that I could be granted edit rights just to this thread? Then I could add a FIXED note inside the reports as I correct them?
        I'll ask gai if he can make you a mod for the ruby forum πŸ‘
        • scottliningerS Offline
          scottlininger
          I meant to say, InstanceObservers. πŸ˜›
          In any case, they fire fine for me.
          • Scott Lininger
            SketchUp Software Engineer
            Have you visited the Ruby API Docs?
            Jim
            Scott, there's no way to give edit-rights on a single topic. So you get edit rights to the whole Ruby Forum.
            If you have a list of changes, we can take care of marking them fixed. I'd hate to see you spend time doing it if you have more important work to do.
              Hi Scott, I have sent you a PM, too, about it. The mods have also be informed to welcome you in the team.
              πŸ˜†
                Hmm... When I tried to implement it in my plugin the onClose never fired. I also tried Jim's observer test script: http://sketchuptips.blogspot.com/2008/03/plugin-oberver-tests.html - and that never fired either. Could you post a working sample where onClose fires? (The onOpen always works though.)
                  scottlininger
                  Give this a go... Could be that we're seeing a sneaky bug...
                  class MyInstanceObserver < Sketchup;;InstanceObserver
                     def onOpen(instance)
                       UI.messagebox("onOpen; " + instance.to_s)
                     def onClose(instance)
                       UI.messagebox("onClose; " + instance.to_s)
                  model = Sketchup.active_model
                  model.definitions[0].instances[0].add_observer(MyInstanceObserver.new)
                  • Scott Lininger
                    Nopes. Doesn't work.
                      Jim
                      Works for me...
                        Scott just found out that it works if the script loads when SU loads. But if you put it a subfolder for instance, and then manually load it, it won't work.
                        Jim's Observer tests never fire the event in SU7. However, in SU6 it works fine.
                          Jim
                          Just wondering if you have Dynamic Components on, and what happens if you turn them off?
                            Well I'll be! After disabling DCs the onClose even works!
                            btw, the DefinitionObserver works in SU6. But not SU7. Noticed that when I tested this observer in SU6.
                              scottlininger
                              Self note: need to add an explanation of how add_face works in relation to which "side" of the face is inside vs. outside, and document the exception where faces drawn at z=0 are always drawn with inside facing upward.
                              πŸ˜„
                              -Scott Lininger
                              • Scott Lininger
                                scottlininger
                                From Didier's post:
                                301 Moved Permanently
                                (www.sketchucation.com)
                                Need to add an FAQ for getting to installation directory of SU, for folks trying to build installers (and find out a mac equivalent.)
                                • Scott Lininger
                                  avariant
                                  BoundingBox.valid?
                                  text says
                                  status
                                      true if the bounding box is valid (not empty), false if it is not valid (empty)
                                  but the code example has it exactly the opposite:
                                   bbox = Sketchup.active_model.bounds
                                   status = bbox.valid?
                                   if (status)
                                     # If true, bounding box is empty.
                                   else
                                     # If false, bounding box contains entities.
                                  • Chris FullmerC Offline
                                    The introduction to RenderingOptions class states:
                                    The majority of the rendering information returned exists in the Model Info > Display section of SketchUp.
                                    There is no longer a Model Info > Distplay section of SketchUp. I suppose it should say its in the styles inspector or something like that.
                                    http://code.google.com/apis/sketchup/docs/ourdoc/renderingoptions.html#introduction
                                    Also, the API doesn't list these:
                                    DisplayQueWidth
                                    DisplayDims
                                    DisplaySketchAxes
                                    DisplayText
                                    DisplayWatermarks
                                    DrawDepthQue
                                    DrawLineEnds
                                    DrawProfilesOnly
                                    DrawUnderground
                                    EdgeType
                                    FogEndDist*- listed as FogEnd in the API*
                                    FogStartDist - listed as FogStart in the API
                                    HideConstructionGeometry
                                    LineEndWidth
                                    LockedColor
                                    SectionTransparencyMode
                                    ShowViewName
                                    And the API lists these which don't appear to be valid:
                                    DisplayFogEdges
                                    FogDensity
                                    FogEnd - appears to actually be FogEndDist
                                    FogStart*- appears to actually be FogStartDist*
                                    FogType
                                    I tried to be thorough, but perhaps I missed something. It might not be bad to double check my work πŸ˜„
                                      http://code.google.com/apis/sketchup/docs/ourdoc/tool.html#onReturn
                                      the onReturn method is showing an example for onMouseLeave
                                        http://code.google.com/apis/sketchup/docs/ourdoc/view.html#zoom_extents
                                        Does not give an example of view.zoom_extents. It gives an example of view.zoom
                                          ModelObserver.onExplode
                                          http://code.google.com/apis/sketchup/docs/ourdoc/modelobserver.html#onExplode
                                          The onExplode method is invoked whenever a component anywhere in this model is exploded. This is an easier way to watch explode events vs. attaching an InstanceObserver to every instance in the model.
                                          The docs in InstanceObserver http://code.google.com/apis/sketchup/docs/ourdoc/instanceobserver.html doesn't mention any explode event. All though, I imagine there used to be. ModelObserver.onExplode is new to SU7, and I'm sure there was an explode related event in SU6. But it's MIA atm.
                                            Face.position_material
                                            http://code.google.com/intl/nb/apis/sketchup/docs/ourdoc/face.html#position_material
                                            Doesn't explain the difference between using 2,4,6 or 8 points.
                                            • 18
                                            • 19
                                            • 5 / 19
