    New API doc - typos and questions
    370 Posts 35 Posters 371.9k Views 35 Watching
    • Chris FullmerC
      Error 404 (Not Found)!!1
      (code.google.com)
      The ComponentInstance.definition example does not include the method in the example anywhere, so by definition it is not really an example.
      This is the given example:
       point = Geom;;Point3d.new 10,20,30
       transform = Geom;;Transformation.new point
       model = Sketchup.active_model
       entities = model.active_entities
       path=Sketchup.find_support_file "Bed.skp",
         "Components/Components Sampler/"
        Jim
        Any ideas about a way to mark these errors as they are fixed?
          We could ask Coen to have a strike-through BBC tag. [deleted] or something...
          Or, put a big fat FIXED in bold green. Might be easier.
            avariant
            From Image.explode:
            entitiesarray     an Array object of entities if successful
            which I interpret as the face and edges created in the explosion. However, the result from my testing always returns an empty array.
              I see that behaviour as well: http://www.sketchucation.com/forums/scf/viewtopic.php?f=11&t=17150&hilit=+explode
              • Chris FullmerC
                (code.google.com)
                add polygon detail just repeats the add_point example.
                • scottliningerS
                  scottlininger
                  @thomthom said:
                  Seems that InstanceObserver.onClose is dead as well. http://code.google.com/apis/sketchup/docs/ourdoc/instanceobserver.html#onClose
                  But onOpen works.
                  Thomas,
                  I'm about to push an update with all of the recent changes above. This one puzzled me, though. The ToolsObserver examples work fine for me on the onOpen and onClose. Can you clarify what "dead as well" means? πŸ˜„
                  Does this list work 'across-platforms' - my understanding was that PCs and Macs differ ?
                  Tig, these action codes only work on the PC, but I still think I'll add them to the docs. There are some cool things in there that PC-only shops might need.
                  Thanks, guys! New update should be live in the next day or so.
                  • Scott Lininger
                    SketchUp Software Engineer
                    Have you visited the Ruby API Docs?
                  • scottliningerS
                    scottlininger
                    Jim, is there a way that I could be granted edit rights just to this thread? Then I could add a FIXED note inside the reports as I correct them?
                    • Scott Lininger
                      Dead as in: I never see it trigger.
                        ToolObservers? How are they related to onClose and onOpen?
                          remus
                          I'll ask gai if he can make you a mod for the ruby forum πŸ‘
                          • scottliningerS
                            scottlininger
                            I meant to say, InstanceObservers. πŸ˜›
                            In any case, they fire fine for me.
                            • Scott Lininger
                              Jim
                              Scott, there's no way to give edit-rights on a single topic. So you get edit rights to the whole Ruby Forum.
                              If you have a list of changes, we can take care of marking them fixed. I'd hate to see you spend time doing it if you have more important work to do.
                              • GaieusG
                                Hi Scott, I have sent you a PM, too, about it. The mods have also be informed to welcome you in the team.
                                πŸ˜†
                                  Hmm... When I tried to implement it in my plugin the onClose never fired. I also tried Jim's observer test script: http://sketchuptips.blogspot.com/2008/03/plugin-oberver-tests.html - and that never fired either. Could you post a working sample where onClose fires? (The onOpen always works though.)
                                  • scottliningerS
                                    scottlininger
                                    Give this a go... Could be that we're seeing a sneaky bug...
                                    class MyInstanceObserver < Sketchup;;InstanceObserver
                                       def onOpen(instance)
                                         UI.messagebox("onOpen; " + instance.to_s)
                                       def onClose(instance)
                                         UI.messagebox("onClose; " + instance.to_s)
                                    model.definitions[0].instances[0].add_observer(MyInstanceObserver.new)
                                    • Scott Lininger
                                      Nopes. Doesn't work.
                                        Jim
                                        Works for me...
                                          Scott just found out that it works if the script loads when SU loads. But if you put it a subfolder for instance, and then manually load it, it won't work.
                                          Jim's Observer tests never fire the event in SU7. However, in SU6 it works fine.
                                            Jim
                                            Just wondering if you have Dynamic Components on, and what happens if you turn them off?
                                            • 18
                                            • 19
                                            • 4 / 19
