    [Plugin] Shape Bender Beta
    1.3k Posts 331 Posters 1.8m Views 329 Watching
    • free agentF Offline
      free agent
      very cool thank you 😎
        boilingsnow
        Yup . ..this is a much easier way to bend steel.
        But the model you pasted can also be created easily without shape bender.
        • david_hD Offline
          david_h
          Very true, But not as fun.
          • Chris FullmerC Offline
            All right, thanks for the comments so far! I've got lots to think about. That bug where it smooths the end faces if your shape lines ep exactly with the line......I'll have to think about that. Its sort of done on purpose, but that is an exception where it is not desireable. I'll see if I can think of a way for it to be smarter.
            I'm working on groups and components as we speak. That is my #1 frustration with the script is that it explodes everything and it won't take components. I'd like to get that fixed and updated tonight. We'll see πŸ˜„ Thanks everyone, seriously!
              BTM
              Great!! 2 things: 1, why do a few random lines appear when I use it?
              also, sketchup said that there were problems, and when I agreed to let it fix them, this was the message:
              Results of Validity Check.
              CLoop (39755) for CFace (39754) has zero area
              Loop 0 of CFace (39754) is an invalid outer loop
              Entity CFace (39754) should be erased - done
              CLoop (39760) for CFace (39759) has zero area
              Loop 0 of CFace (39759) is an invalid outer loop
              Entity CFace (39759) should be erased - done
              CLoop (40274) for CFace (40273) has zero area
              Loop 0 of CFace (40273) is an invalid outer loop
              Entity CFace (40273) should be erased - done
              CLoop (40279) for CFace (40278) has zero area
              Loop 0 of CFace (40278) is an invalid outer loop
              Entity CFace (40278) should be erased - done
              CLoop (43115) for CFace (43114) has zero area
              Loop 0 of CFace (43114) is an invalid outer loop
              Entity CFace (43114) should be erased - done
              CLoop (43500) for CFace (43499) has zero area
              Loop 0 of CFace (43499) is an invalid outer loop
              Entity CFace (43499) should be erased - done
                Hmmm, very interesting.
                Well, the lines appear because a face is being bent in a way that it is not able to do, so SketchUp steps in and adds the extra lines so that it can bend as needed. I'd be interested if anyone out there has a method for determining what faces are going to need that extra geometry so I can add the lines myself beforehand.
                The invalid geometry actually probably has a lot to do with problem above. Invalid geometry can be fixed automatically, the worst that can happen is that it will delete a few bad faces. Ok, thats not really ideal. So hopefully I'll get it fixed πŸ˜„
                On a happier note, I got the script to work with groups and components. I've got a few other things I want to try to implement tonight before I post the update though. So far so good.
                  BTM
                  And up arrow isn't toggling orientation.
                    Really? Thats too bad. If the model is complex, it will take a second or two to "toggle". Its not necessarily immediate. It might need to think about it for a bit.
                    So if you've waited patiently and its still not working, that is no good. Could you open the Ruby Console and see if it gives any errors when you press the up arrow key?
                    • jeff hammondJ Offline
                      just a by-the-way going back to the perpendicular face/mac osx
                      the up arrow does work with this script on macs so it's probably something to do with the gear's geometry.
                        BTM
                        Actually, I tried it with a simple rectangle as well. It give no errors in the console, nothing happens at all. πŸ˜• With the console opened, I selected the (rectangle) group, then shape bend, then the straight line, then curved. after I selected the curved line, I pressed the up arrow. Nothing happens at all. Am I doing something wrong?
                          it sounds like you're doing it properly.. that did happen to me once yesterday (didn't get any response from the up arrow and i wasn't getting the green outline showing a preview bend.. (it was after i tried a super complex shape being bent to a weird 3d curve -- i was trying to break the ruby πŸ˜„ and succeeded)
                          i quit sketchup and relaunched and it worked again.
                          try that.
                            Hmm, here's the order of operations:
                            Select a group (must be a group, not a component in the current version of the script)
                            Activate the script
                            Select a straight line - must be drawn on the red axis. It will add "start" and "end" tags to it if it was selected correctly.
                            Select the curve. Now the grids should appear and you should be able to press the up arrow.
                            Hope that helps,
                            Jeff, I found a better method for the up arrow key. I still need to implement it in the perpendicular face tools script though - I probably will have time for that tomorrow.
                              I've tried hard to make it unbreakable.....but it has tried harder to remain breakable πŸ˜„
                                UPDATED! v 0.2 Beta
                                A few major improvements. Now you can bend a component or a group. It can be scaled or rotated however you want, no need to explode and re-group immediately before using the plugin anymore. The shape to bend can also be comprised of groups and components. The script will explode them all by necessity though.
                                Also I added dynamic highlighting. Now when you move the mouse over a line or curve that is an acceptable selection, it is highlighted. This should help make it easier to know what is an acceptable line or curve.
                                Hopefully it is more stable now. I've tweaked a few other spots in the code, but nothing major. Just those 2 things listed above. Let me know if I broke anything, or if you like what I fixed.
                                • W Offline
                                  watkins
                                  Dear Chris,
                                  Many thanks for you wonderful new plugin. I should like to thank you for your generosity too. It is greatly appreciated.
                                  I assume you meant 10 April and not 10 March.
                                  Kind regards,
                                  Bob
                                    Chris, I didn't have any trouble with the plugin yesterday when I tried it. When I woke up this morning there was an e-mail froma friend who was trying it. He sent it to me and I'm getting the same weird results. See the screen grab. The group starts out as long has the straight line. I tried it without the swirly thing at the end and get the same results. I've also tried changing the length of the curve but without luck. I discovered that it depends upon which direction the straight line is drawn. If the line is drawn from right to left, the geometry is added as shown. I also notice that if the curve is drawn from right to left the start and end points are transposed compared to the line.
                                    Right to left-drawn line:
                                    Left to right-drawn line, right to left-drawn curve
                                    Left to right-drawn line, left to right drawn curve
                                    Is there any chance of getting the plugin to ignore the direction of the drawn lines and curves?
                                    Edited to add, I tried it with the new version and got the same results.
                                      BTM
                                      Even with the new one, the up arrow NEVER does anything. I've been doing it properly, but nothing happens. Could another script have broken it? Also, I'm now having trouble with the smoothing. When the shape is first created, I have to open it again, because it doesn't appear smooth until I do.
                                        DonVid
                                        Greetings Chris:
                                        This is another great plugin that surpasses other 3D modeling program: easy, intuitive and precise. It can give several steps ahead when modeling architectural objects and entities.
                                        Thanks a MM.
                                        DonVid
                                        Component before bending
                                        Good and precise output
                                          oh no!!, the script is indeed not working if you draw the first line from right to left......grrrr! I've got an idea of how to fix it though. Give me an hour or two and I'll get it updated very shortly. Sorry, sorry, sorry. Thanks for pointing it out.
                                          @Bob, yes I meant April - oops! - The date is updated now, thanks!
                                          BTM - sorry about the arrow key. I'm guessing its another script breaking it. Would you mind poking around to see which one it is? I don't even know how another script could, but its "amazing" what other scripts do........ Also, the smoothing thing is an odd bug I agree. I noticed it to, but I couldn't find a fix. I'll look into again today and see if I can get it working better.
                                          Thanks everyone for the quick and detailed feeedback! πŸ˜„
                                            Thank you
                                            • 63
                                            • 64
                                            • 3 / 64
