    [Plugin] BezierSpline - v2.2a - 22 Apr 21
    460 Posts 183 Posters 2.1m Views 183 Watching
    • CadFatherC Offline
      CadFather
      yes... at the moment i am doing exactly the same with PresBundle - but suppose you have a path with curves, knowing the constant segment of each camera can be useful.. (i'd love the same ease as 'divide')
      when you reach the curve, splitting in two gives half transition time without having to try it out first
      another use is the copy along path, since it behaves a bit different when copying by spacing and by nodes.. surely more would follow.. interesting.. hope Fredo's loves the idea too.. for now this is all Fredo Grace! β˜€
      ..and thanks for the manual! πŸ˜‰
      • fredo6F Offline
        @cadfather said:
        ...is there a way to divide a curve by an equal number of segments or am i talking a different plug in?
        The answer should be YES.
        If you have a curve, generated by BezierSpline or from native Sktechup, you can convert it to a Polyline with equal segments by 2 methods which are delivered as part of BezierSpline (via the contextual menu "Convert to":
          1) %(#0000BF)[**Polyline Divider**]: you specify the interval, and the extension computes the number of segments
          2) %(#0000FF)[**Polyline Segmentor**]: you specify the number of segments, and the extensions computes the length of segments
        Note that all segments will be equal, except possibly the last one (but you can adjust the last vertex anyway).
        Here is an example: On the left is a regular B-Spline. On the right, the curve converted by PolyLine Divider. You can modify the interval by typing TAB and setting the value in the dialog box appearing.
        Hope this helps
          CadFather
          Many Thanks Fredo ..that will do just fine for now. πŸ‘ πŸ˜„
          (think i'm going to make a request for curve divider)
          • plot-parisP Offline
            plot-paris
            fantastic, fredo! it is really great. every time I am looking for some function of your bezier curve tool, it already exists.
            (and surely we would have found out ourselves, if we read your manual carefully πŸ˜„
            what do we learn from that? READ FREDO'S MANUALS!!!)
              CadFather
              ..and he actualy writes them really well! πŸ˜†
                cyan.archnet
                THANKS A WHOLE LOT for the update!
                • O Offline
                  otb designworks
                  Thanks! Your plugins are awesome and quite appreciated, not to mention as useful as anything in SU.
                  Cheers, Chuck
                  OTB Designworks is on Youtube
                  • F Offline
                    flyashy
                    Again, Thank You!
                    Ashy
                      chrischancc
                      so a gorgeous plugin!!
                      • EdsonE Offline
                        Edson
                        hi fredo,
                        i followed your instructions but something is not right as i do not get the cubic bezier curves in any way. please have a look at the attached images. i am on mac.
                        http://www.mahfuz.arq.br
                        • fredo6F Offline
                          Edson,
                          It seems you got the same Mac OS issue (or Podium related) as Kannonbal.
                          See this thread http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=15182. You'll find a modified version of the script.
                          I still don't understand what was going on by the way, and any clarification from Mac users would be helpful for the future.
                          • EdsonE Offline
                            Edson
                            fredo,
                            it worked. thanks!
                            the only remaining issue is that although the polyline segmentor function is working (and it shows in the contextual menu) its icon does not show in the toolbar. i had a look in the script's folder and there was no icon for it there. am i missing something?
                            regards.
                            • O Offline
                              otb designworks
                              Curiously, I am missing the same button image as Edson.
                              Thankfully, though, no loss of functionality.
                              Cheers, Chuck
                              • fredo6F Offline
                                This is normal.
                                I never designed an icon for it!
                                  smithsam
                                  First, I have to say, what an amazing plugin. I just discovered it today. Always frustrated by lack of Bezier curves in Sketchup. Wow!
                                  I did discover one problem though. The documentation does not display. I get a blank window.
                                  Mac 0S X 10.5.6 MacBook Pro Intel
                                  Sketchup 7 Pro
                                  doc.tiff
                                    agpig
                                    thank you man it's so helpful 😍
                                    • EdsonE Offline
                                      Edson
                                      @watkins said:
                                      Dear Frodo,
                                      Kind regards,
                                      Bob
                                      watkins,
                                      i just could not resist pulling your leg about the mix up of fredo6's username with the main character in The Lord of the Rings.
                                      • W Offline
                                        watkins
                                        Dear Edson,
                                        You are not the only one to spot that. I will have to be more careful in future.
                                        Regards,
                                        Bob
                                          mattg
                                          Just re-downloaded this for SU7.
                                          Any reason why the toolbar won't hug the side of the screen.
                                          Seems to only want to sit horizontally along the top.
                                          • fredo6F Offline
                                            Matt,
                                            As you may know, scripts have zero control over the toolbar placement from Ruby.
                                            So it must be SU7 or the configuration of the toolbar set.
                                            In my SU7 environment, I don't have any particular issue.
                                            • 22
                                            • 23
                                            • 2 / 23
