    • Conectarse
    [Plugin][$] FredoScale - v3.6a - 01 Apr 24
    Programado Fijo Cerrado Movido Plugins
    1.1k Mensajes 345 Posters 2.4m Visitas 342 Watching
    Cargando más mensajes
    • Más antiguo a más nuevo
    • Más nuevo a más antiguo
    • Mayor número de Votos
    Responder
    • Responder como tema
    Accede para responder
    Este tema ha sido borrado. Solo los usuarios que tengan privilegios de administración de temas pueden verlo.
    • Chris FullmerC Desconectado
      Última edición por
      You should just be able to click on it and it should pop up a windows asking if you want to save or open. What operating system are you on? What browser are you using?
      1 Respuesta Última respuesta Responder Citar 0
      • M Desconectado
        malvin
        Última edición por
        • M Desconectado
          malvin
          Última edición por
          • M Desconectado
            malvin
            Última edición por
            I have Windows XP Pro, Internet Explorer 6
            The window does pop up to save or open but instead of save the zip file.php is saved
            Please advice
            Olga
            • E Desconectado
              Ecuadorian
              Última edición por
              Get rid of Internet explorer and get either Firefox or Google Chrome. Both are free and a lot less of a headache.
              -Miguel Lescano
              • soloS Desconectado
                Última edición por
                hmmmm, I would'nt say that IE is that bad, pretty stable IMO.
                However I noticed that Malvin is using version 6, considering version 8 is out and he has not upgraded one can deduce that he does not have updates enabled therefore all his definitions and drivers are probably outdated.
                • M Desconectado
                  malvin
                  Última edición por
                  Yes, solo, I do not have updates enabled so that might be the reason but I do download stuff now and then and only very seldom I run into this problem when instead of zip I have file.php downloaded. That might be the promlem
                  • X Desconectado
                    xrok1
                    Última edición por
                    i noticed a quirk?
                    if i use the SP toolbar to create a cone, i cannot stretch it up or down no matter what. i can however stretch it from the sides?
                    its not too important to me i just thought i'd mention it in case its a bigger thing than i can tell.
                    • B Desconectado
                      boilingsnow
                      Última edición por
                      Thank you very much Fredo!
                      But it seems that the streching tool doesn't work on cylinders.
                      • J Desconectado
                        jmmad
                        Última edición por
                        boilingsnow & xrok1
                        stretch wont affect curves.
                        to affect it you must explode the curve first.
                        Get Upa !
                        • X Desconectado
                          xrok1
                          Última edición por
                          if i stretch a cone from the point upward, what does that have to do with a curve?
                          • utilerU Desconectado
                            utiler
                            Última edición por
                            Pete, I just un-installed 8 as it was causing some issues and couldn't be bothered to troubleshooting... less time on FreeScale. 😉
                            Just Curious...
                            • J Desconectado
                              jmmad
                              Última edición por
                              You are right
                              The problem with a cone is that upwards its made of triangles you cannot stretch a triangle it would be the same as using scale.
                              As it wont work with a 3 side piramid in any direction
                              Get Upa !
                              • fredo6F Desconectado
                                Última edición por
                                jmmad,
                                On your problem of freeze, and since you seem to be able to reproduce the problem, could you just try with the attached file (just drop it into the FREESCALE_Dir_20 folder).
                                I am not too sure of what it can be, but I rewrite one part of the code differently.
                                Thanks to advise
                                to drop into FREESCALE_Dir_20 folder
                                • J Desconectado
                                  jmmad
                                  Última edición por
                                  I did what you told me.
                                  But the freeze continues but its only with this component y tried to duplicate the bug with similar components (a component with 4 nested components inside) and the tool works perfect.
                                  Its strange i think this might be a isolated problem not much to worry about.
                                  Thxs for the concern and help
                                  Get Upa !
                                    Última edición por
                                    @daniel s said:
                                    • A feature of the native protactor-rotate tool is missing... The ability of holding down the primary mouse button, and dragging the protractor is great:
                                      [attachment=1:2xhvp641]<!-- ia1 -->Animation_Rotate_Tool.gif<!-- ia1 -->[/attachment:2xhvp641]
                                      http://sites.google.com/site/sketchupsage/tweak/rotate
                                      This option can be added?
                                    Thank you again for this amazings tools,
                                    Daniel S
                                    Daniel,
                                    Can you try if this works for you (drop the attached file into LIBFREDO6_Dir_31 folder). I must say that I did not know this function, but using it a little bit, it seems very convenient. So thank you for signaling it and evangelizing other users.
                                    to drop into LIBFREDO6_Dir_31 folder
                                    • P Desconectado
                                      princedragoncok
                                      Última edición por
                                      Thank you for this great set of tools fredo. Seem to handle even complex geometry well. mighty impressed!
                                      • D Desconectado
                                        Daniel S
                                        Última edición por
                                        Daniel,
                                        Works great for endpoints but if you place the protactor on edges and drag it dosen´t lock in the exact point you start the operation. Is like the protactor slips. The same happens if you place the protactor on a face and drag.
                                        Thank you for adding this option!!!
                                        Daniel S
                                          Última edición por
                                          of course.
                                          Sorry for that
                                          Lib6Protractor.rb
                                          • D Desconectado
                                            Daniel S
                                            Última edición por
                                            The protactor still slips for me.
                                            Daniel S
                                            • 11
                                            • 12
                                            • 56
                                            • 57
                                            • 10 / 57
