    [Plugin][$] FredoScale - v3.7c - 19 Aug 26
    1.2k Posts 347 Posters 3.5m Views 345 Watching
    • E
      Ecuadorian
      Get rid of Internet explorer and get either Firefox or Google Chrome. Both are free and a lot less of a headache.
      -Miguel Lescano
      • soloS
        hmmmm, I would'nt say that IE is that bad, pretty stable IMO.
        However I noticed that Malvin is using version 6, considering version 8 is out and he has not upgraded one can deduce that he does not have updates enabled therefore all his definitions and drivers are probably outdated.
          malvin
          Yes, solo, I do not have updates enabled so that might be the reason but I do download stuff now and then and only very seldom I run into this problem when instead of zip I have file.php downloaded. That might be the promlem
          • X
            xrok1
            i noticed a quirk?
            if i use the SP toolbar to create a cone, i cannot stretch it up or down no matter what. i can however stretch it from the sides?
            its not too important to me i just thought i'd mention it in case its a bigger thing than i can tell.
            • B
              boilingsnow
              Thank you very much Fredo!
              But it seems that the streching tool doesn't work on cylinders.
                jmmad
                boilingsnow & xrok1
                stretch wont affect curves.
                to affect it you must explode the curve first.
                Get Upa !
                • X
                  xrok1
                  if i stretch a cone from the point upward, what does that have to do with a curve?
                  • utilerU
                    utiler
                    Pete, I just un-installed 8 as it was causing some issues and couldn't be bothered to troubleshooting... less time on FreeScale. 😉
                    Just Curious...
                      jmmad
                      You are right
                      The problem with a cone is that upwards its made of triangles you cannot stretch a triangle it would be the same as using scale.
                      As it wont work with a 3 side piramid in any direction
                      Get Upa !
                      • fredo6F
                        jmmad,
                        On your problem of freeze, and since you seem to be able to reproduce the problem, could you just try with the attached file (just drop it into the FREESCALE_Dir_20 folder).
                        I am not too sure of what it can be, but I rewrite one part of the code differently.
                        Thanks to advise
                        to drop into FREESCALE_Dir_20 folder
                          jmmad
                          I did what you told me.
                          But the freeze continues but its only with this component y tried to duplicate the bug with similar components (a component with 4 nested components inside) and the tool works perfect.
                          Its strange i think this might be a isolated problem not much to worry about.
                          Thxs for the concern and help
                          Get Upa !
                          • fredo6F
                            @daniel s said:
                            • A feature of the native protactor-rotate tool is missing... The ability of holding down the primary mouse button, and dragging the protractor is great:
                              [attachment=1:2xhvp641]<!-- ia1 -->Animation_Rotate_Tool.gif<!-- ia1 -->[/attachment:2xhvp641]
                              http://sites.google.com/site/sketchupsage/tweak/rotate
                              This option can be added?
                            Thank you again for this amazings tools,
                            Daniel S
                            Daniel,
                            Can you try if this works for you (drop the attached file into LIBFREDO6_Dir_31 folder). I must say that I did not know this function, but using it a little bit, it seems very convenient. So thank you for signaling it and evangelizing other users.
                            to drop into LIBFREDO6_Dir_31 folder
                            • P
                              princedragoncok
                              Thank you for this great set of tools fredo. Seem to handle even complex geometry well. mighty impressed!
                                Daniel S
                                Daniel,
                                Works great for endpoints but if you place the protactor on edges and drag it dosen´t lock in the exact point you start the operation. Is like the protactor slips. The same happens if you place the protactor on a face and drag.
                                Thank you for adding this option!!!
                                Daniel S
                                • fredo6F
                                  of course.
                                  Sorry for that
                                  Lib6Protractor.rb
                                    Daniel S
                                    The protactor still slips for me.
                                    Daniel S
                                    • fredo6F
                                      Daniel S
                                      Re-sorry.
                                      I guess this is better now
                                      Lib6Protractor.rb
                                        Is it possible to use the radial Bending only for "slicer" a volume without to bend?
                                        If yes how?
                                        If I click (start end) a "straight line" along an edge nothing append when release the protractor without bending 😳
                                        • fredo6F
                                          If yes how?
                                          I had the idea to isolate the slicer as a separate tool (then in 3 directions). so at least one requestor.
                                          In between, you have one in SketchyFFD
                                          PS: If you don't bend, then nothing happens, which is the natural and intentional behavior
                                            Daniel S
                                            The latest Lib6Protractor.rb works very well like the native SU tool.
                                            Thank you Again!!!
                                            Daniel S
                                            • 58
                                            • 59
                                            • 7 / 59
