    [Plugin][$] FredoScale - v3.7c - 19 Aug 26
    1.2k Posts 347 Posters 3.5m Views 345 Watching
      jmmad
      I cannot reproduce the freeze (see video attached). Is it something always reproducable in your environment?
      Can any other user try to reproduce it?
      [attachment=0:2n2vwxal]<!-- ia0 -->Bench Moder trial.wmv<!-- ia0 -->[/attachment:2n2vwxal]
      I detected that the freez only happens when i have set the planes to a certain position and hit control, then 2 planes apear instead of one and i stretch from the center, but while im stretching the component SU freezes, always.
      Thxs for responding.
      All the rest works like charm
      Get Upa !
        malvin
        How do I download the zip? I have only php file saved.
        Please advice
        • Chris FullmerC
          You should just be able to click on it and it should pop up a windows asking if you want to save or open. What operating system are you on? What browser are you using?
            malvin
              malvin
                malvin
                I have Windows XP Pro, Internet Explorer 6
                The window does pop up to save or open but instead of save the zip file.php is saved
                Please advice
                Olga
                • E
                  Ecuadorian
                  Get rid of Internet explorer and get either Firefox or Google Chrome. Both are free and a lot less of a headache.
                  -Miguel Lescano
                  • soloS
                    hmmmm, I would'nt say that IE is that bad, pretty stable IMO.
                    However I noticed that Malvin is using version 6, considering version 8 is out and he has not upgraded one can deduce that he does not have updates enabled therefore all his definitions and drivers are probably outdated.
                      malvin
                      Yes, solo, I do not have updates enabled so that might be the reason but I do download stuff now and then and only very seldom I run into this problem when instead of zip I have file.php downloaded. That might be the promlem
                      • X
                        xrok1
                        i noticed a quirk?
                        if i use the SP toolbar to create a cone, i cannot stretch it up or down no matter what. i can however stretch it from the sides?
                        its not too important to me i just thought i'd mention it in case its a bigger thing than i can tell.
                        ā€œThere are three classes of people: those who see. Those who see when they are shown. Those who do not see.ā€
                        • B
                          boilingsnow
                          Thank you very much Fredo!
                          But it seems that the streching tool doesn't work on cylinders.
                            jmmad
                            boilingsnow & xrok1
                            stretch wont affect curves.
                            to affect it you must explode the curve first.
                            Get Upa !
                            • X
                              xrok1
                              if i stretch a cone from the point upward, what does that have to do with a curve?
                              • utilerU
                                utiler
                                Pete, I just un-installed 8 as it was causing some issues and couldn't be bothered to troubleshooting... less time on FreeScale. šŸ˜‰
                                Just Curious...
                                  jmmad
                                  You are right
                                  The problem with a cone is that upwards its made of triangles you cannot stretch a triangle it would be the same as using scale.
                                  As it wont work with a 3 side piramid in any direction
                                  Get Upa !
                                  • fredo6F
                                    jmmad,
                                    On your problem of freeze, and since you seem to be able to reproduce the problem, could you just try with the attached file (just drop it into the FREESCALE_Dir_20 folder).
                                    I am not too sure of what it can be, but I rewrite one part of the code differently.
                                    Thanks to advise
                                    to drop into FREESCALE_Dir_20 folder
                                      jmmad
                                      I did what you told me.
                                      But the freeze continues but its only with this component y tried to duplicate the bug with similar components (a component with 4 nested components inside) and the tool works perfect.
                                      Its strange i think this might be a isolated problem not much to worry about.
                                      Thxs for the concern and help
                                      Get Upa !
                                      • fredo6F
                                        @daniel s said:
                                        • A feature of the native protactor-rotate tool is missing... The ability of holding down the primary mouse button, and dragging the protractor is great:
                                          [attachment=1:2xhvp641]<!-- ia1 -->Animation_Rotate_Tool.gif<!-- ia1 -->[/attachment:2xhvp641]
                                          http://sites.google.com/site/sketchupsage/tweak/rotate
                                          This option can be added?
                                        Thank you again for this amazings tools,
                                        Daniel S
                                        Daniel,
                                        Can you try if this works for you (drop the attached file into LIBFREDO6_Dir_31 folder). I must say that I did not know this function, but using it a little bit, it seems very convenient. So thank you for signaling it and evangelizing other users.
                                        to drop into LIBFREDO6_Dir_31 folder
                                        • P
                                          princedragoncok
                                          Thank you for this great set of tools fredo. Seem to handle even complex geometry well. mighty impressed!
                                            Daniel S
                                            Daniel,
                                            Works great for endpoints but if you place the protactor on edges and drag it dosen“t lock in the exact point you start the operation. Is like the protactor slips. The same happens if you place the protactor on a face and drag.
                                            Thank you for adding this option!!!
                                            Daniel S
                                            With your input, this post could be even better šŸ’—
                                            • 58
                                            • 59
                                            • 7 / 59
