    [Plugin][$] FredoScale - v3.7c - 19 Aug 26
    1.2k Posts 347 Posters 3.3m Views 345 Watching
    • B
      boilingsnow
      Thank you very much Fredo!
      But it seems that the streching tool doesn't work on cylinders.
        jmmad
        boilingsnow & xrok1
        stretch wont affect curves.
        to affect it you must explode the curve first.
        Get Upa !
        • X
          xrok1
          if i stretch a cone from the point upward, what does that have to do with a curve?
          • utilerU
            utiler
            @solo said:
            hmmmm, I would'nt say that IE is that bad, pretty stable IMO.
            However I noticed that Malvin is using version 6, considering version 8 is out and he has not upgraded one can deduce that he does not have updates enabled therefore all his definitions and drivers are probably outdated.
            Pete, I just un-installed 8 as it was causing some issues and couldn't be bothered to troubleshooting... less time on FreeScale. 😉
            Just Curious...
              jmmad
              You are right
              The problem with a cone is that upwards its made of triangles you cannot stretch a triangle it would be the same as using scale.
              As it wont work with a 3 side piramid in any direction
              Get Upa !
              • fredo6F
                jmmad,
                On your problem of freeze, and since you seem to be able to reproduce the problem, could you just try with the attached file (just drop it into the FREESCALE_Dir_20 folder).
                I am not too sure of what it can be, but I rewrite one part of the code differently.
                Thanks to advise
                to drop into FREESCALE_Dir_20 folder
                  jmmad
                  I did what you told me.
                  But the freeze continues but its only with this component y tried to duplicate the bug with similar components (a component with 4 nested components inside) and the tool works perfect.
                  Its strange i think this might be a isolated problem not much to worry about.
                  Thxs for the concern and help
                  Get Upa !
                  • fredo6F
                    @daniel s said:
                    • A feature of the native protactor-rotate tool is missing... The ability of holding down the primary mouse button, and dragging the protractor is great:
                      [attachment=1:2xhvp641]<!-- ia1 -->Animation_Rotate_Tool.gif<!-- ia1 -->[/attachment:2xhvp641]
                      http://sites.google.com/site/sketchupsage/tweak/rotate
                      This option can be added?
                    Thank you again for this amazings tools,
                    Daniel S
                    Daniel,
                    Can you try if this works for you (drop the attached file into LIBFREDO6_Dir_31 folder). I must say that I did not know this function, but using it a little bit, it seems very convenient. So thank you for signaling it and evangelizing other users.
                    to drop into LIBFREDO6_Dir_31 folder
                    • P
                      princedragoncok
                      Thank you for this great set of tools fredo. Seem to handle even complex geometry well. mighty impressed!
                        Daniel S
                        Daniel,
                        Works great for endpoints but if you place the protactor on edges and drag it dosen´t lock in the exact point you start the operation. Is like the protactor slips. The same happens if you place the protactor on a face and drag.
                        Thank you for adding this option!!!
                        Daniel S
                        • fredo6F
                          of course.
                          Sorry for that
                          Lib6Protractor.rb
                            Daniel S
                            The protactor still slips for me.
                            Daniel S
                            • fredo6F
                              Daniel S
                              Re-sorry.
                              I guess this is better now
                              Lib6Protractor.rb
                                Is it possible to use the radial Bending only for "slicer" a volume without to bend?
                                If yes how?
                                If I click (start end) a "straight line" along an edge nothing append when release the protractor without bending 😳
                                • fredo6F
                                  If yes how?
                                  I had the idea to isolate the slicer as a separate tool (then in 3 directions). so at least one requestor.
                                  In between, you have one in SketchyFFD
                                  PS: If you don't bend, then nothing happens, which is the natural and intentional behavior
                                    Daniel S
                                    The latest Lib6Protractor.rb works very well like the native SU tool.
                                    Thank you Again!!!
                                    Daniel S
                                    • Jean-FrancoJ
                                      Jean-Franco
                                      Hi, Fredo I've a recurent problem after bending. See my picture.
                                      Any idea of what happens ?
                                      Jean-Franco
                                        They are still co-planar. But there is hidden lines created there. Turn on Hidden Geometry and erase the lines on that surface and you can do a regular push/pull.
                                        • fredo6F
                                          Very simple;
                                          If you show hidden geometry you'll see all the subface.
                                          In your case, you can easily clean up all those coplanar edges, and then have a surface you can push pull with the native Sketchup tool.
                                          Actually, I could have the script do the clean up of coplanar edges automatically as an option. Maybe I'll do that.
                                          • Chris FullmerC
                                            +1 for that idea.
                                            Great Plugin!
                                            • 58
                                            • 59
                                            • 8 / 59
