    [Plugin][$] FredoScale - v3.7c - 19 Aug 26
    1.2k Posts 347 Posters 3.0m Views 345 Watching
      Is it possible to specify the number of slices it does when bending?
        @dave r said:
        Ken, did you install LibFredo6 version 3.1? It is linked to in the first post of the thread.
        I think he does. He said he deleted the old version. But I suspect here is that Vista keeps a copy of the old version somewhere. I think I've heard of issues like that. Though I've never experienced it myself, I wonder if it happens when UAC is on...
          remus
          Yep, press tab when youve got the bend tool selected and change the top number, 20's usually pretty good, although you can go up to 60 if you need to.
          • kenK Offline
            ken
            Yes, I did install LibFredo6 version 3.1. However, I didn't remove all of the old program, I just renamed the directories until I was sure this version would work.
            Now, however, I did remove all of the old directories, I now have this error.
            Working my way to total victory.
            Thanks for the replies
            Ken
            • F Offline
              farukahmet
              This is just.. just... i mean... 😲 😲 😲
              • majidM Offline
                majid
                Thanx so much , very^1000 thank you Fredo πŸ‘ , and for your generosity.... very appreciated. your plugins are a BEND in sketchup path..
                yours truely , majid
                • free agentF Offline
                  free agent
                  you are a genius, i use your rubies daily and would have dropped sketchup a while ago if it wasnt for such awsome scripts, thank you.
                  a small request, could cadfather do your icons again, i liked his work with "Tools on Surface" and "BZ_Toolbar"... no offence
                  Google tisk tisk
                  http://i167.photobucket.com/albums/u143/FreeAgent84/bug.gif
                  • fredo6F Offline
                    Ken
                    Ken,
                    Do not remove or rename anything. Just install the Library LibFredo6 3.1 and FreeScale 2.0, as indicated.
                    Then, if it works, you may want to remove the folders LIBFREDO6_Dir_30 and FREESCALE_Dir_10, but it does not really matter you do it right away, as they will never be loaded.
                    • W Offline
                      wolfy
                      Fredo, you are truly amazing!! β˜€ Thanks so much for all your hard work, dedication and generosity!!!
                      • O Offline
                        otb designworks
                        awesome awesome awesome!!!
                        Fredo, if it wasn't for you, I think I would have left SU in my dust ages ago.
                        Just simply fantastic and thank you!!
                        Cheers, Chuck
                        OTB Designworks is on Youtube
                        • ely862meE Offline
                          ely862me
                          This is
                          http://www.webdeveloper.com/animations/bnifiles/dmfire.gif
                          Well done....i m still wondering what is sketchup going to become with such smart people like Fredo..
                          Thanks a lot!
                          Elisei
                          Elisei (sketchupper)
                          Come and See EliseiDesign
                          • fredo6F Offline
                            to all users
                            First of all thanks very much for your warm encouragements. Note that the reward should also go to the SU team, for the native capability of the 3D application and for the design of the API, which is quite powerful (and of course the choice of Ruby). Stretch is actually simply based on the functionality of the native Move tool, and the other deformations just rely on the capability of Sketchup to transform faces and edges when you move vertices.
                            A few remarks based on comments received:
                            1. For Bend, I would recommend that you configure the slicer with a 'negative' number. This allows to adjust automatically the number of slices based on the angle. With a small angle, you will only get a few slices. The convention is based on a 12-sides circle (360 degree). For instance "-3" corresponds to a circle of 36 edges.
                            2. The slicer is based on the Sketchup "Intersect With" functionality(to answer a question from Whaat). Unfortunately, the API method does not seem to be able to cut lonely edges. If you have some in your model, they wont be smoothly bent and could even create some geometric mess.
                            3. Plane Shear is a simple transformation, but it also 'shears' the axes of the components, so that they are no longer orthogonal. Although in most cases you do not have to bother, it might be that some scripts encounter problems with those components if they assume that the axes are orthogonal. Just in case, though I don't have any script in mind!
                            4. I forgot to mention the "Make Unique" function. All transformations manage it automatically, but again, it easy to mess up or get bugsplat with too quick Undos. So if you know for sure that you want to transform complex sets of embedded components, you can use the Make Unique function once for all.
                            5. I recommend you watch the edges generated by Bend and Twist with slicer on. By default, they are created as soft and smooth, so the surface may look smooth. It is good however to check the details to avoid late surprise. In most cases, you should avoid to deform twice the same area.
                            6. The protractor plane-lock works in Toggle mode. You do not need to keep the Shift key down. Lock is also set when pressing arrow Up, Left, Right for the axes. Arrow Down will unlock the plane.
                            7. For the Donation, there is a menu in FreeScale. So you do not need to care about the HTML file. Thanks for those who already donated. Again, the script is totally free.
                            Please do not hesitate to report bugs and problems so that I can improve the plugin for all.
                            PS: by the way, if some knows how to embed a YouTube video within a message!
                            • soloS Offline
                              I embedded the youtube video in your original post.
                              • urgenU Offline
                                urgen
                                ---Thanks!!!!! πŸ‘
                                ------Thanks!!!!! πŸ‘
                                ----------Thanks!!!!! πŸ‘ πŸ˜„
                                --pupil forever...------
                                • PixeroP Offline
                                  Pixero
                                  Fantastic!
                                  I was waiting for the bend tool and now we got the others as well.
                                  Then the stretch tool. Just wow! What a timesaver.
                                  I'm shocked at what you can do by yourself.
                                  It would be quite interesting to be a fly in the SU teams office when they see this plugin. πŸ˜‰
                                  Google team shame on you +2.
                                    sepo
                                    "1) For Bend, I would recommend that you configure the slicer with a 'negative' number. This allows to adjust automatically the number of slices based on the angle. With a small angle, you will only get a few slices. The convention is based on a 12-sides circle (360 degree). For instance "-3" corresponds to a circle of 36 edges."
                                    How do you do that? I do not seem to have any GUI. In your video there is one.
                                      1. Plane Shear is a simple transformation, but it also 'shears' the axes of the components, so that they are no longer orthogonal. Although in most cases you do not have to bother, it might be that some scripts encounter problems with those components if they assume that the axes
                                      I might be working on one at the moment. A script that generates a second cutout for cutout components so you can cut through double faced walls. I haven't checked yet, but I have a suspicion that it might not work out the position properly. So I'll see if I can account for this.
                                      • soloS Offline
                                        Hit the tab button
                                        • fredo6F Offline
                                          One thing I forgot to repeat and insist on.
                                          All transformations in FreeScale are purely geometric. So they totally ignore the behavior of Dynamic Components.
                                          I simply hope it does not mess up anything however.
                                          Personally, I have not played yet with Dynamic Components (I don't have the Pro version) and I have found nothing in the API allowing to inspect or act on such DC behaviors.
                                          Please tell me if you encounter any problem between FreeScale and Dynamic Components.
                                            sepo
                                            Cheers Solo
                                            • 58
                                            • 59
                                            • 3 / 59
