    [Plugin][$] FredoScale - v3.7c - 19 Aug 26
    1.2k Posts 347 Posters 3.2m Views 345 Watching
    • GaieusG
      This is again one of the greatest plugins, Fredo! There are so many of "one of the greates plugins" by you now that the expression is getting inflated however. 😉
      Thanks a bunch!
      • G
        Gjenio
        Your scripts are just incredible!
        Thank you Fredo
        You are great
        • T
          torben.wadlinger
          I say "Wooooooaaaaaaaahhh!"
          Google, be ashamed!
          Great job, man. Great job!
          Torben
          • K
            kwistenbiebel
            A one man development team. Wonderful!
            Google, shame on you +1
            • boofredlayB
              boofredlay
              You can change the key assignments and show more (or less) toolbar icons by modifying the settings in the FreeScale Default Parameters dialog box (the menu entry is under FreeScale, not under LibFredo6).
              To activate the slicer and divider, you also have the contextual menus.
              Got it, thank you very much for the response, and the plugin.
              • W
                wrecknball
                Wow! Just had my first cup of coffee and thought I would check to see about the "Bend" plugin. It's like christmas morning. Thanks sooooo much Fredo!
                I will give it a try and post some results. Thanks again.
                • N
                  notareal
                  Thank you. This is like Christmas!
                  • broomstickB
                    broomstick
                    this
                    is
                    utterly
                    AWESOME!
                    You are doing an incredible job. Thank you so much!
                    • soloS
                      Scripters like you are what gives the 'UP' in Sketchup. Thanks a ton for all you hard work and thoughtful rubies.
                      • kenK
                        ken
                        Thank you Fredo6
                        However, I seem to be the only one with this problem. The below jpg shows the error I recieve. I have removed the old version, still get the same error.
                        Help
                        Again thank you.
                        Ken
                        • massimoM
                          massimo Moderator
                          Thanks Fredo for this great plugin!
                            Ken, did you install LibFredo6 version 3.1? It is linked to in the first post of the thread.
                              Is it possible to specify the number of slices it does when bending?
                                I think he does. He said he deleted the old version. But I suspect here is that Vista keeps a copy of the old version somewhere. I think I've heard of issues like that. Though I've never experienced it myself, I wonder if it happens when UAC is on...
                                  remus
                                  Yep, press tab when youve got the bend tool selected and change the top number, 20's usually pretty good, although you can go up to 60 if you need to.
                                  • kenK
                                    ken
                                    Yes, I did install LibFredo6 version 3.1. However, I didn't remove all of the old program, I just renamed the directories until I was sure this version would work.
                                    Now, however, I did remove all of the old directories, I now have this error.
                                    Working my way to total victory.
                                    Thanks for the replies
                                    Ken
                                    • F
                                      farukahmet
                                      This is just.. just... i mean... 😲 😲 😲
                                      • majidM
                                        majid
                                        Thanx so much , very^1000 thank you Fredo 👍 , and for your generosity.... very appreciated. your plugins are a BEND in sketchup path..
                                        yours truely , majid
                                        • free agentF
                                          free agent
                                          you are a genius, i use your rubies daily and would have dropped sketchup a while ago if it wasnt for such awsome scripts, thank you.
                                          a small request, could cadfather do your icons again, i liked his work with "Tools on Surface" and "BZ_Toolbar"... no offence
                                          Google tisk tisk
                                          http://i167.photobucket.com/albums/u143/FreeAgent84/bug.gif
                                          • fredo6F
                                            Ken
                                            Ken,
                                            Do not remove or rename anything. Just install the Library LibFredo6 3.1 and FreeScale 2.0, as indicated.
                                            Then, if it works, you may want to remove the folders LIBFREDO6_Dir_30 and FREESCALE_Dir_10, but it does not really matter you do it right away, as they will never be loaded.
                                            • 58
                                            • 59
                                            • 3 / 59
