    [Plugin] Scale and Rotate Multiple (UPDATED Dec 22, 09)
    123 Posts 51 Posters 190.5k Views 51 Watching
    • TommyKT Offline
      TommyK
      I use this plugin almost everyday. Many thanks!
      As a "power" user, I have noticed performance issues when applying the script to lots of components. In a model with hundreds of components, it gets very sluggish indeed, and the memory usage of Sketchup goes through the roof, and sometimes ends in a bugsplat.
      I am happy to take a look and see what optimisations are possible in the ruby script, but before I do so, I should ask if you have had a go at optimisation already? Do let me know!
      Tommy
      • onzkiO Offline
        onzki
        Thanks for sharing this.. it will be very useful in my work. By the way, I have a similar need, this time multi-face scale plugin, to scale a multiple polygon/faces in one go. Is this possible? My screenshot:
        Thanks a lot!
        [/hr]Dell Alienware Area-51. SKU 2021 Pro. AutoCAD 2023. Landscape design firm
          Just transform all your faces in group or component then apply the Scale multiple! πŸ˜‰
          By Tig each face in Component
          m=Sketchup.active_model;n=m.active_entities;m.selection.to_a.each{|e|(g=n.add_group(e);g.to_component.definition.name="Face#1")if e.class==Sketchup;;Face}
          You have in the same spirit the Multiple face Offset by Remus! πŸ˜„
            potemutzu
            Thank you for a very usefull plugin
            • JQLJ Offline
              JQL
              Hi Chris,
              I know you've been busy with other things but I'd like to make a request on this plugin, if you wouldn't mind.
              I'd like it to work on a choosen axis. Right now we can choose axis, center, base or world, but they all act acording to the Z axis. It would be cool to be able to choose the X or Y axis as a base too.
              Thanks in advance,
              JoΓ£o
              www.casca.pt
              Visit us on facebook!
              • HornOxxH Offline
                HornOxx
                πŸ‘ this is a great suggestion - i join this request πŸ˜„
                never trust a skinny cook
                  You can solve that in rotate your objects before apply the script! πŸ˜‰
                  • JQLJ Offline
                    JQL
                    I know I can do that but I have 1643 individual objects that I wanted to randomly rotate.
                    They were 1643 groups all aligned to the Y axis. I could get inside each one of them and change the Y axis to become the Z axis. But I would be mad if I did that...
                    Also, I can see myself wanting to do this a LOT more times, and I think, if this plugin would allow it my life would be easier.
                    Chris, certainly has other things in his mind though, because he hasn't dealt with plugins for ages, nor showed himself up around that often, but he is still very much connected to Sketchup and probably he could take a look at the script easily.
                    If not... I'll have to deal with this kind of stuff myself or find alternatives...
                    Thanks for your attention.
                    www.casca.pt
                      Random Rotation by Sdmitch πŸ˜‰
                      • few Random Select by Tig + Scale Multiple does make the trick!
                      • JQLJ Offline
                        JQL
                        Thanks Pilou I'll try Random Rotation
                        www.casca.pt
                          tomaszdrgas
                          Does it work with sKetchup 2015.. ?
                          I installed but nothing in Extensions>Chris Fullmer Tools> I have there extended views already.. Maybe issue is only the change of "plugins" folder name to "extensions"..
                          Tomasz
                            Tomasz
                            This is an old toolset...
                            However, I are concerned about your comment regarding Plugins folder versus Extensions folder !
                            All installed extension/plugins go into your user Plugins folder.
                            The renaming of the menu item from Plugins to Extensions is not important.
                            Any code referencing the Plugins menu auto-corrects to the Extensions menu.
                            This tool appears under the Extensions > Chris Fulmer Tools submenu ???
                            https://sketchucation.com/pluginstore?pln=clf_scale_rotate_multiple gets you the RBZ...
                            Use the built-in Extensions > Installer tool to get it installed properly.
                            • E Offline
                              Einstein
                              Hey! Adding a non-uniform scale (1 axis only) would be cool!
                              But the plugin is cool anyways πŸ˜„
                              • E Offline
                                Einstein
                                And also adding a feature of remembering settings and ability to rotate horizontally and vertically.
                                If you have any plans to continue developing this great plug πŸ˜‰
                                  stuff4oleg
                                  +1 vote for doing non-uniform scale.
                                  Let me describe the purpose. I use it for making tiled texture tiling not so noticeable. For example if I have 1 wood plank texture and I create 100 plank faces and apply texture to them - this is Not very convincing. I can add some variation by using Random Select + Scale and Rotate Multiple to rotate some of the planks 180 degrees around their center points. Now tiling is less noticeable. But with Random Select + (-1 Scale X/Scale Y/Scale XY) I can have 8 different variations from a single texture! basic+3 scale variations + 180 rotated+3 its scale variations
                                    Jorgensen
                                    Hi Chris
                                    I have been using this plugin for years to add some realism to scenes. Just twisting the furniture a little....
                                    I had to upgrade to Sketchup 2020, and it seems that I can no longer install this very usefull plugin.
                                    I have tried to install via extension manager, but nothing happens 😞
                                    Am I'm doing something wrong - or does the plugin not support SU 2020?
                                    Best
                                    Jorgensen
                                    • PixeroP Offline
                                      Pixero
                                      Not sure that it works with SU2020 but my plugin Chaos does some of the same things.
                                      https://sketchucation.com/plugin/2254-chaos
                                        Jorgensen
                                        Ah thanks Pixero πŸ˜„
                                        Just tried it - and it seems to work.
                                        I just have a small problem problem - if I have some chairs standing by a table, I would like to rotate them just slightly, like -1 - +1 degree, but it seems not to work - if I enter small numbers, the objects rotate quite a lot, even if I use -1 - +1.
                                        What do I do something wrong?
                                        Jorgensen
                                        ps. thanks for linking to the chaos plugin - I think randomness is really needed to create realistic images.
                                        • E Offline
                                          Einstein
                                          Jorgensen, you are doing everything right.
                                          The plugin has a bug that rotation values are in radians instead of degrees. 1 radian is about 57.3 degrees.
                                          I posted this issue on Chaos' plugin thread but I got no answer 😞
                                          • PixeroP Offline
                                            Pixero
                                            Sorry about that.
                                            I have uploaded an updated version of Chaos.rb that hopefully have fixed the rotation problem.
                                            Chaos | SketchUcation
                                            (sketchucation.com)
                                            • 6 / 7
