    [Plugin] Scale and Rotate Multiple (UPDATED Dec 22, 09)
    123 Posts 51 Posters 208.7k Views 51 Watching
      popfunky
      THANK YOU
      • HornOxxH Offline
        HornOxx
        as always - a great tool again ! thank you
        never trust a skinny cook
        • W Offline
          wat
          thank sir
          • W Offline
            wat
            • HornOxxH Offline
              HornOxx
              once again THANK YOU! - A wonderful tool that I use almost daily
                SUNutz
                Wow! this is mind blowing. For its simplicity and effectiveness. Thanks!
                • TommyKT Offline
                  TommyK
                  I use this plugin almost everyday. Many thanks!
                  As a "power" user, I have noticed performance issues when applying the script to lots of components. In a model with hundreds of components, it gets very sluggish indeed, and the memory usage of Sketchup goes through the roof, and sometimes ends in a bugsplat.
                  I am happy to take a look and see what optimisations are possible in the ruby script, but before I do so, I should ask if you have had a go at optimisation already? Do let me know!
                  Tommy
                  • onzkiO Offline
                    onzki
                    Thanks for sharing this.. it will be very useful in my work. By the way, I have a similar need, this time multi-face scale plugin, to scale a multiple polygon/faces in one go. Is this possible? My screenshot:
                    Thanks a lot!
                    [/hr]Dell Alienware Area-51. SKU 2021 Pro. AutoCAD 2023. Landscape design firm
                      Just transform all your faces in group or component then apply the Scale multiple! πŸ˜‰
                      By Tig each face in Component
                      m=Sketchup.active_model;n=m.active_entities;m.selection.to_a.each{|e|(g=n.add_group(e);g.to_component.definition.name="Face#1")if e.class==Sketchup;;Face}
                      You have in the same spirit the Multiple face Offset by Remus! πŸ˜„
                        potemutzu
                        Thank you for a very usefull plugin
                        • JQLJ Offline
                          JQL
                          Hi Chris,
                          I know you've been busy with other things but I'd like to make a request on this plugin, if you wouldn't mind.
                          I'd like it to work on a choosen axis. Right now we can choose axis, center, base or world, but they all act acording to the Z axis. It would be cool to be able to choose the X or Y axis as a base too.
                          Thanks in advance,
                          JoΓ£o
                          www.casca.pt
                          Visit us on facebook!
                          • HornOxxH Offline
                            HornOxx
                            πŸ‘ this is a great suggestion - i join this request πŸ˜„
                              You can solve that in rotate your objects before apply the script! πŸ˜‰
                              • JQLJ Offline
                                JQL
                                I know I can do that but I have 1643 individual objects that I wanted to randomly rotate.
                                They were 1643 groups all aligned to the Y axis. I could get inside each one of them and change the Y axis to become the Z axis. But I would be mad if I did that...
                                Also, I can see myself wanting to do this a LOT more times, and I think, if this plugin would allow it my life would be easier.
                                Chris, certainly has other things in his mind though, because he hasn't dealt with plugins for ages, nor showed himself up around that often, but he is still very much connected to Sketchup and probably he could take a look at the script easily.
                                If not... I'll have to deal with this kind of stuff myself or find alternatives...
                                Thanks for your attention.
                                www.casca.pt
                                  Random Rotation by Sdmitch πŸ˜‰
                                  • few Random Select by Tig + Scale Multiple does make the trick!
                                  • JQLJ Offline
                                    JQL
                                    Thanks Pilou I'll try Random Rotation
                                    www.casca.pt
                                      tomaszdrgas
                                      Does it work with sKetchup 2015.. ?
                                      I installed but nothing in Extensions>Chris Fullmer Tools> I have there extended views already.. Maybe issue is only the change of "plugins" folder name to "extensions"..
                                      Tomasz
                                        Tomasz
                                        This is an old toolset...
                                        However, I are concerned about your comment regarding Plugins folder versus Extensions folder !
                                        All installed extension/plugins go into your user Plugins folder.
                                        The renaming of the menu item from Plugins to Extensions is not important.
                                        Any code referencing the Plugins menu auto-corrects to the Extensions menu.
                                        This tool appears under the Extensions > Chris Fulmer Tools submenu ???
                                        https://sketchucation.com/pluginstore?pln=clf_scale_rotate_multiple gets you the RBZ...
                                        Use the built-in Extensions > Installer tool to get it installed properly.
                                        • E Offline
                                          Einstein
                                          Hey! Adding a non-uniform scale (1 axis only) would be cool!
                                          But the plugin is cool anyways πŸ˜„
                                          • E Offline
                                            Einstein
                                            And also adding a feature of remembering settings and ability to rotate horizontally and vertically.
                                            If you have any plans to continue developing this great plug πŸ˜‰
                                            • 6 / 7
