    [Plugin] Recall last tool v1.2
    60 Posts 28 Posters 62.2k Views 28 Watching
      Matt666
      Hi Rick!
      Thank you for the comment, I've updated the code... πŸ˜‰
      Frenglish at its best !
      My scripts
      • EarthMoverE Offline
        EarthMover
        Hey Matt - You are eternally my friend! Thanks for listening to my request. I'm sure it will be useful to many!
        Content Creator at Skapeup
          Matt666
          πŸ˜‰
          My scripts
            Astucieux! 😎
              Matt666
              Merci Pilou πŸ˜‰
              My scripts
              • EdsonE Offline
                Edson
                matt,
                here we go again. unless i do not know how to use your new script, it is not working on mac! sorry...
                http://www.mahfuz.arq.br
                  Matt666
                  Hi Edson... I hope you do not know!! I'm cursed...
                  So : Draw a . Draw a . Press space bar for .
                  Go to Plugins/Recall last tool. Rectangle tool is now recalled.
                  If it does not work, can you open your ruby console, and try again, please?
                  And, at last, can you call rectangle tool, and try to copy this code in the ruby console ?
                  Sketchup.send_action(21022)
                  This code calls selection tool.
                  Thank you Edson. And sorry for the inconvenience.
                  My scripts
                  • EdsonE Offline
                    Edson
                    matt,
                    it did not work. i had done it that way before. below is the ruby console reading.
                    glad to help you. keep your requests coming.
                    • BurkhardB Offline
                      Burkhard
                      I read a lot /users/mahfuz... πŸ˜‰
                      http://www.ia-plus.de
                        pecan
                        On differenct OS's, even the same OS with different menus, that magic number will have changed.
                        What's wrong with Sketchup.send_action(selectSelectionTool:);
                        When the menu structure is updated, then the call will still work even tho the menu id has changed.
                        • simon le bonS Offline
                          simon le bon
                          Bravo Matt !!
                          at the very beginning of my learning SketchUp, I was surprised not to have this feature at disposal. And then I was accustomed to always recall my tools. And Here comes your ruby. It is as if suddenly we had won a great lightness. (F2 is great)
                          it already belongs to my toolbox. πŸ‘ πŸ‘ πŸ˜„simon
                            Matt666
                            Merci Simon ! πŸ˜‰
                            @pecan said:
                            On different OS's, even the same OS with different menus, that magic number will have changed.
                            Hi pecan! Are you sure of that? I use only two different numbers in my code. The rest is a recall of the last number used.
                            But there's a biiig problem with Mac... On Mac, function "send_action" does not accept integers. Only strings! 😞
                            @edson said:
                            It did not work. i had done it that way before. below is the ruby console reading.
                            Thank you Edson!
                            Ouch. I will try to find a solution. Can you test this code below, please?
                            Sketchup.send_action("21022")
                            My scripts
                            • EdsonE Offline
                              Edson
                              it looks good!
                                Matt666
                                Ok. But if you have rectangle tool called, when you copy and validate the code, is the selection tool activated?
                                My scripts
                                • EdsonE Offline
                                  Edson
                                  i drew a rectangle, then pressed the space bar, then used the script from the menu. the result is in the picture.
                                    Matt666
                                    Sorry Edson, and all mac users. But I can't do anything with this bug. 😞 Function 'send_action' doesn't accept integers (so tool IDs) on Mac.
                                    My scripts
                                      pecan
                                      Result from SU ruby console
                                      (eval)
                                      result = Sketchup.send_action "selectSelectionTool:"
                                      true
                                      I was in error suggesting it was a num.
                                        pecan
                                        Using the tool name should work:
                                        def onActiveToolChanged (tools_object, toolname, toolid)
                                                print tools_object, toolname, toolid
                                        		@@Matt_Model_Toolid = @@Matt_Model_Toolid2 if @@Matt_Model_Toolid2
                                        		#@@Matt_Model_Toolid2 = toolid if not([21022,10508].index toolid)
                                        		@@Matt_Model_Toolid2 = "select#{toolname};";
                                        		puts "1; #{@@Matt_Model_Toolid} 2; #{@@Matt_Model_Toolid2}"
                                          pecan
                                          > 	end
                                          Well... almost.
                                          "selectCameraOrbitTool:" doesnt work.
                                          It's action name is simply OrbitTool.
                                          So maybe a hash of returned tool names and the send_action name.
                                          sendActionToolName = {"CameraOrbitTool", "OrbitTool", } etc.
                                          Or maybe a hash of just the exceptions.
                                          Its a shame SU has to be so inconsistent.
                                            pecan
                                            Here's a list of the send_actions and the actual tool name returned by the observer.
                                            howRubyPanel;
                                            viewBack;
                                            viewBottom;
                                            viewFront;
                                            viewIso;
                                            viewLeft;
                                            viewRight;
                                            viewTop;
                                            viewPerspective;
                                            viewShowAxes;
                                            viewShowHidden;
                                            viewZoomExtents;
                                            viewZoomToSelection;
                                            viewUndo;
                                            selectOrbitTool; (CameraOrbitTool)
                                                ok  selectPositionCameraTool;
                                            selectDollyTool; (CameraDollyTool
                                            selectTurnTool;
                                            selectWalkTool; (CameraWalkTool)
                                            selectZoomTool; (CameraZoomTool)
                                            selectFieldOfViewTool; (CameraFOVTool) <=== inconsistency
                                            selectZoomWindowTool; (CameraZoomWindowTool)
                                            pageAdd;
                                            pageDelete;
                                            pageUpdate;
                                            pageNext;
                                            pagePrevious;
                                            renderWireframe;
                                            renderHiddenLine;
                                            renderMonochrome&#058;
                                            renderShaded;
                                            renderTextures;
                                                ok  selectArcTool;
                                            selectAxisTool; (SketchCSTool)
                                                ok  selectCircleTool;
                                                ok selectEraseTool;
                                                ok  selectFreehandTool;
                                            selectLineTool; (SketchTool)
                                                ok  selectMeasureTool;
                                                ok  selectMoveTool;
                                                ok  selectOffsetTool;
                                                ok  selectPaintTool;
                                            selectPolygonTool; (PolyTool)
                                                ok  selectProtractorTool;
                                                ok  selectPushPullTool;
                                                ok  selectRectangleTool;
                                                ok  selectRotateTool;
                                                ok  selectScaleTool;
                                                ok  selectSectionPlaneTool;
                                                ok  selectTextTool;
                                                ok  selectDimensionTool;
                                                ok  selectExtrudeTool;
                                                ok  selectSelectionTool;
                                            editUndo;
                                            editRedo;
                                            editHide;
                                            editUnhide;
                                            fixNonPlanarFaces;
                                            axes is returning SketchCSTool
                                            3d text is returning 3DTextTool
                                            plugins return RubyTool
                                            orbit return CameraOrbitTool
                                            pan returns CameraDollyTool
                                            zoom returns CameraZoomTool
                                            field of view returns CameraFDVTool
                                            zoom window returns CameraFOVTool
                                            zoom extends return CameraZoomWindowTool
                                            walk return CamerWalkTool
                                            look returns CameraPanTool
                                            line returns selectSketchTool
                                            Except for "selectFieldOfViewTool: (CameraFOVTool)" you can remove "Camera" from the observer reported name and prefix "select".
                                            Special cases are PolyTool, Line tool, and axis tool.
                                            On second thought, a hash like {reportedObserverName, sendSelectName} might be the best bet.
                                            • 1 / 3
