    [Plugin] Recall last tool v1.2
    60 Posts 28 Posters 62.5k Views 28 Watching
    • EarthMoverE Offline
      EarthMover
      Hey Matt - You are eternally my friend! Thanks for listening to my request. I'm sure it will be useful to many!
      Content Creator at Skapeup
        Matt666
        πŸ˜‰
        Frenglish at its best !
        My scripts
          Astucieux! 😎
            Matt666
            Merci Pilou πŸ˜‰
            My scripts
            • EdsonE Offline
              Edson
              matt,
              here we go again. unless i do not know how to use your new script, it is not working on mac! sorry...
              http://www.mahfuz.arq.br
                Matt666
                Hi Edson... I hope you do not know!! I'm cursed...
                So : Draw a . Draw a . Press space bar for .
                Go to Plugins/Recall last tool. Rectangle tool is now recalled.
                If it does not work, can you open your ruby console, and try again, please?
                And, at last, can you call rectangle tool, and try to copy this code in the ruby console ?
                Sketchup.send_action(21022)
                This code calls selection tool.
                Thank you Edson. And sorry for the inconvenience.
                My scripts
                • EdsonE Offline
                  Edson
                  matt,
                  it did not work. i had done it that way before. below is the ruby console reading.
                  glad to help you. keep your requests coming.
                  • BurkhardB Offline
                    Burkhard
                    I read a lot /users/mahfuz... πŸ˜‰
                    http://www.ia-plus.de
                      pecan
                      On differenct OS's, even the same OS with different menus, that magic number will have changed.
                      What's wrong with Sketchup.send_action(selectSelectionTool:);
                      When the menu structure is updated, then the call will still work even tho the menu id has changed.
                      • simon le bonS Offline
                        simon le bon
                        Bravo Matt !!
                        at the very beginning of my learning SketchUp, I was surprised not to have this feature at disposal. And then I was accustomed to always recall my tools. And Here comes your ruby. It is as if suddenly we had won a great lightness. (F2 is great)
                        it already belongs to my toolbox. πŸ‘ πŸ‘ πŸ˜„simon
                          Matt666
                          Merci Simon ! πŸ˜‰
                          @pecan said:
                          On different OS's, even the same OS with different menus, that magic number will have changed.
                          Hi pecan! Are you sure of that? I use only two different numbers in my code. The rest is a recall of the last number used.
                          But there's a biiig problem with Mac... On Mac, function "send_action" does not accept integers. Only strings! 😞
                          @edson said:
                          It did not work. i had done it that way before. below is the ruby console reading.
                          Thank you Edson!
                          Ouch. I will try to find a solution. Can you test this code below, please?
                          Sketchup.send_action("21022")
                          My scripts
                          • EdsonE Offline
                            Edson
                            it looks good!
                              Matt666
                              Ok. But if you have rectangle tool called, when you copy and validate the code, is the selection tool activated?
                              My scripts
                              • EdsonE Offline
                                Edson
                                i drew a rectangle, then pressed the space bar, then used the script from the menu. the result is in the picture.
                                  Matt666
                                  Sorry Edson, and all mac users. But I can't do anything with this bug. 😞 Function 'send_action' doesn't accept integers (so tool IDs) on Mac.
                                  My scripts
                                    pecan
                                    Result from SU ruby console
                                    (eval)
                                    result = Sketchup.send_action "selectSelectionTool:"
                                    true
                                    I was in error suggesting it was a num.
                                      pecan
                                      Using the tool name should work:
                                      def onActiveToolChanged (tools_object, toolname, toolid)
                                              print tools_object, toolname, toolid
                                      		@@Matt_Model_Toolid = @@Matt_Model_Toolid2 if @@Matt_Model_Toolid2
                                      		#@@Matt_Model_Toolid2 = toolid if not([21022,10508].index toolid)
                                      		@@Matt_Model_Toolid2 = "select#{toolname};";
                                      		puts "1; #{@@Matt_Model_Toolid} 2; #{@@Matt_Model_Toolid2}"
                                        pecan
                                        > 	end
                                        Well... almost.
                                        "selectCameraOrbitTool:" doesnt work.
                                        It's action name is simply OrbitTool.
                                        So maybe a hash of returned tool names and the send_action name.
                                        sendActionToolName = {"CameraOrbitTool", "OrbitTool", } etc.
                                        Or maybe a hash of just the exceptions.
                                        Its a shame SU has to be so inconsistent.
                                          pecan
                                          Here's a list of the send_actions and the actual tool name returned by the observer.
                                          howRubyPanel;
                                          viewBack;
                                          viewBottom;
                                          viewFront;
                                          viewIso;
                                          viewLeft;
                                          viewRight;
                                          viewTop;
                                          viewPerspective;
                                          viewShowAxes;
                                          viewShowHidden;
                                          viewZoomExtents;
                                          viewZoomToSelection;
                                          viewUndo;
                                          selectOrbitTool; (CameraOrbitTool)
                                              ok  selectPositionCameraTool;
                                          selectDollyTool; (CameraDollyTool
                                          selectTurnTool;
                                          selectWalkTool; (CameraWalkTool)
                                          selectZoomTool; (CameraZoomTool)
                                          selectFieldOfViewTool; (CameraFOVTool) <=== inconsistency
                                          selectZoomWindowTool; (CameraZoomWindowTool)
                                          pageAdd;
                                          pageDelete;
                                          pageUpdate;
                                          pageNext;
                                          pagePrevious;
                                          renderWireframe;
                                          renderHiddenLine;
                                          renderMonochrome&#058;
                                          renderShaded;
                                          renderTextures;
                                              ok  selectArcTool;
                                          selectAxisTool; (SketchCSTool)
                                              ok  selectCircleTool;
                                              ok selectEraseTool;
                                              ok  selectFreehandTool;
                                          selectLineTool; (SketchTool)
                                              ok  selectMeasureTool;
                                              ok  selectMoveTool;
                                              ok  selectOffsetTool;
                                              ok  selectPaintTool;
                                          selectPolygonTool; (PolyTool)
                                              ok  selectProtractorTool;
                                              ok  selectPushPullTool;
                                              ok  selectRectangleTool;
                                              ok  selectRotateTool;
                                              ok  selectScaleTool;
                                              ok  selectSectionPlaneTool;
                                              ok  selectTextTool;
                                              ok  selectDimensionTool;
                                              ok  selectExtrudeTool;
                                              ok  selectSelectionTool;
                                          editUndo;
                                          editRedo;
                                          editHide;
                                          editUnhide;
                                          fixNonPlanarFaces;
                                          axes is returning SketchCSTool
                                          3d text is returning 3DTextTool
                                          plugins return RubyTool
                                          orbit return CameraOrbitTool
                                          pan returns CameraDollyTool
                                          zoom returns CameraZoomTool
                                          field of view returns CameraFDVTool
                                          zoom window returns CameraFOVTool
                                          zoom extends return CameraZoomWindowTool
                                          walk return CamerWalkTool
                                          look returns CameraPanTool
                                          line returns selectSketchTool
                                          Except for "selectFieldOfViewTool: (CameraFOVTool)" you can remove "Camera" from the observer reported name and prefix "select".
                                          Special cases are PolyTool, Line tool, and axis tool.
                                          On second thought, a hash like {reportedObserverName, sendSelectName} might be the best bet.
                                            pecan
                                            The following seems to work, and you can add to the exceptions hash when you find 'em.
                                            Hope this helps some...
                                            # Supports Organizer.rb
                                            =begin
                                            Copyright 2009, Matt
                                            All Rights Reserved
                                            THIS SOFTWARE IS PROVIDED "AS IS" AND WITHOUT ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, WITHOUT LIMITATION,
                                            THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE.
                                            License;   Free
                                            Author;     	Matthieu NOBLET
                                            Organization;   Matt
                                            Name;      		Recall_lst_tool
                                            Version;   		1.0
                                            SU Version;   	6 and 7
                                            Date;      		17/02/2009
                                            Description;   	Recall last tool used
                                            Usage;      	If you want to have a shortcut, please try with native Sketchup shortcuts...
                                            History;
                                            	1.000   17/02/2009
                                            			First version
                                            	1.100	17/02/2009
                                            			Global variables replaced by Class variables
                                            =end
                                            require 'sketchup.rb'
                                            class Matt_Observer < Sketchup;;ToolsObserver
                                                def initialize
                                                    @ToolExceptionsHash = {
                                                       # observerName    send_actionName
                                                        "FOVTool",       "FieldOfViewTool",
                                                        "SketchCSTool",  "AxisTool",
                                                        "SketchTool",    "LineTool",
                                                        "PolyTool",      "PolygonTool"
                                            	@@Matt_Model_Toolid = nil
                                            	@@Matt_Model_Toolid2 = nil
                                                    print tools_object, " ", toolname, " ", toolid, "\n"
                                                    tname = toolname;
                                            		# remove "Camera" prefix reported by ToolObserver"
                                            		@@Matt_Model_Toolid2 = (tname[0,6]="" if (tname[0,6] == "Camera"));
                                            		tname = @ToolExceptionsHash.fetch(tname, tname);
                                            		@@Matt_Model_Toolid2 = "select#{tname};";
                                            	def self.recall_last
                                                    puts "sending action #{@@Matt_Model_Toolid}" if @@Matt_Model_Toolid
                                            		return Sketchup.send_action(@@Matt_Model_Toolid) if @@Matt_Model_Toolid
                                            		return Sketchup.send_action("selectSelectionTool;")
                                            unless file_loaded?(__FILE__)
                                               file_loaded(__FILE__)
                                               Sketchup.active_model.tools.add_observer(Matt_Observer.new)
                                               $submenu ? (organizer = $submenu) ; (organizer = UI.menu("Plugins"))
                                               organizer.add_item("Recall last tool"){ Matt_Observer.recall_last }
                                            • 1 / 3
