    How to pause a ruby script for 1 second
    25 Posts 5 Posters 6.4k Views 5 Watching
      AlexMozg
      And it is possible and so:
      def self.timer(proc, time_limit=0.5)
      $val_time = Time.now
      $timer = UI.start_timer(0, true) do
         if Time.now - $val_time >= time_limit
            UI.stop_timer $timer
            proc.call
            $val_time = $timer = nil
      select_comp_by_name("Fahrstuhl")
      Morisdov.transf_get("transf2")
      self.timer(proc{Sketchup.active_model.selection.clear})
      Though it is possible to do without global variables.
      But, I do not know that Morisdov.transf_get does.
      • N
        N Lindenthal
        def self.timer(proc, time_limit=0.9)
              proc.call
        With 0.9 it works for exactly one time, each next start lets Sketchup crash down.
        With 0.2 SketchUp crashes immediately.
        I think I have to ask Morisdov by PM.
          AlexMozg
          Ask me, and I shall try to answer.
          • N
            N Lindenthal
            @alexmozg said:
            … Ask me, and I shall try to answer.
            Here is my »Fahrstuhl«, english elevator.
            My script selects the "Fahrstuhl“, puts it to another position (here position 1 and 2), and then clears the selection:
            Morisdov.transf_get("transf1")
            UI.start_timer(1, false) {Sketchup.active_model.selection.clear}
            Position 1
            Position 2
            To get the script work, the following .rbs must be installed:
            1. select_com_by_name.rb
            def select_comp_by_name(comp_name)
            	model = Sketchup.active_model
            	sel = model.selection
            	sel.clear
            	if compdef = Sketchup.active_model.definitions[comp_name]
            		sel.add(compdef.instances)
            	else
            		Sketchup.active_model.active_entities.each do |d|
            			if d.typename == "ComponentInstance"
            			sel.add d if d.name==comp_name
            		if sel.count == 0
            			UI.beep
            		else
            			UI.messagebox(sel.count.to_s + " gesuchte Dinger gefunden.")
            1. proper_animation.rb
            My question is, how to select the "Fahrstuhl/elevator" without selection marks.
            So I tried to use the following script:
            def self.timer(proc, time_limit=1)
                  proc.call
            Would be a wonder to get the arrows in model be buttons, which start the elevator scripts.
            Fahrstuhl = Elevator
              AlexMozg
              The simplest - to make changes to a script "Morisdov".
              Somehow here so:
              def Morisdov.transf_get(dict_key, ss=nil)
                model=Sketchup.active_model
                ents=model.active_entities
                 if ss
                   @ents = ss
                 else
                   @ents=[]
                   model.selection.each {|e| @ents.push(e)}
                @ents.freeze
              And completely to get rid from selection.
              Where I can find "following.rbs"?
              I shall think...
              • N
                N Lindenthal
                @alexmozg said:
                …And completely to get rid from selection.
                I shall think...
                Yes, rid from selection …
                … but how? This way?
                   if ss
                     @ents = ss
                   else
                     @ents=[]
                  @ents.freeze
                (my poor english) Which "following.rbs" you need?
                  AlexMozg
                        sel = compdef.instances
                     else
                        sel=[]
                           sel << d if d.name==comp_name
                        if sel.count == 0
                           UI.beep
                        else
                  sel
                     if ss
                       @ents = ss
                     else
                       @ents=[]
                    @ents.freeze
                    ...<<original code>>...
                  Use:
                  1. ss = select_comp_by_name("Fahrstuhl")
                  2. Morisdov.transf_get(dict_key, ss)
                  Here this:
                  ...Position 2
                  • Chris FullmerC
                    I know this is old, but I was needing an answer to something similar today, and this thread over-complexificated the issue for me. I just wanted to add a short .2 second delay before carrying on with my script. This is what I've come up with and it worked for me. No need to invoke the UI.timer
                    time_mark = ( Time.now + 0.2 )
                    while time_mark > Time.now
                    Hopefully thats helpful if anyone stumbles on this thread,
                    • tbdT
                      tbd
                      Chris: i hope your code is called only by the user and not in an Observer or right click menus, because it will stop Ruby thread and if you call this several times it will block a lot of things.
                      http://plugins.ro
                      • Chris FullmerC
                        Ahh, I see. I think its ok in this instance to stop up ruby entirely. I was having very little luck getting it to work any other way. I just kept sending SU into a deeep coma.
                        Maybe I'll try to post my broken code using the timer and try to get that working instead then. Thanks Tavi,
                        • 2 / 2
