    How to pause a ruby script for 1 second
    25 Posts 5 Posters 6.4k Views 5 Watching
    • N
      N Lindenthal
      Yes, TDB, that I could know myself. Excuse me, please.
      @Jim
      Your times are the same with me.
      How can I get ==> 0.5 or ==> 0.99?
      Mac OS X 10.4.11
      • tbdT
        tbd
        yup. my bad. I checked only visual and didnt do any time checks.
        seems that it ignores decimals (0.1...0.9 = 0, 1.1 ... 1.9 = 1) - so we need to use that. for interface like clear selection doesnt matter that much anyway
        http://plugins.ro
        • N
          N Lindenthal
          To pause is a workaround. Would be better to ask how long
          Morisdov.transf_get("transf2")
          works and then clear without pause/delay.
          Can ruby know how long the earlier line works?
            AlexMozg
            Here such variant:
            time_limit = 0.2
            @val_time = Time.now
            @timer = UI.start_timer(0, true) do
            	if Time.now - @val_time >= time_limit
            		UI.stop_timer @timer
            		Sketchup.active_model.selection.clear
            		@val_time = @timer = nil
            It works 😄
            • N
              N Lindenthal
              @AlexMozg
              Unfortunately it does not work, if this line is before
              Please try with proper_animation.rb and one selected component with Position 2
              time_limit = 0.2
              The selected component will stay selected.
              • tbdT
                tbd
                welcome to thread synchronization fun - as you can see Morisdov.transf_get uses start_timer
                so you need to sync with that (e.g. add global variable in transf_get end for example)
                http://plugins.ro
                • N
                  N Lindenthal
                  How?
                  • tbdT
                    tbd
                    btw, did you increased time_limit from AlexMozg example first ? to like 5 ?
                    http://plugins.ro
                      AlexMozg
                      And it is possible and so:
                      def self.timer(proc, time_limit=0.5)
                      $val_time = Time.now
                      $timer = UI.start_timer(0, true) do
                         if Time.now - $val_time >= time_limit
                            UI.stop_timer $timer
                            proc.call
                            $val_time = $timer = nil
                      select_comp_by_name("Fahrstuhl")
                      self.timer(proc{Sketchup.active_model.selection.clear})
                      Though it is possible to do without global variables.
                      But, I do not know that Morisdov.transf_get does.
                      • N
                        N Lindenthal
                        def self.timer(proc, time_limit=0.9)
                              proc.call
                        With 0.9 it works for exactly one time, each next start lets Sketchup crash down.
                        With 0.2 SketchUp crashes immediately.
                        I think I have to ask Morisdov by PM.
                          AlexMozg
                          Ask me, and I shall try to answer.
                          • N
                            N Lindenthal
                            @alexmozg said:
                            … Ask me, and I shall try to answer.
                            Here is my »Fahrstuhl«, english elevator.
                            My script selects the "Fahrstuhl“, puts it to another position (here position 1 and 2), and then clears the selection:
                            Morisdov.transf_get("transf1")
                            UI.start_timer(1, false) {Sketchup.active_model.selection.clear}
                            Position 1
                            Position 2
                            To get the script work, the following .rbs must be installed:
                            1. select_com_by_name.rb
                            def select_comp_by_name(comp_name)
                            	model = Sketchup.active_model
                            	sel = model.selection
                            	sel.clear
                            	if compdef = Sketchup.active_model.definitions[comp_name]
                            		sel.add(compdef.instances)
                            	else
                            		Sketchup.active_model.active_entities.each do |d|
                            			if d.typename == "ComponentInstance"
                            			sel.add d if d.name==comp_name
                            		if sel.count == 0
                            			UI.beep
                            		else
                            			UI.messagebox(sel.count.to_s + " gesuchte Dinger gefunden.")
                            1. proper_animation.rb
                            My question is, how to select the "Fahrstuhl/elevator" without selection marks.
                            So I tried to use the following script:
                            def self.timer(proc, time_limit=1)
                                  proc.call
                            Would be a wonder to get the arrows in model be buttons, which start the elevator scripts.
                            Fahrstuhl = Elevator
                              AlexMozg
                              The simplest - to make changes to a script "Morisdov".
                              Somehow here so:
                              def Morisdov.transf_get(dict_key, ss=nil)
                                model=Sketchup.active_model
                                ents=model.active_entities
                                 if ss
                                   @ents = ss
                                 else
                                   @ents=[]
                                   model.selection.each {|e| @ents.push(e)}
                                @ents.freeze
                              And completely to get rid from selection.
                              Where I can find "following.rbs"?
                              I shall think...
                              • N
                                N Lindenthal
                                @alexmozg said:
                                …And completely to get rid from selection.
                                I shall think...
                                Yes, rid from selection …
                                … but how? This way?
                                   if ss
                                     @ents = ss
                                   else
                                     @ents=[]
                                  @ents.freeze
                                (my poor english) Which "following.rbs" you need?
                                  AlexMozg
                                        sel = compdef.instances
                                     else
                                        sel=[]
                                           sel << d if d.name==comp_name
                                        if sel.count == 0
                                           UI.beep
                                        else
                                  sel
                                     if ss
                                       @ents = ss
                                     else
                                       @ents=[]
                                    @ents.freeze
                                    ...<<original code>>...
                                  Use:
                                  1. ss = select_comp_by_name("Fahrstuhl")
                                  2. Morisdov.transf_get(dict_key, ss)
                                  Here this:
                                  ...Position 2
                                  • Chris FullmerC
                                    I know this is old, but I was needing an answer to something similar today, and this thread over-complexificated the issue for me. I just wanted to add a short .2 second delay before carrying on with my script. This is what I've come up with and it worked for me. No need to invoke the UI.timer
                                    time_mark = ( Time.now + 0.2 )
                                    while time_mark > Time.now
                                    Hopefully thats helpful if anyone stumbles on this thread,
                                    • tbdT
                                      tbd
                                      Chris: i hope your code is called only by the user and not in an Observer or right click menus, because it will stop Ruby thread and if you call this several times it will block a lot of things.
                                      http://plugins.ro
                                      • Chris FullmerC
                                        Ahh, I see. I think its ok in this instance to stop up ruby entirely. I was having very little luck getting it to work any other way. I just kept sending SU into a deeep coma.
                                        Maybe I'll try to post my broken code using the timer and try to get that working instead then. Thanks Tavi,
