    How to pause a ruby script for 1 second
    25 Posts 5 Posters 6.4k Views 5 Watching
    • N
      N Lindenthal
      To pause is a workaround. Would be better to ask how long
      Morisdov.transf_get("transf2")
      works and then clear without pause/delay.
      Can ruby know how long the earlier line works?
        AlexMozg
        Here such variant:
        time_limit = 0.2
        @val_time = Time.now
        @timer = UI.start_timer(0, true) do
        	if Time.now - @val_time >= time_limit
        		UI.stop_timer @timer
        		Sketchup.active_model.selection.clear
        		@val_time = @timer = nil
        It works 😄
        • N
          N Lindenthal
          @AlexMozg
          Unfortunately it does not work, if this line is before
          Please try with proper_animation.rb and one selected component with Position 2
          time_limit = 0.2
          The selected component will stay selected.
          • tbdT
            tbd
            welcome to thread synchronization fun - as you can see Morisdov.transf_get uses start_timer
            so you need to sync with that (e.g. add global variable in transf_get end for example)
            http://plugins.ro
            • N
              N Lindenthal
              How?
              • tbdT
                tbd
                btw, did you increased time_limit from AlexMozg example first ? to like 5 ?
                http://plugins.ro
                  AlexMozg
                  And it is possible and so:
                  def self.timer(proc, time_limit=0.5)
                  $val_time = Time.now
                  $timer = UI.start_timer(0, true) do
                     if Time.now - $val_time >= time_limit
                        UI.stop_timer $timer
                        proc.call
                        $val_time = $timer = nil
                  select_comp_by_name("Fahrstuhl")
                  self.timer(proc{Sketchup.active_model.selection.clear})
                  Though it is possible to do without global variables.
                  But, I do not know that Morisdov.transf_get does.
                  • N
                    N Lindenthal
                    def self.timer(proc, time_limit=0.9)
                          proc.call
                    With 0.9 it works for exactly one time, each next start lets Sketchup crash down.
                    With 0.2 SketchUp crashes immediately.
                    I think I have to ask Morisdov by PM.
                      AlexMozg
                      Ask me, and I shall try to answer.
                      • N
                        N Lindenthal
                        @alexmozg said:
                        … Ask me, and I shall try to answer.
                        Here is my »Fahrstuhl«, english elevator.
                        My script selects the "Fahrstuhl“, puts it to another position (here position 1 and 2), and then clears the selection:
                        Morisdov.transf_get("transf1")
                        UI.start_timer(1, false) {Sketchup.active_model.selection.clear}
                        Position 1
                        Position 2
                        To get the script work, the following .rbs must be installed:
                        1. select_com_by_name.rb
                        def select_comp_by_name(comp_name)
                        	model = Sketchup.active_model
                        	sel = model.selection
                        	sel.clear
                        	if compdef = Sketchup.active_model.definitions[comp_name]
                        		sel.add(compdef.instances)
                        	else
                        		Sketchup.active_model.active_entities.each do |d|
                        			if d.typename == "ComponentInstance"
                        			sel.add d if d.name==comp_name
                        		if sel.count == 0
                        			UI.beep
                        		else
                        			UI.messagebox(sel.count.to_s + " gesuchte Dinger gefunden.")
                        1. proper_animation.rb
                        My question is, how to select the "Fahrstuhl/elevator" without selection marks.
                        So I tried to use the following script:
                        def self.timer(proc, time_limit=1)
                              proc.call
                        Would be a wonder to get the arrows in model be buttons, which start the elevator scripts.
                        Fahrstuhl = Elevator
                          AlexMozg
                          The simplest - to make changes to a script "Morisdov".
                          Somehow here so:
                          def Morisdov.transf_get(dict_key, ss=nil)
                            model=Sketchup.active_model
                            ents=model.active_entities
                             if ss
                               @ents = ss
                             else
                               @ents=[]
                               model.selection.each {|e| @ents.push(e)}
                            @ents.freeze
                          And completely to get rid from selection.
                          Where I can find "following.rbs"?
                          I shall think...
                          • N
                            N Lindenthal
                            @alexmozg said:
                            …And completely to get rid from selection.
                            I shall think...
                            Yes, rid from selection …
                            … but how? This way?
                               if ss
                                 @ents = ss
                               else
                                 @ents=[]
                              @ents.freeze
                            (my poor english) Which "following.rbs" you need?
                              AlexMozg
                                    sel = compdef.instances
                                 else
                                    sel=[]
                                       sel << d if d.name==comp_name
                                    if sel.count == 0
                                       UI.beep
                                    else
                              sel
                                 if ss
                                   @ents = ss
                                 else
                                   @ents=[]
                                @ents.freeze
                                ...<<original code>>...
                              Use:
                              1. ss = select_comp_by_name("Fahrstuhl")
                              2. Morisdov.transf_get(dict_key, ss)
                              Here this:
                              ...Position 2
                              • Chris FullmerC
                                I know this is old, but I was needing an answer to something similar today, and this thread over-complexificated the issue for me. I just wanted to add a short .2 second delay before carrying on with my script. This is what I've come up with and it worked for me. No need to invoke the UI.timer
                                time_mark = ( Time.now + 0.2 )
                                while time_mark > Time.now
                                Hopefully thats helpful if anyone stumbles on this thread,
                                • tbdT
                                  tbd
                                  Chris: i hope your code is called only by the user and not in an Observer or right click menus, because it will stop Ruby thread and if you call this several times it will block a lot of things.
                                  http://plugins.ro
                                  • Chris FullmerC
                                    Ahh, I see. I think its ok in this instance to stop up ruby entirely. I was having very little luck getting it to work any other way. I just kept sending SU into a deeep coma.
                                    Maybe I'll try to post my broken code using the timer and try to get that working instead then. Thanks Tavi,
