    How to pause a ruby script for 1 second
    25 Posts 5 Posters 6.3k Views 5 Watching
    • N Offline
      N Lindenthal
      @AlexMozg
      Unfortunately it does not work, if this line is before
      Morisdov.transf_get("transf2")
      Please try with proper_animation.rb and one selected component with Position 2
      time_limit = 0.2
      @val_time = Time.now
      @timer = UI.start_timer(0, true) do
         if Time.now - @val_time >= time_limit
            UI.stop_timer @timer
            Sketchup.active_model.selection.clear
            @val_time = @timer = nil
      The selected component will stay selected.
      • tbdT Offline
        tbd
        welcome to thread synchronization fun - as you can see Morisdov.transf_get uses start_timer
        so you need to sync with that (e.g. add global variable in transf_get end for example)
        http://plugins.ro
        • N Offline
          N Lindenthal
          How?
          • tbdT Offline
            tbd
            btw, did you increased time_limit from AlexMozg example first ? to like 5 ?
            http://plugins.ro
              AlexMozg
              And it is possible and so:
              def self.timer(proc, time_limit=0.5)
              $val_time = Time.now
              $timer = UI.start_timer(0, true) do
                 if Time.now - $val_time >= time_limit
                    UI.stop_timer $timer
                    proc.call
                    $val_time = $timer = nil
              select_comp_by_name("Fahrstuhl")
              self.timer(proc{Sketchup.active_model.selection.clear})
              Though it is possible to do without global variables.
              But, I do not know that Morisdov.transf_get does.
              • N Offline
                N Lindenthal
                def self.timer(proc, time_limit=0.9)
                      proc.call
                With 0.9 it works for exactly one time, each next start lets Sketchup crash down.
                With 0.2 SketchUp crashes immediately.
                I think I have to ask Morisdov by PM.
                  AlexMozg
                  Ask me, and I shall try to answer.
                  • N Offline
                    N Lindenthal
                    @alexmozg said:
                    … Ask me, and I shall try to answer.
                    Here is my »Fahrstuhl«, english elevator.
                    My script selects the "Fahrstuhl“, puts it to another position (here position 1 and 2), and then clears the selection:
                    Morisdov.transf_get("transf1")
                    UI.start_timer(1, false) {Sketchup.active_model.selection.clear}
                    Position 1
                    Position 2
                    To get the script work, the following .rbs must be installed:
                    1. select_com_by_name.rb
                    def select_comp_by_name(comp_name)
                    	model = Sketchup.active_model
                    	sel = model.selection
                    	sel.clear
                    	if compdef = Sketchup.active_model.definitions[comp_name]
                    		sel.add(compdef.instances)
                    	else
                    		Sketchup.active_model.active_entities.each do |d|
                    			if d.typename == "ComponentInstance"
                    			sel.add d if d.name==comp_name
                    		if sel.count == 0
                    			UI.beep
                    		else
                    			UI.messagebox(sel.count.to_s + " gesuchte Dinger gefunden.")
                    1. proper_animation.rb
                    My question is, how to select the "Fahrstuhl/elevator" without selection marks.
                    So I tried to use the following script:
                    def self.timer(proc, time_limit=1)
                          proc.call
                    Would be a wonder to get the arrows in model be buttons, which start the elevator scripts.
                    Fahrstuhl = Elevator
                      AlexMozg
                      The simplest - to make changes to a script "Morisdov".
                      Somehow here so:
                      def Morisdov.transf_get(dict_key, ss=nil)
                        model=Sketchup.active_model
                        ents=model.active_entities
                         if ss
                           @ents = ss
                         else
                           @ents=[]
                           model.selection.each {|e| @ents.push(e)}
                        @ents.freeze
                      And completely to get rid from selection.
                      Where I can find "following.rbs"?
                      I shall think...
                      • N Offline
                        N Lindenthal
                        @alexmozg said:
                        …And completely to get rid from selection.
                        I shall think...
                        Yes, rid from selection …
                        … but how? This way?
                           if ss
                             @ents = ss
                           else
                             @ents=[]
                          @ents.freeze
                        (my poor english) Which "following.rbs" you need?
                          AlexMozg
                                sel = compdef.instances
                             else
                                sel=[]
                                   sel << d if d.name==comp_name
                                if sel.count == 0
                                   UI.beep
                                else
                          sel
                             if ss
                               @ents = ss
                             else
                               @ents=[]
                            @ents.freeze
                            ...<<original code>>...
                          Use:
                          1. ss = select_comp_by_name("Fahrstuhl")
                          2. Morisdov.transf_get(dict_key, ss)
                          Here this:
                          ...Position 2
                          • Chris FullmerC Offline
                            I know this is old, but I was needing an answer to something similar today, and this thread over-complexificated the issue for me. I just wanted to add a short .2 second delay before carrying on with my script. This is what I've come up with and it worked for me. No need to invoke the UI.timer
                            time_mark = ( Time.now + 0.2 )
                            while time_mark > Time.now
                            Hopefully thats helpful if anyone stumbles on this thread,
                            • tbdT Offline
                              tbd
                              Chris: i hope your code is called only by the user and not in an Observer or right click menus, because it will stop Ruby thread and if you call this several times it will block a lot of things.
                              http://plugins.ro
                                Ahh, I see. I think its ok in this instance to stop up ruby entirely. I was having very little luck getting it to work any other way. I just kept sending SU into a deeep coma.
                                Maybe I'll try to post my broken code using the timer and try to get that working instead then. Thanks Tavi,
                                • 2 / 2
