    How to pause a ruby script for 1 second
    25 Posts 5 Posters 5.7k Views 5 Watching
      AlexMozg
      Here such variant:
      time_limit = 0.2
      @val_time = Time.now
      @timer = UI.start_timer(0, true) do
      	if Time.now - @val_time >= time_limit
      		UI.stop_timer @timer
      		Sketchup.active_model.selection.clear
      		@val_time = @timer = nil
      It works 😄
      • N Offline
        N Lindenthal
        @AlexMozg
        Unfortunately it does not work, if this line is before
        Morisdov.transf_get("transf2")
        Please try with proper_animation.rb and one selected component with Position 2
        time_limit = 0.2
        The selected component will stay selected.
        • tbdT Offline
          tbd
          welcome to thread synchronization fun - as you can see Morisdov.transf_get uses start_timer
          so you need to sync with that (e.g. add global variable in transf_get end for example)
          http://plugins.ro
          • N Offline
            N Lindenthal
            How?
            • tbdT Offline
              tbd
              btw, did you increased time_limit from AlexMozg example first ? to like 5 ?
              http://plugins.ro
                AlexMozg
                And it is possible and so:
                def self.timer(proc, time_limit=0.5)
                $val_time = Time.now
                $timer = UI.start_timer(0, true) do
                   if Time.now - $val_time >= time_limit
                      UI.stop_timer $timer
                      proc.call
                      $val_time = $timer = nil
                select_comp_by_name("Fahrstuhl")
                self.timer(proc{Sketchup.active_model.selection.clear})
                Though it is possible to do without global variables.
                But, I do not know that Morisdov.transf_get does.
                • N Offline
                  N Lindenthal
                  def self.timer(proc, time_limit=0.9)
                        proc.call
                  With 0.9 it works for exactly one time, each next start lets Sketchup crash down.
                  With 0.2 SketchUp crashes immediately.
                  I think I have to ask Morisdov by PM.
                    AlexMozg
                    Ask me, and I shall try to answer.
                    • N Offline
                      N Lindenthal
                      @alexmozg said:
                      … Ask me, and I shall try to answer.
                      Here is my »Fahrstuhl«, english elevator.
                      My script selects the "Fahrstuhl“, puts it to another position (here position 1 and 2), and then clears the selection:
                      Morisdov.transf_get("transf1")
                      UI.start_timer(1, false) {Sketchup.active_model.selection.clear}
                      Position 1
                      Position 2
                      To get the script work, the following .rbs must be installed:
                      1. select_com_by_name.rb
                      def select_comp_by_name(comp_name)
                      	model = Sketchup.active_model
                      	sel = model.selection
                      	sel.clear
                      	if compdef = Sketchup.active_model.definitions[comp_name]
                      		sel.add(compdef.instances)
                      	else
                      		Sketchup.active_model.active_entities.each do |d|
                      			if d.typename == "ComponentInstance"
                      			sel.add d if d.name==comp_name
                      		if sel.count == 0
                      			UI.beep
                      		else
                      			UI.messagebox(sel.count.to_s + " gesuchte Dinger gefunden.")
                      1. proper_animation.rb
                      My question is, how to select the "Fahrstuhl/elevator" without selection marks.
                      So I tried to use the following script:
                      def self.timer(proc, time_limit=1)
                            proc.call
                      Would be a wonder to get the arrows in model be buttons, which start the elevator scripts.
                      Fahrstuhl = Elevator
                        AlexMozg
                        The simplest - to make changes to a script "Morisdov".
                        Somehow here so:
                        def Morisdov.transf_get(dict_key, ss=nil)
                          model=Sketchup.active_model
                          ents=model.active_entities
                           if ss
                             @ents = ss
                           else
                             @ents=[]
                             model.selection.each {|e| @ents.push(e)}
                          @ents.freeze
                        And completely to get rid from selection.
                        Where I can find "following.rbs"?
                        I shall think...
                        • N Offline
                          N Lindenthal
                          @alexmozg said:
                          …And completely to get rid from selection.
                          I shall think...
                          Yes, rid from selection …
                          … but how? This way?
                             if ss
                               @ents = ss
                             else
                               @ents=[]
                            @ents.freeze
                          (my poor english) Which "following.rbs" you need?
                            AlexMozg
                                  sel = compdef.instances
                               else
                                  sel=[]
                                     sel << d if d.name==comp_name
                                  if sel.count == 0
                                     UI.beep
                                  else
                            sel
                               if ss
                                 @ents = ss
                               else
                                 @ents=[]
                              @ents.freeze
                              ...<<original code>>...
                            Use:
                            1. ss = select_comp_by_name("Fahrstuhl")
                            2. Morisdov.transf_get(dict_key, ss)
                            Here this:
                            ...Position 2
                            • Chris FullmerC Offline
                              I know this is old, but I was needing an answer to something similar today, and this thread over-complexificated the issue for me. I just wanted to add a short .2 second delay before carrying on with my script. This is what I've come up with and it worked for me. No need to invoke the UI.timer
                              time_mark = ( Time.now + 0.2 )
                              while time_mark > Time.now
                              Hopefully thats helpful if anyone stumbles on this thread,
                              • tbdT Offline
                                tbd
                                Chris: i hope your code is called only by the user and not in an Observer or right click menus, because it will stop Ruby thread and if you call this several times it will block a lot of things.
                                http://plugins.ro
                                  Ahh, I see. I think its ok in this instance to stop up ruby entirely. I was having very little luck getting it to work any other way. I just kept sending SU into a deeep coma.
                                  Maybe I'll try to post my broken code using the timer and try to get that working instead then. Thanks Tavi,
