    How to pause a ruby script for 1 second
    25 Posts 5 Posters 6.4k Views 5 Watching
    • tbdT
      tbd
      yup. my bad. I checked only visual and didnt do any time checks.
      seems that it ignores decimals (0.1...0.9 = 0, 1.1 ... 1.9 = 1) - so we need to use that. for interface like clear selection doesnt matter that much anyway
      http://plugins.ro
      • N
        N Lindenthal
        To pause is a workaround. Would be better to ask how long
        Morisdov.transf_get("transf2")
        works and then clear without pause/delay.
        Can ruby know how long the earlier line works?
          AlexMozg
          Here such variant:
          time_limit = 0.2
          @val_time = Time.now
          @timer = UI.start_timer(0, true) do
          	if Time.now - @val_time >= time_limit
          		UI.stop_timer @timer
          		Sketchup.active_model.selection.clear
          		@val_time = @timer = nil
          It works 😄
          • N
            N Lindenthal
            @AlexMozg
            Unfortunately it does not work, if this line is before
            Please try with proper_animation.rb and one selected component with Position 2
            time_limit = 0.2
            The selected component will stay selected.
            • tbdT
              tbd
              welcome to thread synchronization fun - as you can see Morisdov.transf_get uses start_timer
              so you need to sync with that (e.g. add global variable in transf_get end for example)
              http://plugins.ro
              • N
                N Lindenthal
                How?
                • tbdT
                  tbd
                  btw, did you increased time_limit from AlexMozg example first ? to like 5 ?
                  http://plugins.ro
                    AlexMozg
                    And it is possible and so:
                    def self.timer(proc, time_limit=0.5)
                    $val_time = Time.now
                    $timer = UI.start_timer(0, true) do
                       if Time.now - $val_time >= time_limit
                          UI.stop_timer $timer
                          proc.call
                          $val_time = $timer = nil
                    select_comp_by_name("Fahrstuhl")
                    self.timer(proc{Sketchup.active_model.selection.clear})
                    Though it is possible to do without global variables.
                    But, I do not know that Morisdov.transf_get does.
                    • N
                      N Lindenthal
                      def self.timer(proc, time_limit=0.9)
                            proc.call
                      With 0.9 it works for exactly one time, each next start lets Sketchup crash down.
                      With 0.2 SketchUp crashes immediately.
                      I think I have to ask Morisdov by PM.
                        AlexMozg
                        Ask me, and I shall try to answer.
                        • N
                          N Lindenthal
                          @alexmozg said:
                          … Ask me, and I shall try to answer.
                          Here is my »Fahrstuhl«, english elevator.
                          My script selects the "Fahrstuhl“, puts it to another position (here position 1 and 2), and then clears the selection:
                          Morisdov.transf_get("transf1")
                          UI.start_timer(1, false) {Sketchup.active_model.selection.clear}
                          Position 1
                          Position 2
                          To get the script work, the following .rbs must be installed:
                          1. select_com_by_name.rb
                          def select_comp_by_name(comp_name)
                          	model = Sketchup.active_model
                          	sel = model.selection
                          	sel.clear
                          	if compdef = Sketchup.active_model.definitions[comp_name]
                          		sel.add(compdef.instances)
                          	else
                          		Sketchup.active_model.active_entities.each do |d|
                          			if d.typename == "ComponentInstance"
                          			sel.add d if d.name==comp_name
                          		if sel.count == 0
                          			UI.beep
                          		else
                          			UI.messagebox(sel.count.to_s + " gesuchte Dinger gefunden.")
                          1. proper_animation.rb
                          My question is, how to select the "Fahrstuhl/elevator" without selection marks.
                          So I tried to use the following script:
                          def self.timer(proc, time_limit=1)
                                proc.call
                          Would be a wonder to get the arrows in model be buttons, which start the elevator scripts.
                          Fahrstuhl = Elevator
                            AlexMozg
                            The simplest - to make changes to a script "Morisdov".
                            Somehow here so:
                            def Morisdov.transf_get(dict_key, ss=nil)
                              model=Sketchup.active_model
                              ents=model.active_entities
                               if ss
                                 @ents = ss
                               else
                                 @ents=[]
                                 model.selection.each {|e| @ents.push(e)}
                              @ents.freeze
                            And completely to get rid from selection.
                            Where I can find "following.rbs"?
                            I shall think...
                            • N
                              N Lindenthal
                              @alexmozg said:
                              …And completely to get rid from selection.
                              I shall think...
                              Yes, rid from selection …
                              … but how? This way?
                                 if ss
                                   @ents = ss
                                 else
                                   @ents=[]
                                @ents.freeze
                              (my poor english) Which "following.rbs" you need?
                                AlexMozg
                                      sel = compdef.instances
                                   else
                                      sel=[]
                                         sel << d if d.name==comp_name
                                      if sel.count == 0
                                         UI.beep
                                      else
                                sel
                                   if ss
                                     @ents = ss
                                   else
                                     @ents=[]
                                  @ents.freeze
                                  ...<<original code>>...
                                Use:
                                1. ss = select_comp_by_name("Fahrstuhl")
                                2. Morisdov.transf_get(dict_key, ss)
                                Here this:
                                ...Position 2
                                • Chris FullmerC
                                  I know this is old, but I was needing an answer to something similar today, and this thread over-complexificated the issue for me. I just wanted to add a short .2 second delay before carrying on with my script. This is what I've come up with and it worked for me. No need to invoke the UI.timer
                                  time_mark = ( Time.now + 0.2 )
                                  while time_mark > Time.now
                                  Hopefully thats helpful if anyone stumbles on this thread,
                                  • tbdT
                                    tbd
                                    Chris: i hope your code is called only by the user and not in an Observer or right click menus, because it will stop Ruby thread and if you call this several times it will block a lot of things.
                                    http://plugins.ro
                                    • Chris FullmerC
                                      Ahh, I see. I think its ok in this instance to stop up ruby entirely. I was having very little luck getting it to work any other way. I just kept sending SU into a deeep coma.
                                      Maybe I'll try to post my broken code using the timer and try to get that working instead then. Thanks Tavi,
