    How to pause a ruby script for 1 second
    25 Posts 5 Posters 6.6k Views 5 Watching
    • tbdT
      tbd
      of course, ==> means what it should return and you must not type that
      http://plugins.ro
      • N
        N Lindenthal
        Yes, TDB, that I could know myself. Excuse me, please.
        @Jim
        Your times are the same with me.
        How can I get ==> 0.5 or ==> 0.99?
        Mac OS X 10.4.11
        • tbdT
          tbd
          yup. my bad. I checked only visual and didnt do any time checks.
          seems that it ignores decimals (0.1...0.9 = 0, 1.1 ... 1.9 = 1) - so we need to use that. for interface like clear selection doesnt matter that much anyway
          http://plugins.ro
          • N
            N Lindenthal
            To pause is a workaround. Would be better to ask how long
            Morisdov.transf_get("transf2")
            works and then clear without pause/delay.
            Can ruby know how long the earlier line works?
              AlexMozg
              Here such variant:
              time_limit = 0.2
              @val_time = Time.now
              @timer = UI.start_timer(0, true) do
              	if Time.now - @val_time >= time_limit
              		UI.stop_timer @timer
              		Sketchup.active_model.selection.clear
              		@val_time = @timer = nil
              It works 😄
              • N
                N Lindenthal
                @AlexMozg
                Unfortunately it does not work, if this line is before
                Please try with proper_animation.rb and one selected component with Position 2
                time_limit = 0.2
                The selected component will stay selected.
                • tbdT
                  tbd
                  welcome to thread synchronization fun - as you can see Morisdov.transf_get uses start_timer
                  so you need to sync with that (e.g. add global variable in transf_get end for example)
                  http://plugins.ro
                  • N
                    N Lindenthal
                    How?
                    • tbdT
                      tbd
                      btw, did you increased time_limit from AlexMozg example first ? to like 5 ?
                      http://plugins.ro
                        AlexMozg
                        And it is possible and so:
                        def self.timer(proc, time_limit=0.5)
                        $val_time = Time.now
                        $timer = UI.start_timer(0, true) do
                           if Time.now - $val_time >= time_limit
                              UI.stop_timer $timer
                              proc.call
                              $val_time = $timer = nil
                        select_comp_by_name("Fahrstuhl")
                        self.timer(proc{Sketchup.active_model.selection.clear})
                        Though it is possible to do without global variables.
                        But, I do not know that Morisdov.transf_get does.
                        • N
                          N Lindenthal
                          def self.timer(proc, time_limit=0.9)
                                proc.call
                          With 0.9 it works for exactly one time, each next start lets Sketchup crash down.
                          With 0.2 SketchUp crashes immediately.
                          I think I have to ask Morisdov by PM.
                            AlexMozg
                            Ask me, and I shall try to answer.
                            • N
                              N Lindenthal
                              @alexmozg said:
                              … Ask me, and I shall try to answer.
                              Here is my »Fahrstuhl«, english elevator.
                              My script selects the "Fahrstuhl“, puts it to another position (here position 1 and 2), and then clears the selection:
                              Morisdov.transf_get("transf1")
                              UI.start_timer(1, false) {Sketchup.active_model.selection.clear}
                              Position 1
                              Position 2
                              To get the script work, the following .rbs must be installed:
                              1. select_com_by_name.rb
                              def select_comp_by_name(comp_name)
                              	model = Sketchup.active_model
                              	sel = model.selection
                              	sel.clear
                              	if compdef = Sketchup.active_model.definitions[comp_name]
                              		sel.add(compdef.instances)
                              	else
                              		Sketchup.active_model.active_entities.each do |d|
                              			if d.typename == "ComponentInstance"
                              			sel.add d if d.name==comp_name
                              		if sel.count == 0
                              			UI.beep
                              		else
                              			UI.messagebox(sel.count.to_s + " gesuchte Dinger gefunden.")
                              1. proper_animation.rb
                              My question is, how to select the "Fahrstuhl/elevator" without selection marks.
                              So I tried to use the following script:
                              def self.timer(proc, time_limit=1)
                                    proc.call
                              Would be a wonder to get the arrows in model be buttons, which start the elevator scripts.
                              Fahrstuhl = Elevator
                                AlexMozg
                                The simplest - to make changes to a script "Morisdov".
                                Somehow here so:
                                def Morisdov.transf_get(dict_key, ss=nil)
                                  model=Sketchup.active_model
                                  ents=model.active_entities
                                   if ss
                                     @ents = ss
                                   else
                                     @ents=[]
                                     model.selection.each {|e| @ents.push(e)}
                                  @ents.freeze
                                And completely to get rid from selection.
                                Where I can find "following.rbs"?
                                I shall think...
                                • N
                                  N Lindenthal
                                  @alexmozg said:
                                  …And completely to get rid from selection.
                                  I shall think...
                                  Yes, rid from selection …
                                  … but how? This way?
                                     if ss
                                       @ents = ss
                                     else
                                       @ents=[]
                                    @ents.freeze
                                  (my poor english) Which "following.rbs" you need?
                                    AlexMozg
                                          sel = compdef.instances
                                       else
                                          sel=[]
                                             sel << d if d.name==comp_name
                                          if sel.count == 0
                                             UI.beep
                                          else
                                    sel
                                       if ss
                                         @ents = ss
                                       else
                                         @ents=[]
                                      @ents.freeze
                                      ...<<original code>>...
                                    Use:
                                    1. ss = select_comp_by_name("Fahrstuhl")
                                    2. Morisdov.transf_get(dict_key, ss)
                                    Here this:
                                    ...Position 2
                                    • Chris FullmerC
                                      I know this is old, but I was needing an answer to something similar today, and this thread over-complexificated the issue for me. I just wanted to add a short .2 second delay before carrying on with my script. This is what I've come up with and it worked for me. No need to invoke the UI.timer
                                      time_mark = ( Time.now + 0.2 )
                                      while time_mark > Time.now
                                      Hopefully thats helpful if anyone stumbles on this thread,
                                      • tbdT
                                        tbd
                                        Chris: i hope your code is called only by the user and not in an Observer or right click menus, because it will stop Ruby thread and if you call this several times it will block a lot of things.
                                        http://plugins.ro
                                        • Chris FullmerC
                                          Ahh, I see. I think its ok in this instance to stop up ruby entirely. I was having very little luck getting it to work any other way. I just kept sending SU into a deeep coma.
                                          Maybe I'll try to post my broken code using the timer and try to get that working instead then. Thanks Tavi,
