    How to pause a ruby script for 1 second
    25 Posts 5 Posters 6.2k Views 5 Watching
    • tbdT Offline
      tbd
      btw, did you increased time_limit from AlexMozg example first ? to like 5 ?
      http://plugins.ro
        AlexMozg
        And it is possible and so:
        def self.timer(proc, time_limit=0.5)
        $val_time = Time.now
        $timer = UI.start_timer(0, true) do
           if Time.now - $val_time >= time_limit
              UI.stop_timer $timer
              proc.call
              $val_time = $timer = nil
        select_comp_by_name("Fahrstuhl")
        Morisdov.transf_get("transf2")
        self.timer(proc{Sketchup.active_model.selection.clear})
        Though it is possible to do without global variables.
        But, I do not know that Morisdov.transf_get does.
        • N Offline
          N Lindenthal
          def self.timer(proc, time_limit=0.9)
                proc.call
          With 0.9 it works for exactly one time, each next start lets Sketchup crash down.
          With 0.2 SketchUp crashes immediately.
          I think I have to ask Morisdov by PM.
            AlexMozg
            Ask me, and I shall try to answer.
            • N Offline
              N Lindenthal
              @alexmozg said:
              … Ask me, and I shall try to answer.
              Here is my »Fahrstuhl«, english elevator.
              My script selects the "Fahrstuhl“, puts it to another position (here position 1 and 2), and then clears the selection:
              Morisdov.transf_get("transf1")
              UI.start_timer(1, false) {Sketchup.active_model.selection.clear}
              Position 1
              Position 2
              To get the script work, the following .rbs must be installed:
              1. select_com_by_name.rb
              def select_comp_by_name(comp_name)
              	model = Sketchup.active_model
              	sel = model.selection
              	sel.clear
              	if compdef = Sketchup.active_model.definitions[comp_name]
              		sel.add(compdef.instances)
              	else
              		Sketchup.active_model.active_entities.each do |d|
              			if d.typename == "ComponentInstance"
              			sel.add d if d.name==comp_name
              		if sel.count == 0
              			UI.beep
              		else
              			UI.messagebox(sel.count.to_s + " gesuchte Dinger gefunden.")
              1. proper_animation.rb
              My question is, how to select the "Fahrstuhl/elevator" without selection marks.
              So I tried to use the following script:
              def self.timer(proc, time_limit=1)
                    proc.call
              Would be a wonder to get the arrows in model be buttons, which start the elevator scripts.
              Fahrstuhl = Elevator
                AlexMozg
                The simplest - to make changes to a script "Morisdov".
                Somehow here so:
                def Morisdov.transf_get(dict_key, ss=nil)
                  model=Sketchup.active_model
                  ents=model.active_entities
                   if ss
                     @ents = ss
                   else
                     @ents=[]
                     model.selection.each {|e| @ents.push(e)}
                  @ents.freeze
                And completely to get rid from selection.
                Where I can find "following.rbs"?
                I shall think...
                • N Offline
                  N Lindenthal
                  @alexmozg said:
                  …And completely to get rid from selection.
                  I shall think...
                  Yes, rid from selection …
                  … but how? This way?
                     if ss
                       @ents = ss
                     else
                       @ents=[]
                    @ents.freeze
                  (my poor english) Which "following.rbs" you need?
                    AlexMozg
                          sel = compdef.instances
                       else
                          sel=[]
                             sel << d if d.name==comp_name
                          if sel.count == 0
                             UI.beep
                          else
                    sel
                       if ss
                         @ents = ss
                       else
                         @ents=[]
                      @ents.freeze
                      ...<<original code>>...
                    Use:
                    1. ss = select_comp_by_name("Fahrstuhl")
                    2. Morisdov.transf_get(dict_key, ss)
                    Here this:
                    ...Position 2
                    • Chris FullmerC Offline
                      I know this is old, but I was needing an answer to something similar today, and this thread over-complexificated the issue for me. I just wanted to add a short .2 second delay before carrying on with my script. This is what I've come up with and it worked for me. No need to invoke the UI.timer
                      time_mark = ( Time.now + 0.2 )
                      while time_mark > Time.now
                      Hopefully thats helpful if anyone stumbles on this thread,
                      • tbdT Offline
                        tbd
                        Chris: i hope your code is called only by the user and not in an Observer or right click menus, because it will stop Ruby thread and if you call this several times it will block a lot of things.
                        http://plugins.ro
                          Ahh, I see. I think its ok in this instance to stop up ruby entirely. I was having very little luck getting it to work any other way. I just kept sending SU into a deeep coma.
                          Maybe I'll try to post my broken code using the timer and try to get that working instead then. Thanks Tavi,
                          • 2 / 2
