    [TUTORIAL]: texturing organic form (subsmooth)
    36 Posts 17 Posters 20.8k Views 17 Watching
      Click Draw
      What is your preferrance for a rendering program. I'd like to get as much feedback and opinions as possible before I layout the money.
      Jeff
      Have I mentioned how much of a laugh I get out of some of the Signatures on here!
        I don't really render too much (no time to learn it well).I used Podium and Kerkythea (a bit more this latter one). It is free and Podium also has a free version with images limited to 500x500 pixels.
        Indigo is also free.
          Click Draw
          Good stuff! Thanks
          Jeff
          • W Offline
            wheay
            wow! i want to learn this. since im using vray and loving its rendering capability. i want to learn the grass thing, it really amazed me. hope more tutorials on this.
            "i try to learn everyday"
            http://designerslandmark.blogspot.com/
              Click Draw
              Hey wheay,
              Do you know of a better tutorial than the one on the Vray site? I'd like to learn what the settings are for and so on. Thanks...
              Jeff
                krowka_smieszka
                kwistenbiebel how did u make this organic shape? I know that may be silly question but I am still learning how to use sketchup...
                • soloS Offline
                  Krowka, hope this helps, it's a very crude and fast example, Biebel's shape is cleaner.
                  [flash=600,400:3gn1ftdy]http://vimeo.com/moogaloop.swf?clip_id=2335698&server=vimeo.com&show_title=1&show_byline=1&show_portrait=0&color=00ADEF&fullscreen=1[/flash:3gn1ftdy]
                  Displaced with ecosystem in Vue:
                  http://img81.imageshack.us/img81/938/biebelshapefu4.jpg
                    Click Draw
                    Very cool Solo....how about doing a tut to show how to displace with Vray? Don't make me bag....cause I will! 😄
                    • soloS Offline
                      Jeff, I would like to help with V-ray but my trial has ended and I had a choice between v-ray and Vue and I'm sure you know who won. I am sure once Kwistenbiebel gets settled into Oz he will get one going, after all this is his turf. 😉
                        Click Draw
                        No worries....I'm sure he'll show us mower 🤣
                          tulacong
                          thank you very much.I wan it
                            krowka_smieszka
                            Thank u for video solo... i see that i need get some plugins 😒
                              berbay
                              How do you scale the texture that you have applied on that surface?? anyone can help me?
                              • massimoM Offline
                                massimo Moderator
                                Right click on the surface-->entity info-->click on the material's thumbnail-->edit. Or pick the material with the eyedropper, then go to the material panel-->edit.
                                  Aerilius
                                  you can (unfortunately) only edit a projected texture's positioning on the same face from where you projected it or from a parallel face.
                                  That means:
                                  Either you have to remember where the red-dashed triangle (second image) was - or, better, you project the texture from a face outside of that organic shape (like an image) and then you just hide this "helper face" and don't delete it. Keep it in the same group like the organic shape. Later you can right-click on that "helper face" and move, rotate and skew the texture; then project it again on the organic shape.
                                    berbay
                                    oh ok it works like that!! thank you…. but i could do it if the material is not from sketchup. for vismat materials I couldnt do.
                                    and Aerilius thanks for your reply, it seemed pretty advanced for me, but I will try…
                                    i opened a new post for the scene i am working on… the materials I use are vismats and i dont know how to control them yet... 😕
                                    http://forums.sketchucation.com/viewtopic.php?f=18&t=40824
                                    • andrea.biancoA Offline
                                      andrea.bianco
                                      Thanks a lot for the tip, it's very useful indeed.
                                      Andrea A. Bianco
                                      http://www.andreabianco.eu
                                      HW: i7 3.8GHz | nVidia GTX590 3GB | 8GB RAM
                                      SW: SketchUp, Octane, Adobe CC, Painter, Windows 8.1 64
                                      • 2 / 2
