    [TUTORIAL]: texturing organic form (subsmooth)
    36 Posts 17 Posters 20.3k Views 17 Watching
      krowka_smieszka
      kwistenbiebel how did u make this organic shape? I know that may be silly question but I am still learning how to use sketchup...
      • soloS Offline
        Krowka, hope this helps, it's a very crude and fast example, Biebel's shape is cleaner.
        [flash=600,400:3gn1ftdy]http://vimeo.com/moogaloop.swf?clip_id=2335698&server=vimeo.com&show_title=1&show_byline=1&show_portrait=0&color=00ADEF&fullscreen=1[/flash:3gn1ftdy]
        Displaced with ecosystem in Vue:
        http://img81.imageshack.us/img81/938/biebelshapefu4.jpg
          Click Draw
          Very cool Solo....how about doing a tut to show how to displace with Vray? Don't make me bag....cause I will! 😄
          Have I mentioned how much of a laugh I get out of some of the Signatures on here!
          • soloS Offline
            Jeff, I would like to help with V-ray but my trial has ended and I had a choice between v-ray and Vue and I'm sure you know who won. I am sure once Kwistenbiebel gets settled into Oz he will get one going, after all this is his turf. 😉
              Click Draw
              No worries....I'm sure he'll show us mower 🤣
                tulacong
                thank you very much.I wan it
                  krowka_smieszka
                  Thank u for video solo... i see that i need get some plugins 😒
                    berbay
                    How do you scale the texture that you have applied on that surface?? anyone can help me?
                    • massimoM Offline
                      massimo Moderator
                      Right click on the surface-->entity info-->click on the material's thumbnail-->edit. Or pick the material with the eyedropper, then go to the material panel-->edit.
                        Aerilius
                        you can (unfortunately) only edit a projected texture's positioning on the same face from where you projected it or from a parallel face.
                        That means:
                        Either you have to remember where the red-dashed triangle (second image) was - or, better, you project the texture from a face outside of that organic shape (like an image) and then you just hide this "helper face" and don't delete it. Keep it in the same group like the organic shape. Later you can right-click on that "helper face" and move, rotate and skew the texture; then project it again on the organic shape.
                          berbay
                          oh ok it works like that!! thank you…. but i could do it if the material is not from sketchup. for vismat materials I couldnt do.
                          and Aerilius thanks for your reply, it seemed pretty advanced for me, but I will try…
                          i opened a new post for the scene i am working on… the materials I use are vismats and i dont know how to control them yet... 😕
                          http://forums.sketchucation.com/viewtopic.php?f=18&t=40824
                          • andrea.biancoA Offline
                            andrea.bianco
                            Thanks a lot for the tip, it's very useful indeed.
                            Andrea A. Bianco
                            http://www.andreabianco.eu
                            HW: i7 3.8GHz | nVidia GTX590 3GB | 8GB RAM
                            SW: SketchUp, Octane, Adobe CC, Painter, Windows 8.1 64
                            • 2 / 2
