    [Plugin] Simple Glazing tool
    19 Posts 9 Posters 17.4k Views 9 Watching
    • T
      tomot
      Jim I don't know what I'm going to do with that piece of information
      in a practical way to solve this problem.
      As the attached pic shows, at present the glazing is flush with each face
      of the 2 opening the glazing is installed into.
      I would like to have the option of letting the user pick an offset back from
      the face as is shown in the opening on the left side of the cube.
      my plugins
      tomot
        Jim
        Well, you know the normal of the glass, just move the group forward or backward along the normal.
        In other words, apply a transformation to the final group in the + or - direction along the base face normal.
          Aren't you re-inventing Windowizer without a frame ? Currently you must enter something, but 0.1mm makes the frames effectively nothing...
            dtrarch
            tomot
            Very clever tool and thanks.
            As it creates a group it is very easy to move back and forth.
            Good enough as it stands.
            dtr
            • T
              tomot
              Not at all! Windowizer asks for 4 sided face to be selected first. While I use the "pick 3 point rectangle" method.
              This is not a criticism of how Windowizer works, it has more to do with my workflow.
              I design structures in SU using walls and slabs that have thickness. Then I punch openings in them for windows, doors, stairs etc., later I fill in those openings with the required components.
              I find the "pick 3 points rectangle' method the most natural way to fill in an opening. If I were to use Windowizer, I have to fill in the opening prior to running the script.
              However, I would be more interested in getting the setback problem solved.
              While Jim's comments make a lot of sense, I can't get the code to work.
              aargh!
              my plugins
              tomot
              • T
                tomot
                @dtrarch said:
                tomot
                dtr
                Thanks! But after I have moved about 30 windows back 3" from the face. I
                feel like my Grey matter is leaving for greener pastures.
                my plugins
                tomot
                  Jim
                  Hi tomot,
                  Here is a snippet of your plugin with the transformation.
                      base.pushpull $ggthick
                      self.reset
                      normal = base.normal
                      normal.length = 2 # how far?
                      tr = Geom;;Transformation.translation(normal.reverse)
                      group.transform! tr
                      model.commit_operation
                  • T
                    tomot
                    Jim, please accept my great appreciation, with a reply HUG!
                    so here is the the attached update:
                    WindowGlass.rb
                    my plugins
                    tomot
                    • N
                      nomeradona
                      clever and useful indeed.. thanks
                      • FletchF
                        Fletch
                        I asked a long time ago for windowizer to have ability to have "0" as the frame, and have it be left out completely... but all I remember getting was a "good idea Fletch"... while never seeing it implemented... I'm still waiting.
                        until then... this could be useful - thanks for sharing!... and true about the workflow... sometime nice to just draw interactively.
                        Fletch
                          RickW
                          @fletch: Yeah, unfortunately, that happens a lot more than I would like. More ideas than time to implement...
                          RickW
                          www.smustard.com
                            JGA
                            Tomat, thanks very much for the tool.
                            RickW, Windowizer is one of the most useful tools available. However, could it be adapted to provide an inner frame of a window? I currently push pull through the wall, repair the faces & then use windowizer on both sides of the wall.
                            Regards,
                            JGA
                            • T
                              tomot
                              Yes I have a working copy, with glazing, frame and exterior trim however, I still have
                              a few bugs to resolve, before posting it.
                              my plugins
                              tomot
                              • FletchF
                                Fletch
                                @Rick,
                                ah well... c'est la vie... 😄
                                Fletch
                                • T
                                  tomot
                                  @fletch said:
                                  @Rick,
                                  In fairness to RickW, he has produced some amazing code.
                                  I think he was the first one to create a dialog box in Ruby.
                                  Without which all input Rubies could not exist.
                                  my plugins
                                  tomot
