    [Plugin] Simple Glazing tool
    19 Posts 9 Posters 17.3k Views 9 Watching
      tomot
      I see no ruby gurus willing to take a nibble yet? 😄
      Once the rectangle has been picked, its co-ordinates are defined
      by $pt0 thru $pt3 (see below)
      #------create a new set of points from the original 3 point pick
      $pt0=Geom::Point3d.new($pts[0][0], $pts[0][1], $pts[0][2])
      $pt1=Geom::Point3d.new($pts[1][0], $pts[1][1], $pts[1][2])
      $pt2=Geom::Point3d.new($pts[2][0], $pts[2][1], $pts[2][2])
      $pt3=Geom::Point3d.new($pts[3][0], $pts[3][1], $pts[3][2])
      I can then create the required code that makes the glazing,
      give it a transparent color, followed by "pushpull'ing" the thickness of the glass
      whose value is $ggthick (see below)
      #------create the Glazing
      group=entities.add_group
      entities=group.entities
      base=entities.add_face($pt0, $pt1, $pt2, $pt3)
      base.material=Sketchup::Color.new(163,204,204) #change the RGB Color numbers here
      base.material.alpha = 0.6
      base.pushpull $ggthick
      All of the above will produce glazing in any plane xy, xz, yz.
      However in order to set the glazing back from an xy plane, I need a z offset
      equally for glazing on an xz plane needs a y offset, and for glazing on an yz plane
      requires an x offset.
      If I was producing a static glazing ruby where the glazing was always located at 0,0,0
      then I could provide the offset option via $wwthick which is the "Glass Setback from face value.
      as follows:
      $pt3=Geom::Point3d.new($pts[3][0], $pts[3][1], $pts[3][2]-$wwthick)
      but this will not work for the other 2 planes.
      Is there a 3d point in Ruby that is not tied to the world co-ordinate system, but rather
      to a local co-ordinate system?
      or is there a way to do a double pushpull one for the offset and one for the glazing thickness,
      and then erasing the first sheet of glass?
      TIA!
      my plugins
      tomot
        Jim
        Entities added to a group are relative to the Group's origin and axes.
          tomot
          Jim I don't know what I'm going to do with that piece of information
          in a practical way to solve this problem.
          As the attached pic shows, at present the glazing is flush with each face
          of the 2 opening the glazing is installed into.
          I would like to have the option of letting the user pick an offset back from
          the face as is shown in the opening on the left side of the cube.
          my plugins
          tomot
            Jim
            Well, you know the normal of the glass, just move the group forward or backward along the normal.
            In other words, apply a transformation to the final group in the + or - direction along the base face normal.
              Aren't you re-inventing Windowizer without a frame ? Currently you must enter something, but 0.1mm makes the frames effectively nothing...
                dtrarch
                tomot
                Very clever tool and thanks.
                As it creates a group it is very easy to move back and forth.
                Good enough as it stands.
                dtr
                  tomot
                  Not at all! Windowizer asks for 4 sided face to be selected first. While I use the "pick 3 point rectangle" method.
                  This is not a criticism of how Windowizer works, it has more to do with my workflow.
                  I design structures in SU using walls and slabs that have thickness. Then I punch openings in them for windows, doors, stairs etc., later I fill in those openings with the required components.
                  I find the "pick 3 points rectangle' method the most natural way to fill in an opening. If I were to use Windowizer, I have to fill in the opening prior to running the script.
                  However, I would be more interested in getting the setback problem solved.
                  While Jim's comments make a lot of sense, I can't get the code to work.
                  aargh!
                  my plugins
                  tomot
                    tomot
                    @dtrarch said:
                    tomot
                    dtr
                    Thanks! But after I have moved about 30 windows back 3" from the face. I
                    feel like my Grey matter is leaving for greener pastures.
                    my plugins
                    tomot
                      Jim
                      Hi tomot,
                      Here is a snippet of your plugin with the transformation.
                          self.reset
                          normal = base.normal
                          normal.length = 2 # how far?
                          tr = Geom;;Transformation.translation(normal.reverse)
                          group.transform! tr
                          model.commit_operation
                        tomot
                        Jim, please accept my great appreciation, with a reply HUG!
                        so here is the the attached update:
                        WindowGlass.rb
                        my plugins
                        tomot
                        • N Offline
                          nomeradona
                          clever and useful indeed.. thanks
                          • FletchF Offline
                            Fletch
                            I asked a long time ago for windowizer to have ability to have "0" as the frame, and have it be left out completely... but all I remember getting was a "good idea Fletch"... while never seeing it implemented... I'm still waiting.
                            until then... this could be useful - thanks for sharing!... and true about the workflow... sometime nice to just draw interactively.
                            Fletch
                              RickW
                              @fletch: Yeah, unfortunately, that happens a lot more than I would like. More ideas than time to implement...
                              RickW
                              www.smustard.com
                                JGA
                                Tomat, thanks very much for the tool.
                                RickW, Windowizer is one of the most useful tools available. However, could it be adapted to provide an inner frame of a window? I currently push pull through the wall, repair the faces & then use windowizer on both sides of the wall.
                                Regards,
                                JGA
                                  tomot
                                  Yes I have a working copy, with glazing, frame and exterior trim however, I still have
                                  a few bugs to resolve, before posting it.
                                  my plugins
                                  tomot
                                  • FletchF Offline
                                    Fletch
                                    @Rick,
                                    ah well... c'est la vie... 😄
                                    Fletch
                                      tomot
                                      @fletch said:
                                      @Rick,
                                      In fairness to RickW, he has produced some amazing code.
                                      I think he was the first one to create a dialog box in Ruby.
                                      Without which all input Rubies could not exist.
                                      my plugins
                                      tomot
