    [Plugin] SketchyBevel 0.1(Updated May 11)
    142 Posts 84 Posters 124.2k Views 84 Watching
    • soloS Offline
      Yup to the desktop unfortunately, I hardly use the Mac so it's no big deal really. every now and again I have to clean it all up as I run out of space on desktop.
        REGIS
        with safari 2 it saves on the desktop but with safari 3 and 10.5 it saves where you want and you can check this in safari's preferences
        Never tried safari 3 with 10.4
          rzadwg
          woah, awesome, cheers for this one. its gunna save me a lot of time!
          • JClementsJ Offline
            JClements
            The bevel to the top surface (red) should be "concave" shouldn't it?PNG image
            Sketchy Bevel with v0-1.skp
              CPhillips
              Its a known bug. I haven't figured out how to detect those faces yet. You can fix it by erasing the face and redrawing it using a clockwise line.
              • W Offline
                Whaat
                As I was playing around with my own beveling script, I found this method to be useful:
                edge.reversed_in?(face)
                The EdgeUse class also has some useful methods that may help fix this bug.
                Great script, BTW
                  CPhillips
                  I'll try that. Thanks Whaat!
                  BTW. I understand you lost your bevel script in a HD crash. SketchyBevel was almost doomed as well. My Ruby editor crashed (the only time in years of use) taking the only version of the almost finished plugin with it. Nothing was left. I was despondent. But I manage to pull a half digested version of the Ruby code out of a Sketchup core dump. Whew! I would have never had the strength to redo the code without that.
                  • Y Offline
                    Yup_done
                    DELETED FOR BREVITY
                    We're all in your debt for that heroic effort.
                    Has NBC heard of you yet? Maybe a spinoff of
                    heroes...
                    Heroes... The CAD team?
                    Saving the world, one bezel at a time!? 🤣
                    Your efforts are appreciated by all who don't dare put words to paper...
                    errr.. make that:
                    font to blog 😲
                      twharvey
                      Super useful!!
                      Thanks a million.
                      Tom
                      Tom
                        rufy
                        😍 Greaat !!!!
                          topmanblue
                          ☀ ☀ ☀ very very nice !!!!
                          • F Offline
                            Fletch
                            realized I neglected to give you my thanks for this great plugin - it was something I had requested many times over the years.
                            a great big 😍 for you, Chris!
                            Fletch
                            Twilight Render Cross-platform Plugin for SketchUp on PC or Mac
                              Jim
                              I can't get this simple box to bevel, but I also can't find anything wrong with the geometry. Can someone look at it and tell me if there's a problem? Thanks.
                              box.skp
                                remus
                                Worked fine for me, did you select the entire box->right click->bevel?
                                • david_hD Offline
                                  david_h
                                  Worked for me too. . it's a great tool, but there is one issue I don't understand about it. How come it leaves some Geometry "Residue" (i.e. tell-tale faces and lines) after running the sweep? Doesn't do it everytime, but it did in this model (jim's) even after playing with the different values and "True/False" options.
                                    remus
                                    I think the ruby works by offsetting all the faces of the mesh then joining them up to create the bevel, id guess the residue is from when the ruby doesnt delete all the faces it should, for whatever reason.
                                    • david_hD Offline
                                      david_h
                                      Offset thing. . .good tip. . .I just like using the word Residue. 💚
                                        Jim
                                        see attached[attachment=0:2l2qcph5]<!-- ia0 -->screenshot.jpg<!-- ia0 -->[/attachment:2l2qcph5]
                                        I think I've found a solution. I'll forward it to Chris to see what he thinks.
                                          CPhillips
                                          see attached[attachment=0:1xmyg9fv]<!-- ia0 -->screenshot.jpg<!-- ia0 -->[/attachment:1xmyg9fv]
                                          In this case it looks like the front face of the box was reversed. This is a known bug. You can fix it by erasing and redrawing the face using a clockwise line. Lame I know. Whaat suggested a fix a few posts ago but I haven't tried it yet.
                                          Residue can also be caused by a face shrinking so much that it becomes reversed. That is a lot harder to fix.
                                            shuyan
                                            • 3 / 8
