    [Plugin] SketchyBevel 0.1(Updated May 11)
    143 Posts 85 Posters 150.0k Views 85 Watching
    • JClementsJ
      JClements
      The bevel to the top surface (red) should be "concave" shouldn't it?PNG image
      Sketchy Bevel with v0-1.skp
      • C
        CPhillips
        Its a known bug. I haven't figured out how to detect those faces yet. You can fix it by erasing the face and redrawing it using a clockwise line.
        • W
          Whaat
          As I was playing around with my own beveling script, I found this method to be useful:
          edge.reversed_in?(face)
          The EdgeUse class also has some useful methods that may help fix this bug.
          Great script, BTW
          • C
            CPhillips
            I'll try that. Thanks Whaat!
            BTW. I understand you lost your bevel script in a HD crash. SketchyBevel was almost doomed as well. My Ruby editor crashed (the only time in years of use) taking the only version of the almost finished plugin with it. Nothing was left. I was despondent. But I manage to pull a half digested version of the Ruby code out of a Sketchup core dump. Whew! I would have never had the strength to redo the code without that.
            • Y
              Yup_done
              DELETED FOR BREVITY
              We're all in your debt for that heroic effort.
              Has NBC heard of you yet? Maybe a spinoff of
              heroes...
              Heroes... The CAD team?
              Saving the world, one bezel at a time!? 🀣
              Your efforts are appreciated by all who don't dare put words to paper...
              errr.. make that:
              font to blog 😲
              • T
                twharvey
                Super useful!!
                Thanks a million.
                Tom
                Tom
                  rufy
                  😍 Greaat !!!!
                  • T
                    topmanblue
                    β˜€ β˜€ β˜€ very very nice !!!!
                    • FletchF
                      Fletch
                      realized I neglected to give you my thanks for this great plugin - it was something I had requested many times over the years.
                      a great big 😍 for you, Chris!
                      Fletch
                        Jim
                        I can't get this simple box to bevel, but I also can't find anything wrong with the geometry. Can someone look at it and tell me if there's a problem? Thanks.
                        box.skp
                          remus
                          Worked fine for me, did you select the entire box->right click->bevel?
                          • david_hD
                            david_h
                            Worked for me too. . it's a great tool, but there is one issue I don't understand about it. How come it leaves some Geometry "Residue" (i.e. tell-tale faces and lines) after running the sweep? Doesn't do it everytime, but it did in this model (jim's) even after playing with the different values and "True/False" options.
                              remus
                              I think the ruby works by offsetting all the faces of the mesh then joining them up to create the bevel, id guess the residue is from when the ruby doesnt delete all the faces it should, for whatever reason.
                              • david_hD
                                david_h
                                Offset thing. . .good tip. . .I just like using the word Residue. πŸ’š
                                  Jim
                                  see attached[attachment=0:2l2qcph5]<!-- ia0 -->screenshot.jpg<!-- ia0 -->[/attachment:2l2qcph5]
                                  I think I've found a solution. I'll forward it to Chris to see what he thinks.
                                  • C
                                    CPhillips
                                    see attached[attachment=0:1xmyg9fv]<!-- ia0 -->screenshot.jpg<!-- ia0 -->[/attachment:1xmyg9fv]
                                    In this case it looks like the front face of the box was reversed. This is a known bug. You can fix it by erasing and redrawing the face using a clockwise line. Lame I know. Whaat suggested a fix a few posts ago but I haven't tried it yet.
                                    Residue can also be caused by a face shrinking so much that it becomes reversed. That is a lot harder to fix.
                                      shuyan
                                      • G
                                        gaucho
                                        thanks mate!
                                        "eat well, stay fit, die anyway..."
                                          sketchyup
                                          This plugin should help with a model I'm currently working on. Thanks πŸ˜„
                                            daphne0804
                                            Thanks!This is VERY useful πŸ˜„
                                            • 5 / 8
