    [Plugin] SketchyBevel 0.1(Updated May 11)
    143 Posts 85 Posters 150.0k Views 85 Watching
      rufy
      😍 Greaat !!!!
      • T
        topmanblue
        β˜€ β˜€ β˜€ very very nice !!!!
        • FletchF
          Fletch
          realized I neglected to give you my thanks for this great plugin - it was something I had requested many times over the years.
          a great big 😍 for you, Chris!
          Fletch
            Jim
            I can't get this simple box to bevel, but I also can't find anything wrong with the geometry. Can someone look at it and tell me if there's a problem? Thanks.
            box.skp
              remus
              Worked fine for me, did you select the entire box->right click->bevel?
              • david_hD
                david_h
                Worked for me too. . it's a great tool, but there is one issue I don't understand about it. How come it leaves some Geometry "Residue" (i.e. tell-tale faces and lines) after running the sweep? Doesn't do it everytime, but it did in this model (jim's) even after playing with the different values and "True/False" options.
                  remus
                  I think the ruby works by offsetting all the faces of the mesh then joining them up to create the bevel, id guess the residue is from when the ruby doesnt delete all the faces it should, for whatever reason.
                  • david_hD
                    david_h
                    Offset thing. . .good tip. . .I just like using the word Residue. πŸ’š
                      Jim
                      see attached[attachment=0:2l2qcph5]<!-- ia0 -->screenshot.jpg<!-- ia0 -->[/attachment:2l2qcph5]
                      I think I've found a solution. I'll forward it to Chris to see what he thinks.
                      • C
                        CPhillips
                        see attached[attachment=0:1xmyg9fv]<!-- ia0 -->screenshot.jpg<!-- ia0 -->[/attachment:1xmyg9fv]
                        In this case it looks like the front face of the box was reversed. This is a known bug. You can fix it by erasing and redrawing the face using a clockwise line. Lame I know. Whaat suggested a fix a few posts ago but I haven't tried it yet.
                        Residue can also be caused by a face shrinking so much that it becomes reversed. That is a lot harder to fix.
                          shuyan
                          • G
                            gaucho
                            thanks mate!
                            "eat well, stay fit, die anyway..."
                              sketchyup
                              This plugin should help with a model I'm currently working on. Thanks πŸ˜„
                                daphne0804
                                Thanks!This is VERY useful πŸ˜„
                                • free agentF
                                  free agent
                                  Cphillips: as amazing useful as this script is (carzy that sketchup doesnt have this built in) did you manage to work on it a bit? it puts a masave hault on production to have to delete faces and close them (sometimes that doesnt work and and i have to keep deleting face faces and closing to figure out which is the problem face)
                                  http://i167.photobucket.com/albums/u143/FreeAgent84/bug.gif
                                  • I
                                    IHU
                                    hope this helps 😐
                                    • jujuJ
                                      juju
                                      @ihu said:
                                      hope this helps 😐
                                      you hope what helps?
                                        somchailee
                                        Thanks A Lot
                                          moomin
                                          thanks.
                                          • N
                                            NewOne
                                            Hy CPhillips very nice script!! Really usefull (sorry, dropped my pen)
                                            But in some cases I encounter some strange behaviours with this script.
                                            See the attached images.
                                            What exactly does "Cap Holes" ?
                                            Images 1 - 3 are self-explanatory. For img 4 i might have some simple ideas to avoid happening that: What if the script can find the smallest distance between two paralel edges from the selected geometry and don't use a greater value for bevel than is supported on that object.
                                            One more thing: for rounding edges the script could run twice calculating 1/3 from first bevel value, then make edges soften. I don't understand why third run gives me all the times that result with missing faces and rezidual geometry.
                                            I'm not criticing your work, I'm amazed and using it enthusiasticly. Just trying to help with ideeas.
                                            Thank again.
                                            • 6 / 8
