    [Plugin] SketchyBevel 0.1(Updated May 11)
    143 Posts 85 Posters 150.0k Views 85 Watching
      remus
      You'll need to change the file extension to .rb for it to work. Not sure why its downloading it as a .txt though 😉 perhaps some of the more apple savy have an answer?
      • B
        bubbalove
        Figured it out... for some reason Safari downloads it as a txt file for some reason. Worked like a charm in IE even though I don't like using IE. Thanks Remus!
        "Success consists of going from failure to failure without loss of enthusiasm." - Churchill
        • soloS
          I use safari on my Mac and .rb's save normally, must be a setting.
          • B
            bubbalove
            I looked at my preferences... everything is the way it is supposed to be. Maybe it is because I'm using Safari on Windows or something. Do they automatically save to your desktop or does it give you an option on where you want to save it?
            • soloS
              Yup to the desktop unfortunately, I hardly use the Mac so it's no big deal really. every now and again I have to clean it all up as I run out of space on desktop.
                REGIS
                with safari 2 it saves on the desktop but with safari 3 and 10.5 it saves where you want and you can check this in safari's preferences
                Never tried safari 3 with 10.4
                  rzadwg
                  woah, awesome, cheers for this one. its gunna save me a lot of time!
                  • JClementsJ
                    JClements
                    The bevel to the top surface (red) should be "concave" shouldn't it?PNG image
                    Sketchy Bevel with v0-1.skp
                    • C
                      CPhillips
                      Its a known bug. I haven't figured out how to detect those faces yet. You can fix it by erasing the face and redrawing it using a clockwise line.
                      • W
                        Whaat
                        As I was playing around with my own beveling script, I found this method to be useful:
                        edge.reversed_in?(face)
                        The EdgeUse class also has some useful methods that may help fix this bug.
                        Great script, BTW
                        • C
                          CPhillips
                          I'll try that. Thanks Whaat!
                          BTW. I understand you lost your bevel script in a HD crash. SketchyBevel was almost doomed as well. My Ruby editor crashed (the only time in years of use) taking the only version of the almost finished plugin with it. Nothing was left. I was despondent. But I manage to pull a half digested version of the Ruby code out of a Sketchup core dump. Whew! I would have never had the strength to redo the code without that.
                          • Y
                            Yup_done
                            DELETED FOR BREVITY
                            We're all in your debt for that heroic effort.
                            Has NBC heard of you yet? Maybe a spinoff of
                            heroes...
                            Heroes... The CAD team?
                            Saving the world, one bezel at a time!? 🤣
                            Your efforts are appreciated by all who don't dare put words to paper...
                            errr.. make that:
                            font to blog 😲
                            • T
                              twharvey
                              Super useful!!
                              Thanks a million.
                              Tom
                              Tom
                                rufy
                                😍 Greaat !!!!
                                • T
                                  topmanblue
                                  ☀ ☀ ☀ very very nice !!!!
                                  • FletchF
                                    Fletch
                                    realized I neglected to give you my thanks for this great plugin - it was something I had requested many times over the years.
                                    a great big 😍 for you, Chris!
                                    Fletch
                                      Jim
                                      I can't get this simple box to bevel, but I also can't find anything wrong with the geometry. Can someone look at it and tell me if there's a problem? Thanks.
                                      box.skp
                                        remus
                                        Worked fine for me, did you select the entire box->right click->bevel?
                                        • david_hD
                                          david_h
                                          Worked for me too. . it's a great tool, but there is one issue I don't understand about it. How come it leaves some Geometry "Residue" (i.e. tell-tale faces and lines) after running the sweep? Doesn't do it everytime, but it did in this model (jim's) even after playing with the different values and "True/False" options.
                                            remus
                                            I think the ruby works by offsetting all the faces of the mesh then joining them up to create the bevel, id guess the residue is from when the ruby doesnt delete all the faces it should, for whatever reason.
                                            • 5 / 8
