    [Plugin] SketchyBevel 0.1(Updated May 11)
    143 Posts 85 Posters 143.2k Views 85 Watching
    • Y Offline
      Yup_done
      @cphillips said:
      I'll try that. Thanks Whaat!
      DELETED FOR BREVITY
      But I manage to pull a half digested version of the Ruby code out of a Sketchup core dump. Whew! I would have never had the strength to redo the code without that.
      We're all in your debt for that heroic effort.
      Has NBC heard of you yet? Maybe a spinoff of
      heroes...
      Heroes... The CAD team?
      Saving the world, one bezel at a time!? 🀣
      Your efforts are appreciated by all who don't dare put words to paper...
      errr.. make that:
      font to blog 😲
        twharvey
        Super useful!!
        Thanks a million.
        Tom
        Tom
          rufy
          😍 Greaat !!!!
            topmanblue
            β˜€ β˜€ β˜€ very very nice !!!!
            • FletchF Offline
              Fletch
              realized I neglected to give you my thanks for this great plugin - it was something I had requested many times over the years.
              a great big 😍 for you, Chris!
              Fletch
                Jim
                I can't get this simple box to bevel, but I also can't find anything wrong with the geometry. Can someone look at it and tell me if there's a problem? Thanks.
                box.skp
                  remus
                  Worked fine for me, did you select the entire box->right click->bevel?
                  • david_hD Offline
                    david_h
                    Worked for me too. . it's a great tool, but there is one issue I don't understand about it. How come it leaves some Geometry "Residue" (i.e. tell-tale faces and lines) after running the sweep? Doesn't do it everytime, but it did in this model (jim's) even after playing with the different values and "True/False" options.
                      remus
                      I think the ruby works by offsetting all the faces of the mesh then joining them up to create the bevel, id guess the residue is from when the ruby doesnt delete all the faces it should, for whatever reason.
                      • david_hD Offline
                        david_h
                        Offset thing. . .good tip. . .I just like using the word Residue. πŸ’š
                          Jim
                          see attached[attachment=0:2l2qcph5]<!-- ia0 -->screenshot.jpg<!-- ia0 -->[/attachment:2l2qcph5]
                          I think I've found a solution. I'll forward it to Chris to see what he thinks.
                            CPhillips
                            see attached[attachment=0:1xmyg9fv]<!-- ia0 -->screenshot.jpg<!-- ia0 -->[/attachment:1xmyg9fv]
                            In this case it looks like the front face of the box was reversed. This is a known bug. You can fix it by erasing and redrawing the face using a clockwise line. Lame I know. Whaat suggested a fix a few posts ago but I haven't tried it yet.
                            Residue can also be caused by a face shrinking so much that it becomes reversed. That is a lot harder to fix.
                              shuyan
                                gaucho
                                thanks mate!
                                "eat well, stay fit, die anyway..."
                                  sketchyup
                                  This plugin should help with a model I'm currently working on. Thanks πŸ˜„
                                    daphne0804
                                    Thanks!This is VERY useful πŸ˜„
                                    • free agentF Offline
                                      free agent
                                      Cphillips: as amazing useful as this script is (carzy that sketchup doesnt have this built in) did you manage to work on it a bit? it puts a masave hault on production to have to delete faces and close them (sometimes that doesnt work and and i have to keep deleting face faces and closing to figure out which is the problem face)
                                      http://i167.photobucket.com/albums/u143/FreeAgent84/bug.gif
                                      • I Offline
                                        IHU
                                        hope this helps 😐
                                        • jujuJ Offline
                                          juju
                                          @ihu said:
                                          hope this helps 😐
                                          you hope what helps?
                                            somchailee
                                            Thanks A Lot
                                            • 6 / 8
