    ๐Ÿ”Œ Easy Offset | Offset selected faces in SketchUp in positive and negative offsets. Download
    [REQ] Convert ALL components to groups?
    26 Posts 10 Posters 5.8k Views 10 Watching
      Jackson
      Wow guys, thanks so much for the suggestions and the ruby script!
      Bob, all the component names are unique so I'm not sure that ruby would be useful in this case. Thanks for all the thought you've been putting into this though!
      Matt, I'll give your ruby a try- a friend actually emailed me a similar ruby this morning, which I've yet to try, but I'll test both of them and report the results. A 15Mb model containing 3024 components inside 783 groups is a GOOD test!
      Now for the funny part- I put off checking in on SCF this morning when I arrived at work, deciding instead to spend 2 hours manually opening every building group and exploding and regrouping every single component. Then I check SCF and my email and I've been sent TWO ruby's which potentially automate the whole process! ๐Ÿ˜’ ๐Ÿ˜†
      Thanks again guys, your ingenuity and generosity is what makes this such a great community!
      Jackson
        Jackson
        Matt,
        I get an error message on opening SU after copying in your .rb
        I ran the other .rb I received- it definitely works, exploding all top level comps and regrouping them, but I had to delete and purge 90% of the model as I think it would take about an hour of SU hanging before that model was fully converted. Would been a perfect task to have left running at lunchtime though!
        Thanks again,
        Jackson
        • plot-parisP Offline
          plot-paris
          works perfectly fine for me (Windows XP).
          thanks a lot, Matt666. this one will come in quite handy
          now we only need the reverse funktion - transform to component
          if more than one group is selected SU could ask, whether you want to replace all by one component or create a seperate component for each group.
          now I come to think of it SU could even compare the groups' shapes.
          • if they are the same one they are automatically replaced by the same component.
          • if they are the same shape but in different sizes, SU asks you which group shall resemble the original component scale and automatically replaces the other groups by scaled component instances
          • if the groups are different in shape, seperate components will be created
          sorry for drifting off into dreamland. ๐Ÿ˜ณ I don't suspect, comparing geometry like this will be easy...
            Matt666
            Group to component is really more complicated...
            Each group is different, no definition...
            I will try to make smt.
            Frenglish at its best !
            My scripts
              To make a component instance into a group why not make a new group containing the instance and then explode the instance. Its bits stay inside the new group. Then mine down through the new groups entities and if any are instances repeat as above... You can name the group to match the instance etc.
              To make a group into a new component definition (and an instance) use the built in API function:
              new_component = group.to_component
              It takes the group's name...
                Matt666
                Hello TIG !
                ๐Ÿ˜ฒ Great idea !!! I have not thought about it... ๐Ÿ˜ž I have updated the script... ๐Ÿ˜‰
                Also updated !
                Only if the group has a name...
                Otherwise, we must compare all groups, see which are the same ... If so transform them into components with same definition! Quite complicated... ๐Ÿ˜ž
                Thank you for the advices !!
                My scripts
                  plot-paris
                  the new feature of renaming new groups after the original component's name is quite nice.
                  however, I can't transform a selection of components to groups anymore. now I have to right cklick the instances one by one, telling them to become a group, which costs a lot of time.
                  is there a way to change it back to how it was (ability to transform several components to groups in one operation)?
                  cheers,
                  Jakob
                    Matt666
                    Hi plot-paris !
                    โ“ Strange... It works without problem here...
                    Can you open ruby console before running the tool and show the matter returned inside the console here, please ?
                    If you want to convert all components, don't select anything, it will convert all components in the drawing.
                    My scripts
                      plot-paris
                      here is what is displayed in the ruby console, when I apply the tool to a selection of components (if I don't select anything, it still transfers only the component, that has been right clicked):
                      Error; #<NoMethodError; undefined method `c2g_boucle' for #<Object;0x485a290 @model=#<Sketchup;;Model;0x56f7678>, @nb=1>>
                      C;/Program Files/Google/Google SketchUp 6/Plugins/C2G.rb;42;in `boucle'
                      C;/Program Files/Google/Google SketchUp 6/Plugins/C2G.rb;29;in `each'
                      C;/Program Files/Google/Google SketchUp 6/Plugins/C2G.rb;29;in `boucle'
                      C;/Program Files/Google/Google SketchUp 6/Plugins/C2G.rb;20;in `c2g'
                      C;/Program Files/Google/Google SketchUp 6/Plugins/C2G.rb;69
                      C;/Program Files/Google/Google SketchUp 6/Plugins/C2G.rb;69;in `call'
                        Matt666
                        a "transform to group" command
                        New version can transform all components in the right click selection.
                        !!! I have no problem here !!! Could someone test this script ???
                        Mac or PC ?
                        Can you show us this script, please ?
                        New version asks if you want to purge.
                        EDIT : New version with TIG advices ! ๐Ÿ˜‰
                        EDIT : New version with bugs fixes ! Thank you Plot Paris !
                        C2G.rb
                        My scripts
                          Matt666
                          ๐Ÿ˜ณ ๐Ÿ˜ณ ๐Ÿ˜ณ ๐Ÿ˜ณ
                          Excuse me....
                          A new version has been updated in the script's post.
                          My scripts
                            plot-paris
                            and it works... wonderful! ๐Ÿ˜
                              lapx
                              What about G2C? ๐Ÿ˜› Is this still not possible at this time?
                                plot-paris
                                well, that would be wonderful.
                                but I assume (having not a clue of ruby scripting), that it is very difficult to compare geometry. because that is what you had to do, if transforming several identical groups to components.
                                it gets even more complicated, if the instances (of the groups) are rotated or even scaled...
                                but it would indeed be one of the most useful rubies.
                                  Matt666
                                  Exactly, Plot-Paris... ๐Ÿ˜ž ๐Ÿ˜ฎ
                                  My scripts
                                    rfn
                                    @jackson said:
                                    Matt,
                                    [attachment=0:3hbnrx9w]<!-- ia0 -->C2G Ruby Error.jpg<!-- ia0 -->[/attachment:3hbnrx9w]
                                    Thanks again,
                                    I get the exact same error. any solution?
                                      Matt666
                                      Hi rfn,
                                      You just have to add this line at the beginning of the script :
                                      require 'sketchup.rb'
                                      ๐Ÿ˜‰
                                      I will update the script... thank you !
                                      My scripts
                                        Matt666
                                        Hello.
                                        here is a test which converts components to groups.
                                        Not really tested... ๐Ÿ˜‰
                                        EDIT : See last version below
                                        My scripts
                                          Antiever
                                          With SU 2017 if I select a few components script convert only one random from selection...
                                          How can I modify it to convert every selected components to groups?
                                            paguthrie
                                            10 Years later... this script almost does exactly what I need, but as Antiever pointed out it just does one from a selection. Anyone know how to fix this behaviour?
                                            • 2 / 2
