    [REQ] Convert ALL components to groups?
    26 Posts 10 Posters 6.5k Views 10 Watching
      Matt666
      a "transform to group" command
      New version can transform all components in the right click selection.
      I get an error message on opening SU after copying in your .rb
      !!! I have no problem here !!! Could someone test this script ???
      Mac or PC ?
      I ran the other .rb I received- it definitely works,
      Can you show us this script, please ?
      but I had to delete and purge 90% of the model
      New version asks if you want to purge.
      EDIT : New version with TIG advices ! ๐Ÿ˜‰
      EDIT : New version with bugs fixes ! Thank you Plot Paris !
      C2G.rb
      Frenglish at its best !
      My scripts
        Matt666
        ๐Ÿ˜ณ ๐Ÿ˜ณ ๐Ÿ˜ณ ๐Ÿ˜ณ
        Excuse me....
        A new version has been updated in the script's post.
        My scripts
        • plot-parisP Offline
          plot-paris
          and it works... wonderful! ๐Ÿ˜
          thanks a lot, Matt666
            lapx
            What about G2C? ๐Ÿ˜› Is this still not possible at this time?
              plot-paris
              well, that would be wonderful.
              but I assume (having not a clue of ruby scripting), that it is very difficult to compare geometry. because that is what you had to do, if transforming several identical groups to components.
              it gets even more complicated, if the instances (of the groups) are rotated or even scaled...
              but it would indeed be one of the most useful rubies.
                Matt666
                Exactly, Plot-Paris... ๐Ÿ˜ž ๐Ÿ˜ฎ
                My scripts
                  rfn
                  @jackson said:
                  Matt,
                  [attachment=0:3hbnrx9w]<!-- ia0 -->C2G Ruby Error.jpg<!-- ia0 -->[/attachment:3hbnrx9w]
                  I ran the other .rb I received- it definitely works, exploding all top level comps and regrouping them, but I had to delete and purge 90% of the model as I think it would take about an hour of SU hanging before that model was fully converted. Would been a perfect task to have left running at lunchtime though!
                  Thanks again,
                  I get the exact same error. any solution?
                    Matt666
                    Hi rfn,
                    You just have to add this line at the beginning of the script :
                    require 'sketchup.rb'
                    ๐Ÿ˜‰
                    I will update the script... thank you !
                    My scripts
                      Matt666
                      Hello.
                      here is a test which converts components to groups.
                      Not really tested... ๐Ÿ˜‰
                      EDIT : See last version below
                      My scripts
                        Antiever
                        With SU 2017 if I select a few components script convert only one random from selection...
                        How can I modify it to convert every selected components to groups?
                          paguthrie
                          10 Years later... this script almost does exactly what I need, but as Antiever pointed out it just does one from a selection. Anyone know how to fix this behaviour?
                          • sdmitchS Offline
                            sdmitch
                            Hopefully Matt666 wont mind me editing his plugin. Tested in SU2017 in model with and without selections.
                            C2G.rb
                            http://sdmitch.blogspot.com/
                            • 2 / 2
