    [REQ] Convert ALL components to groups?
    26 Posts 10 Posters 7.5k Views 10 Watching
      Jackson
      haha, Scotland WAS quite cold enough thanks Bob! Believe it or not, Malmรถ, where I live now is actually a bit south of Edinburgh (Sweden is a taaaaall country)- summer temperatures here are more in line with the south of England and it only snows a little in the winter (and usually melts within a couple of days ๐Ÿ˜ž ). You have to travel a few hundred miles north before it starts feeling really "Swedish". When you're right up in the Arctic Circle in the middle of winter it feels like the end of the earth... but sooo beautiful!
      Still working on the coincident components problem- I don't think there's an easy way round it.
      Jackson
      • plot-parisP Offline
        plot-paris
        indeed, a ruby would be great that does the following things:
        when a component / several components are selected, the "create group" command in the right click context menue is exchanged with a "transform to group" command (the accordant shortcut changes it's function too)
        and exactly the same the other way arround: with one ore more selected groups the "create component" command is exchanged with "transform to component" command, whereas only one component is created and the other groups are replaced by this component (does that make sense? ๐Ÿ˜• )
        and last but not least: it would be great to be able to apply the "replace with selected" (when some components in the model are highlighted and you right click on a different one in the component window) to groups as well. this would be helpful, if you for example created a set of columns and only later discover, that they all stayed the same proportion and can therefore be a component.
        such a ruby would bring a great improvement to the workflow in SketchUp (and is definitely something that would be nice to be found in SU7 ๐Ÿ˜‰ )
        • W Offline
          watkins
          Dear Jackson,
          Do you know about the select_instances script in the Ruby section of this forum? I think this script will also select multiple components (components with different 'parent' names).
          Quoting from the post:
          NEW Version 2:
          This new version includes a new function that is "Select Families" on right click.
          A family would be a bunch of components that were created by making a parent compo unique.
          Every component name that begins with the same name before the '#' will be considered as part of the family. Capisci? ๐Ÿ˜Ž
          So just create a component, copy it a couple of time, make one of the instance unique, select any of the created component and right click "Select families".
          End quote.
          Do your coincident components have the same 'parent' name. If so, you may be able to use this script to separate you coincident components.
          Kind regards,
          Bob
            Jackson
            Wow guys, thanks so much for the suggestions and the ruby script!
            Bob, all the component names are unique so I'm not sure that ruby would be useful in this case. Thanks for all the thought you've been putting into this though!
            Matt, I'll give your ruby a try- a friend actually emailed me a similar ruby this morning, which I've yet to try, but I'll test both of them and report the results. A 15Mb model containing 3024 components inside 783 groups is a GOOD test!
            Now for the funny part- I put off checking in on SCF this morning when I arrived at work, deciding instead to spend 2 hours manually opening every building group and exploding and regrouping every single component. Then I check SCF and my email and I've been sent TWO ruby's which potentially automate the whole process! ๐Ÿ˜’ ๐Ÿ˜†
            Thanks again guys, your ingenuity and generosity is what makes this such a great community!
            Jackson
              Jackson
              Matt,
              I get an error message on opening SU after copying in your .rb
              I ran the other .rb I received- it definitely works, exploding all top level comps and regrouping them, but I had to delete and purge 90% of the model as I think it would take about an hour of SU hanging before that model was fully converted. Would been a perfect task to have left running at lunchtime though!
              Thanks again,
              Jackson
                plot-paris
                works perfectly fine for me (Windows XP).
                thanks a lot, Matt666. this one will come in quite handy
                now we only need the reverse funktion - transform to component
                if more than one group is selected SU could ask, whether you want to replace all by one component or create a seperate component for each group.
                now I come to think of it SU could even compare the groups' shapes.
                • if they are the same one they are automatically replaced by the same component.
                • if they are the same shape but in different sizes, SU asks you which group shall resemble the original component scale and automatically replaces the other groups by scaled component instances
                • if the groups are different in shape, seperate components will be created
                sorry for drifting off into dreamland. ๐Ÿ˜ณ I don't suspect, comparing geometry like this will be easy...
                  Matt666
                  Group to component is really more complicated...
                  Each group is different, no definition...
                  I will try to make smt.
                  Frenglish at its best !
                  My scripts
                    To make a component instance into a group why not make a new group containing the instance and then explode the instance. Its bits stay inside the new group. Then mine down through the new groups entities and if any are instances repeat as above... You can name the group to match the instance etc.
                    To make a group into a new component definition (and an instance) use the built in API function:
                    new_component = group.to_component
                    It takes the group's name...
                      Matt666
                      Hello TIG !
                      ๐Ÿ˜ฒ Great idea !!! I have not thought about it... ๐Ÿ˜ž I have updated the script... ๐Ÿ˜‰
                      Also updated !
                      Only if the group has a name...
                      Otherwise, we must compare all groups, see which are the same ... If so transform them into components with same definition! Quite complicated... ๐Ÿ˜ž
                      Thank you for the advices !!
                      My scripts
                        plot-paris
                        the new feature of renaming new groups after the original component's name is quite nice.
                        however, I can't transform a selection of components to groups anymore. now I have to right cklick the instances one by one, telling them to become a group, which costs a lot of time.
                        is there a way to change it back to how it was (ability to transform several components to groups in one operation)?
                        cheers,
                        Jakob
                          Matt666
                          Hi plot-paris !
                          โ“ Strange... It works without problem here...
                          Can you open ruby console before running the tool and show the matter returned inside the console here, please ?
                          If you want to convert all components, don't select anything, it will convert all components in the drawing.
                          My scripts
                            plot-paris
                            here is what is displayed in the ruby console, when I apply the tool to a selection of components (if I don't select anything, it still transfers only the component, that has been right clicked):
                            Error; #<NoMethodError; undefined method `c2g_boucle' for #<Object;0x485a290 @model=#<Sketchup;;Model;0x56f7678>, @nb=1>>
                            C;/Program Files/Google/Google SketchUp 6/Plugins/C2G.rb;42;in `boucle'
                            C;/Program Files/Google/Google SketchUp 6/Plugins/C2G.rb;29;in `each'
                            C;/Program Files/Google/Google SketchUp 6/Plugins/C2G.rb;29;in `boucle'
                            C;/Program Files/Google/Google SketchUp 6/Plugins/C2G.rb;20;in `c2g'
                            C;/Program Files/Google/Google SketchUp 6/Plugins/C2G.rb;69
                            C;/Program Files/Google/Google SketchUp 6/Plugins/C2G.rb;69;in `call'
                              Matt666
                              New version can transform all components in the right click selection.
                              !!! I have no problem here !!! Could someone test this script ???
                              Mac or PC ?
                              Can you show us this script, please ?
                              New version asks if you want to purge.
                              EDIT : New version with TIG advices ! ๐Ÿ˜‰
                              EDIT : New version with bugs fixes ! Thank you Plot Paris !
                              C2G.rb
                              My scripts
                                Matt666
                                ๐Ÿ˜ณ ๐Ÿ˜ณ ๐Ÿ˜ณ ๐Ÿ˜ณ
                                Excuse me....
                                A new version has been updated in the script's post.
                                My scripts
                                  plot-paris
                                  and it works... wonderful! ๐Ÿ˜
                                    lapx
                                    What about G2C? ๐Ÿ˜› Is this still not possible at this time?
                                      plot-paris
                                      well, that would be wonderful.
                                      but I assume (having not a clue of ruby scripting), that it is very difficult to compare geometry. because that is what you had to do, if transforming several identical groups to components.
                                      it gets even more complicated, if the instances (of the groups) are rotated or even scaled...
                                      but it would indeed be one of the most useful rubies.
                                        Matt666
                                        Exactly, Plot-Paris... ๐Ÿ˜ž ๐Ÿ˜ฎ
                                        My scripts
                                          rfn
                                          @jackson said:
                                          Matt,
                                          [attachment=0:3hbnrx9w]<!-- ia0 -->C2G Ruby Error.jpg<!-- ia0 -->[/attachment:3hbnrx9w]
                                          Thanks again,
                                          I get the exact same error. any solution?
                                            Matt666
                                            Hi rfn,
                                            You just have to add this line at the beginning of the script :
                                            require 'sketchup.rb'
                                            ๐Ÿ˜‰
                                            I will update the script... thank you !
                                            My scripts
