    [REQ] Convert ALL components to groups?
    26 Posts 10 Posters 6.6k Views 10 Watching
      Matt666
      ๐Ÿ˜ณ ๐Ÿ˜ณ ๐Ÿ˜ณ ๐Ÿ˜ณ
      Excuse me....
      A new version has been updated in the script's post.
      Frenglish at its best !
      My scripts
      • plot-parisP Offline
        plot-paris
        and it works... wonderful! ๐Ÿ˜
        thanks a lot, Matt666
          lapx
          What about G2C? ๐Ÿ˜› Is this still not possible at this time?
            plot-paris
            well, that would be wonderful.
            but I assume (having not a clue of ruby scripting), that it is very difficult to compare geometry. because that is what you had to do, if transforming several identical groups to components.
            it gets even more complicated, if the instances (of the groups) are rotated or even scaled...
            but it would indeed be one of the most useful rubies.
              Matt666
              Exactly, Plot-Paris... ๐Ÿ˜ž ๐Ÿ˜ฎ
              My scripts
                rfn
                @jackson said:
                Matt,
                I get an error message on opening SU after copying in your .rb
                [attachment=0:3hbnrx9w]<!-- ia0 -->C2G Ruby Error.jpg<!-- ia0 -->[/attachment:3hbnrx9w]
                I ran the other .rb I received- it definitely works, exploding all top level comps and regrouping them, but I had to delete and purge 90% of the model as I think it would take about an hour of SU hanging before that model was fully converted. Would been a perfect task to have left running at lunchtime though!
                Thanks again,
                I get the exact same error. any solution?
                  Matt666
                  Hi rfn,
                  You just have to add this line at the beginning of the script :
                  require 'sketchup.rb'
                  ๐Ÿ˜‰
                  I will update the script... thank you !
                  My scripts
                    Matt666
                    Hello.
                    here is a test which converts components to groups.
                    Not really tested... ๐Ÿ˜‰
                    EDIT : See last version below
                    My scripts
                      Antiever
                      With SU 2017 if I select a few components script convert only one random from selection...
                      How can I modify it to convert every selected components to groups?
                        paguthrie
                        10 Years later... this script almost does exactly what I need, but as Antiever pointed out it just does one from a selection. Anyone know how to fix this behaviour?
                        • sdmitchS Offline
                          sdmitch
                          Hopefully Matt666 wont mind me editing his plugin. Tested in SU2017 in model with and without selections.
                          C2G.rb
                          http://sdmitch.blogspot.com/
                          • 2 / 2
