    [REQ] Convert ALL components to groups?
    26 Posts 10 Posters 7.8k Views 10 Watching
      Jackson
      Matt,
      I get an error message on opening SU after copying in your .rb
      I ran the other .rb I received- it definitely works, exploding all top level comps and regrouping them, but I had to delete and purge 90% of the model as I think it would take about an hour of SU hanging before that model was fully converted. Would been a perfect task to have left running at lunchtime though!
      Thanks again,
      Jackson
      • plot-parisP
        plot-paris
        works perfectly fine for me (Windows XP).
        thanks a lot, Matt666. this one will come in quite handy
        now we only need the reverse funktion - transform to component
        if more than one group is selected SU could ask, whether you want to replace all by one component or create a seperate component for each group.
        now I come to think of it SU could even compare the groups' shapes.
        • if they are the same one they are automatically replaced by the same component.
        • if they are the same shape but in different sizes, SU asks you which group shall resemble the original component scale and automatically replaces the other groups by scaled component instances
        • if the groups are different in shape, seperate components will be created
        sorry for drifting off into dreamland. ๐Ÿ˜ณ I don't suspect, comparing geometry like this will be easy...
          Matt666
          Group to component is really more complicated...
          Each group is different, no definition...
          I will try to make smt.
          Frenglish at its best !
          My scripts
            To make a component instance into a group why not make a new group containing the instance and then explode the instance. Its bits stay inside the new group. Then mine down through the new groups entities and if any are instances repeat as above... You can name the group to match the instance etc.
            To make a group into a new component definition (and an instance) use the built in API function:
            new_component = group.to_component
            It takes the group's name...
              Matt666
              Hello TIG !
              ๐Ÿ˜ฒ Great idea !!! I have not thought about it... ๐Ÿ˜ž I have updated the script... ๐Ÿ˜‰
              Also updated !
              Only if the group has a name...
              Otherwise, we must compare all groups, see which are the same ... If so transform them into components with same definition! Quite complicated... ๐Ÿ˜ž
              Thank you for the advices !!
              My scripts
              • plot-parisP
                plot-paris
                the new feature of renaming new groups after the original component's name is quite nice.
                however, I can't transform a selection of components to groups anymore. now I have to right cklick the instances one by one, telling them to become a group, which costs a lot of time.
                is there a way to change it back to how it was (ability to transform several components to groups in one operation)?
                cheers,
                Jakob
                  Matt666
                  Hi plot-paris !
                  โ“ Strange... It works without problem here...
                  Can you open ruby console before running the tool and show the matter returned inside the console here, please ?
                  If you want to convert all components, don't select anything, it will convert all components in the drawing.
                  My scripts
                  • plot-parisP
                    plot-paris
                    here is what is displayed in the ruby console, when I apply the tool to a selection of components (if I don't select anything, it still transfers only the component, that has been right clicked):
                    Error; #<NoMethodError; undefined method `c2g_boucle' for #<Object;0x485a290 @model=#<Sketchup;;Model;0x56f7678>, @nb=1>>
                    C;/Program Files/Google/Google SketchUp 6/Plugins/C2G.rb;42;in `boucle'
                    C;/Program Files/Google/Google SketchUp 6/Plugins/C2G.rb;29;in `each'
                    C;/Program Files/Google/Google SketchUp 6/Plugins/C2G.rb;29;in `boucle'
                    C;/Program Files/Google/Google SketchUp 6/Plugins/C2G.rb;20;in `c2g'
                    C;/Program Files/Google/Google SketchUp 6/Plugins/C2G.rb;69
                    C;/Program Files/Google/Google SketchUp 6/Plugins/C2G.rb;69;in `call'
                      Matt666
                      a "transform to group" command
                      New version can transform all components in the right click selection.
                      !!! I have no problem here !!! Could someone test this script ???
                      Mac or PC ?
                      Can you show us this script, please ?
                      New version asks if you want to purge.
                      EDIT : New version with TIG advices ! ๐Ÿ˜‰
                      EDIT : New version with bugs fixes ! Thank you Plot Paris !
                      C2G.rb
                      My scripts
                        Matt666
                        ๐Ÿ˜ณ ๐Ÿ˜ณ ๐Ÿ˜ณ ๐Ÿ˜ณ
                        Excuse me....
                        A new version has been updated in the script's post.
                        My scripts
                        • plot-parisP
                          plot-paris
                          and it works... wonderful! ๐Ÿ˜
                          • L
                            lapx
                            What about G2C? ๐Ÿ˜› Is this still not possible at this time?
                            • plot-parisP
                              plot-paris
                              well, that would be wonderful.
                              but I assume (having not a clue of ruby scripting), that it is very difficult to compare geometry. because that is what you had to do, if transforming several identical groups to components.
                              it gets even more complicated, if the instances (of the groups) are rotated or even scaled...
                              but it would indeed be one of the most useful rubies.
                                Matt666
                                Exactly, Plot-Paris... ๐Ÿ˜ž ๐Ÿ˜ฎ
                                My scripts
                                  rfn
                                  @jackson said:
                                  Matt,
                                  [attachment=0:3hbnrx9w]<!-- ia0 -->C2G Ruby Error.jpg<!-- ia0 -->[/attachment:3hbnrx9w]
                                  Thanks again,
                                  I get the exact same error. any solution?
                                    Matt666
                                    Hi rfn,
                                    You just have to add this line at the beginning of the script :
                                    require 'sketchup.rb'
                                    ๐Ÿ˜‰
                                    I will update the script... thank you !
                                    My scripts
                                      Matt666
                                      Hello.
                                      here is a test which converts components to groups.
                                      Not really tested... ๐Ÿ˜‰
                                      EDIT : See last version below
                                      My scripts
                                        Antiever
                                        With SU 2017 if I select a few components script convert only one random from selection...
                                        How can I modify it to convert every selected components to groups?
                                        • P
                                          paguthrie
                                          10 Years later... this script almost does exactly what I need, but as Antiever pointed out it just does one from a selection. Anyone know how to fix this behaviour?
                                          • sdmitchS
                                            sdmitch
                                            Hopefully Matt666 wont mind me editing his plugin. Tested in SU2017 in model with and without selections.
                                            C2G.rb
                                            http://sdmitch.blogspot.com/
