    [Plugin] UVTools v0.1
    180 Posts 71 Posters 160.5k Views 71 Watching
    • ibonI
      ibon
      Thanks, Whaat. It's perfect! πŸ‘
      • K
        kwistenbiebel
        Yeah πŸ˜„....Thank god you didn't leave for Basecamp and stuck with us to deliver some goodies.
        Better news over here than @Boulder ?..... πŸ˜„
        Thank you very much Whaat! πŸ‘
        • FrederikF
          Frederik
          Thank you so much..!! 😍
          I read somewhere that people are calling you WhaatUp... πŸ˜„ No wonder why..!! πŸ˜‰
          Cheers
          Kim Frederik
            Jon
            Whaat, you ROCK! 😍 😍 😍
            Jon
            KT Team member
            • K
              kwistenbiebel
              I thought it was Whaat'sUp πŸ˜„
              • FrederikF
                Frederik
                You're right, Chris... 😳
                Of course it's Whaat'sUp... πŸ˜„
                (I actually wrote that to begin with, but got unsure... πŸ˜† )
                Cheers
                Kim Frederik
                • boofredlayB
                  boofredlay
                  No you are both wrong... it's:
                  WhaatzzzUp!
                  With your tongue sticking out...
                  http://www.bouncyfuncastles.com/Smiley_Tounge.gif
                  Thanks again for another nice plugin!
                  • StinkieS
                    Stinkie
                    Tip: trying this plugin on an untextured object causes the fastest splat you've ever seen. Zappp - and SU's gone. πŸ’š
                    • W
                      Whaat
                      Thanks for the comment. This is an easy fix.
                      • StinkieS
                        Stinkie
                        Cool. Been fiddling with this baby - works pretty well! Well-integrated too. πŸ‘
                        • W
                          watkins
                          Dear Dale,
                          I have very little experience of rendering and I tend not to texture my models, so I am not too sure how to use a UV tool. By the way, what does UV stand for? If I understand your post correctly, the tool 'wraps' a texture around a curved object by projecting the texture from a plane positioned over and/or under the object. Further, the plane should be positioned so that its normal is along the centreline of the curved object which is itself aligned with the z-axis. Is this correct?
                          Can one project/wrap textures from a plane over and a plane under an object by dividing the surface area of the object into two along an x-y plane? I imagine a vase with different designs on the upper and lower halves.
                          Sorry for being so dense.
                          Kind regards,
                          Bob
                            remus
                            http://en.wikipedia.org/wiki/UV_mapping
                            Theres a good illustration of spherical UV mapping there.
                            And i tihnk UV is just he coordinaet system thats used when applying textures in this way, so thats where the name comes from.
                            • urgenU
                              urgen
                              ...co-o-o-ol!thanks! 😍
                              --pupil forever...------
                              • W
                                watkins
                                Thanks Remus!
                                • StinkieS
                                  Stinkie
                                  The use is simple. Texture your object, right-click it's surface, and choose either "spherical" or "cylindrical". The size of the maps you set in SU's mat editor.
                                  And you can in fact apply different textures on an object that's been divided in half.
                                  • plot-parisP
                                    plot-paris
                                    what a wonderful plugin - works really good.
                                    cylindrical mapping is even exportet in Indigo (spherical is screwed up a bit) πŸ˜‰
                                    this is a start of a new world in SketchUp...
                                    thank you so much Whaat!
                                      I confirm πŸ˜†
                                      • W
                                        Whaat
                                        [attachment=0:2hx0fdop]<!-- ia0 -->spherical_zylindrical.jpg<!-- ia0 -->[/attachment:2hx0fdop]
                                        Your sphere might have reversed faces. I have seen this type of behavior before in the case of reveresed faces.
                                        • plot-parisP
                                          plot-paris
                                          doesn't work with right face orientation either - I just checked to be sure... still the same messy texture.
                                          indigo would have ignored a reversed face anyway.
                                          but this is the first beta release, and it works perfect in SU! 😍
                                          it is such a wonderful thing (just imagine how easy it is for fred to texture his sculptures now πŸ˜„ )
                                            dtrarch
                                            Stinkie is right.
                                            Lightning BugSplat!!! on non-textured surfaces.
                                            Otherwise works like a charm.
                                            Thanks for such a fun tool too.
                                            dtr
                                            • 1 / 9
