    [Plugin] UVTools v0.1
    180 Posts 71 Posters 160.5k Views 71 Watching
    • K
      kwistenbiebel
      I thought it was Whaat'sUp ๐Ÿ˜„
      • FrederikF
        Frederik
        You're right, Chris... ๐Ÿ˜ณ
        Of course it's Whaat'sUp... ๐Ÿ˜„
        (I actually wrote that to begin with, but got unsure... ๐Ÿ˜† )
        Cheers
        Kim Frederik
        • boofredlayB
          boofredlay
          No you are both wrong... it's:
          WhaatzzzUp!
          With your tongue sticking out...
          http://www.bouncyfuncastles.com/Smiley_Tounge.gif
          Thanks again for another nice plugin!
          • StinkieS
            Stinkie
            Tip: trying this plugin on an untextured object causes the fastest splat you've ever seen. Zappp - and SU's gone. ๐Ÿ’š
            • W
              Whaat
              Thanks for the comment. This is an easy fix.
              • StinkieS
                Stinkie
                Cool. Been fiddling with this baby - works pretty well! Well-integrated too. ๐Ÿ‘
                • W
                  watkins
                  Dear Dale,
                  I have very little experience of rendering and I tend not to texture my models, so I am not too sure how to use a UV tool. By the way, what does UV stand for? If I understand your post correctly, the tool 'wraps' a texture around a curved object by projecting the texture from a plane positioned over and/or under the object. Further, the plane should be positioned so that its normal is along the centreline of the curved object which is itself aligned with the z-axis. Is this correct?
                  Can one project/wrap textures from a plane over and a plane under an object by dividing the surface area of the object into two along an x-y plane? I imagine a vase with different designs on the upper and lower halves.
                  Sorry for being so dense.
                  Kind regards,
                  Bob
                    remus
                    http://en.wikipedia.org/wiki/UV_mapping
                    Theres a good illustration of spherical UV mapping there.
                    And i tihnk UV is just he coordinaet system thats used when applying textures in this way, so thats where the name comes from.
                    • urgenU
                      urgen
                      ...co-o-o-ol!thanks! ๐Ÿ˜
                      --pupil forever...------
                      • W
                        watkins
                        Thanks Remus!
                        • StinkieS
                          Stinkie
                          The use is simple. Texture your object, right-click it's surface, and choose either "spherical" or "cylindrical". The size of the maps you set in SU's mat editor.
                          And you can in fact apply different textures on an object that's been divided in half.
                          • plot-parisP
                            plot-paris
                            what a wonderful plugin - works really good.
                            cylindrical mapping is even exportet in Indigo (spherical is screwed up a bit) ๐Ÿ˜‰
                            this is a start of a new world in SketchUp...
                            thank you so much Whaat!
                              I confirm ๐Ÿ˜†
                              • W
                                Whaat
                                [attachment=0:2hx0fdop]<!-- ia0 -->spherical_zylindrical.jpg<!-- ia0 -->[/attachment:2hx0fdop]
                                Your sphere might have reversed faces. I have seen this type of behavior before in the case of reveresed faces.
                                • plot-parisP
                                  plot-paris
                                  doesn't work with right face orientation either - I just checked to be sure... still the same messy texture.
                                  indigo would have ignored a reversed face anyway.
                                  but this is the first beta release, and it works perfect in SU! ๐Ÿ˜
                                  it is such a wonderful thing (just imagine how easy it is for fred to texture his sculptures now ๐Ÿ˜„ )
                                    dtrarch
                                    Stinkie is right.
                                    Lightning BugSplat!!! on non-textured surfaces.
                                    Otherwise works like a charm.
                                    Thanks for such a fun tool too.
                                    dtr
                                    • PixeroP
                                      Pixero
                                      Whaat, here is a link that might be of interest to you.
                                      http://ozviz.wasp.uwa.edu.au/~pbourke/texture_colour/spheremap/
                                        Jon
                                        I have to agree with plot-paris. It doesn't kep it's genuine texture in Kerkythea, either.
                                        But other than that, it works like a charm! Thank you!!! ๐Ÿ˜
                                        Jon
                                        KT Team member
                                        • W
                                          Whaat
                                          I find this very hard to believe! ๐Ÿ˜ฎ Please post your SKP file for me to test. Thanks!
                                            Jon
                                            Well, it fails with every model I've exported so far, but here's the most recent one. ๐Ÿ˜‰
                                            With some models, there seems to be the change of the actual texture when exporting.
                                            The other spheres surrounding the model are the atmosphere and cloud layer. ๐Ÿ˜‰
                                            Thanks again, Whaat! ๐Ÿ˜„
                                            earth.skp
                                            Jon
                                            KT Team member
                                            • 2 / 9
