    [Plugin] Door-Lintel Update + Window-Sill
    73 Posts 32 Posters 52.0k Views 32 Watching
    • EdsonE Offline
      Edson
      Edson check out ilay7k's post three up from yours. There is a link to a skp explaining.
      thanks, dylan. but that is not what i asked for.
      http://www.mahfuz.arq.br
        @edson said:
        i managed to install it but i do not know how to make it work.
        what is the 1st thing to do? set the door height? and then what? could you take me through the steps?
        Edson, I set the door height, selected the side of the door opening and then chose the other option in the plugin's menu.
        • EdsonE Offline
          Edson
          this is what happens when i run the script. notice there is no lintel. the result was just the disapearance of a back face and the shortening of the wall on the side where i selected a face to start the lintel from.
          small room with a door before running the script
          small room with a door AFTER running the script:
            Edson, is that your back face color?. Try this. Before pulling the walls up, delete the floor so the walls pull up right side out.
            • EdsonE Offline
              Edson
              thanks, dave. i ran some tests and the problem seems to have been the fact that the faces were reversed for the script to work. leaving the floor on was no problem.
                Edson, I knew that reversing the faces would fix it but if you had deleted the floor, Push/Pull wouldn't have resulted in the exposed back faces. Glad you got it to work in any case.
                • E Offline
                  enhorning
                  I installed, it showed up in the plugins menu, all seemed well. I draw a simple floor plan and when I select a face and run door by embasure it crashes SU instantly.
                  Any ideas?
                  marianne
                  • I Offline
                    ilay7k
                    Hello Marianne!
                    Try to catch messages from ruby-console(open console, do some actions with script and look at console, what happens...)
                    Will be nice to have bugsplat-log with ruby?
                    • Didier BurD Offline
                      Didier Bur
                      Of course, because the script uses the normal vector of the selected face to decide in which direction it has to pushpull the lintel.
                      DB
                      • E Offline
                        enhorning
                        I opened the console and ran the same little model to test lintel and nothing appeared in the console and no Bugsplat appeared. I did get a windows rash report. other than that i had about a 5 second wait before the first crash and then instant on subsequent crashes.
                        anything else I can do to help diagnose?
                        marianne
                        error report.txt
                        • F Offline
                          farukahmet
                          Didier,
                          Another excellent plugin. What a time saver!
                          But i have a problem with the window option (door option works flawlessly). It simply does nothing. I tried various "window height" and "sill height" combinations but no success. Do you have any idea what might be the problem?
                          • I Offline
                            ilay7k
                            Hello Faruk, select face(red face, image-description from 1st message of topic) try by right click(context menu) and select "window by..."(for 1st if you define all options of window and sill in plug-ins menu)...
                            Didier thank you for update!
                            I got such error when i tried from "plug-ins"-menu
                            Error; #<NoMethodError; undefined method `wbe_by_embrasure' for #<Object;0x42c92d0>>
                            (eval);220
                            (eval);220;in `call'
                            from context - normal
                            • F Offline
                              farukahmet
                              Thanks Ilya, it worked like a charm. I wonder why it doesn't work from the Plugins menu though.
                              • I Offline
                                ilay7k
                                i think, Didier will fix it...
                                we are humans...not machines
                                  Didier Bur
                                  Done.
                                  Was a typo, "w" instead of "d" in Plugins menu option 🎉
                                  (Note to french users: pas de probleme avec la version française)
                                  DB
                                  • PixeroP Offline
                                    Pixero
                                    Thanks for this great script! 👍
                                    • I Offline
                                      ilay7k
                                      Didier thanks for fix ☀
                                      it alive...works
                                      Pixero
                                      +7 ...sketchup...+7000
                                      it closes to parametric... 😲
                                      multiple selections of sides will be wonderful for it and connection with multiwall tool 😒 💭
                                      • erikBE Offline
                                        erikB
                                        Thanks for the update. This is a very usefull tool !!!
                                        erikB
                                        • pbacotP Offline
                                          It's been a while since I used this tool and it looks like interest in it has dropped off judging by the activity here. What other methods have people been using? I have been working with solid groups more and components, but sometime I just want to use something like this. There are some drawbacks to the tool at present:
                                          I cannot make a shortcut key command operate the tool. Nothing happens. So it is slow if you are doing a lot of doors, pulling down the menus each time. Also I have found if you preselect the embrasures, you can work them all one by one by selecting the tool over and over. I wonder if the tool could be set to work on multiple instances in one command.
                                          The tool would also be enhanced by having an active phase, with a toolbar. Then just clicking on an embrasure would perform the preset lintel. That would be the quickest use.
                                          I sometimes get an error message that the maximum door height is exceeded. It has no relationship to the drawing that I can see. Then I cannot use the tool until I reduce the door height then set it back up again where I want it. I thought I might look at adjusting the script, but it's encoded.
                                          Windows are set by sill and window size. It seems to me that convention would make it appropriate to set window head height and window size instead. Then adjusting for a different window would usually take only one input as window heads are usually constant in a building.
                                          This tool works well and cleanly. It's helpful if you have imported CAD wall lines that already have openings. Probably has other uses in joining shapes. Thanks, Peter
                                            SUFractal
                                            Just discovered this plugin this morning ... very handy when importing a plan drawing in CAD as you suggested. I agree with your comments about some minor tweaking.
                                            • 2 / 4
