    [Plugin] Door-Lintel Update + Window-Sill
    73 Posts 32 Posters 52.0k Views 32 Watching
    • majidM Offline
      majid
      it doesn't work for me too 😞 .nothing happens! i saw the swf , but i don't know where i am rong!!
      • I Offline
        ilay7k
        "door.skp" example with description was included in package(From: http://www.crai.archi.fr/RubyLibraryDepot/Ruby/EM/door_lintel.zip)
        • majidM Offline
          majid
          thanx .... it was so useful 👍 (none of the smilies shows my respect truely )
            dylan
            Excellent Didier, thankyou for this 👍
            http://dmdarchitecture.co.uk/
            • EdsonE Offline
              Edson
              i managed to install it but i do not know how to make it work.
              what is the 1st thing to do? set the door height? and then what? could you take me through the steps?
              http://www.mahfuz.arq.br
                dylan
                Edson check out ilay7k's post three up from yours. There is a link to a skp explaining.
                • EdsonE Offline
                  Edson
                  thanks, dylan. but that is not what i asked for.
                    Edson, I set the door height, selected the side of the door opening and then chose the other option in the plugin's menu.
                    • EdsonE Offline
                      Edson
                      this is what happens when i run the script. notice there is no lintel. the result was just the disapearance of a back face and the shortening of the wall on the side where i selected a face to start the lintel from.
                      small room with a door before running the script
                      small room with a door AFTER running the script:
                        Edson, is that your back face color?. Try this. Before pulling the walls up, delete the floor so the walls pull up right side out.
                        • EdsonE Offline
                          Edson
                          thanks, dave. i ran some tests and the problem seems to have been the fact that the faces were reversed for the script to work. leaving the floor on was no problem.
                            Edson, I knew that reversing the faces would fix it but if you had deleted the floor, Push/Pull wouldn't have resulted in the exposed back faces. Glad you got it to work in any case.
                            • E Offline
                              enhorning
                              I installed, it showed up in the plugins menu, all seemed well. I draw a simple floor plan and when I select a face and run door by embasure it crashes SU instantly.
                              Any ideas?
                              marianne
                              • I Offline
                                ilay7k
                                Hello Marianne!
                                Try to catch messages from ruby-console(open console, do some actions with script and look at console, what happens...)
                                Will be nice to have bugsplat-log with ruby?
                                • Didier BurD Offline
                                  Didier Bur
                                  Of course, because the script uses the normal vector of the selected face to decide in which direction it has to pushpull the lintel.
                                  DB
                                  • E Offline
                                    enhorning
                                    I opened the console and ran the same little model to test lintel and nothing appeared in the console and no Bugsplat appeared. I did get a windows rash report. other than that i had about a 5 second wait before the first crash and then instant on subsequent crashes.
                                    anything else I can do to help diagnose?
                                    marianne
                                    error report.txt
                                    • F Offline
                                      farukahmet
                                      Didier,
                                      Another excellent plugin. What a time saver!
                                      But i have a problem with the window option (door option works flawlessly). It simply does nothing. I tried various "window height" and "sill height" combinations but no success. Do you have any idea what might be the problem?
                                      • I Offline
                                        ilay7k
                                        Hello Faruk, select face(red face, image-description from 1st message of topic) try by right click(context menu) and select "window by..."(for 1st if you define all options of window and sill in plug-ins menu)...
                                        Didier thank you for update!
                                        I got such error when i tried from "plug-ins"-menu
                                        Error; #<NoMethodError; undefined method `wbe_by_embrasure' for #<Object;0x42c92d0>>
                                        (eval);220
                                        (eval);220;in `call'
                                        from context - normal
                                        • F Offline
                                          farukahmet
                                          Thanks Ilya, it worked like a charm. I wonder why it doesn't work from the Plugins menu though.
                                          • I Offline
                                            ilay7k
                                            i think, Didier will fix it...
                                            we are humans...not machines
                                            • 1 / 4
