    [Plugin] Door-Lintel Update + Window-Sill
    73 Posts 32 Posters 47.7k Views 32 Watching
    • I Offline
      ilay7k
      "door.skp" example with description was included in package(From: http://www.crai.archi.fr/RubyLibraryDepot/Ruby/EM/door_lintel.zip)
      • majidM Offline
        majid
        thanx .... it was so useful 👍 (none of the smilies shows my respect truely )
          dylan
          Excellent Didier, thankyou for this 👍
          http://dmdarchitecture.co.uk/
          • EdsonE Offline
            Edson
            i managed to install it but i do not know how to make it work.
            what is the 1st thing to do? set the door height? and then what? could you take me through the steps?
            http://www.mahfuz.arq.br
              dylan
              Edson check out ilay7k's post three up from yours. There is a link to a skp explaining.
              • EdsonE Offline
                Edson
                thanks, dylan. but that is not what i asked for.
                  Edson, I set the door height, selected the side of the door opening and then chose the other option in the plugin's menu.
                  • EdsonE Offline
                    Edson
                    this is what happens when i run the script. notice there is no lintel. the result was just the disapearance of a back face and the shortening of the wall on the side where i selected a face to start the lintel from.
                    small room with a door before running the script
                    small room with a door AFTER running the script:
                      Edson, is that your back face color?. Try this. Before pulling the walls up, delete the floor so the walls pull up right side out.
                      • EdsonE Offline
                        Edson
                        thanks, dave. i ran some tests and the problem seems to have been the fact that the faces were reversed for the script to work. leaving the floor on was no problem.
                          Edson, I knew that reversing the faces would fix it but if you had deleted the floor, Push/Pull wouldn't have resulted in the exposed back faces. Glad you got it to work in any case.
                          • E Offline
                            enhorning
                            I installed, it showed up in the plugins menu, all seemed well. I draw a simple floor plan and when I select a face and run door by embasure it crashes SU instantly.
                            Any ideas?
                            marianne
                            • I Offline
                              ilay7k
                              Hello Marianne!
                              Try to catch messages from ruby-console(open console, do some actions with script and look at console, what happens...)
                              Will be nice to have bugsplat-log with ruby?
                              • Didier BurD Offline
                                Didier Bur
                                Of course, because the script uses the normal vector of the selected face to decide in which direction it has to pushpull the lintel.
                                DB
                                • E Offline
                                  enhorning
                                  I opened the console and ran the same little model to test lintel and nothing appeared in the console and no Bugsplat appeared. I did get a windows rash report. other than that i had about a 5 second wait before the first crash and then instant on subsequent crashes.
                                  anything else I can do to help diagnose?
                                  marianne
                                  error report.txt
                                  • F Offline
                                    farukahmet
                                    Didier,
                                    Another excellent plugin. What a time saver!
                                    But i have a problem with the window option (door option works flawlessly). It simply does nothing. I tried various "window height" and "sill height" combinations but no success. Do you have any idea what might be the problem?
                                    • I Offline
                                      ilay7k
                                      Hello Faruk, select face(red face, image-description from 1st message of topic) try by right click(context menu) and select "window by..."(for 1st if you define all options of window and sill in plug-ins menu)...
                                      Didier thank you for update!
                                      I got such error when i tried from "plug-ins"-menu
                                      Error; #<NoMethodError; undefined method `wbe_by_embrasure' for #<Object;0x42c92d0>>
                                      (eval);220
                                      (eval);220;in `call'
                                      from context - normal
                                      • F Offline
                                        farukahmet
                                        Thanks Ilya, it worked like a charm. I wonder why it doesn't work from the Plugins menu though.
                                        • I Offline
                                          ilay7k
                                          i think, Didier will fix it...
                                          we are humans...not machines
                                            Didier Bur
                                            Done.
                                            Was a typo, "w" instead of "d" in Plugins menu option 🎉
                                            (Note to french users: pas de probleme avec la version française)
                                            DB
                                            • 1 / 4
