    [Plugin] Door-Lintel Update + Window-Sill
    73 Posts 32 Posters 55.7k Views 32 Watching
    • david_hD
      david_h
      I just gave this one a test drive. Works Great. huge Time saver.
      Merci, Mon ami.
      D
        @jclements said:
        It does nothing for me. I input a door height of 6', click OK, and that is it. The script ends.[attachment=0:3m6z38nq]<!-- ia0 -->door_lentel error.jpg<!-- ia0 -->[/attachment:3m6z38nq]. The same thing happens whether the walls are preselected or not.
        What happens if you enter 72 for the height?
        • majidM
          majid
          it doesn't work for me too 😞 .nothing happens! i saw the swf , but i don't know where i am rong!!
          • I
            ilay7k
            "door.skp" example with description was included in package(From: http://www.crai.archi.fr/RubyLibraryDepot/Ruby/EM/door_lintel.zip)
            • majidM
              majid
              thanx .... it was so useful 👍 (none of the smilies shows my respect truely )
                dylan
                Excellent Didier, thankyou for this 👍
                http://dmdarchitecture.co.uk/
                • EdsonE
                  Edson
                  i managed to install it but i do not know how to make it work.
                  what is the 1st thing to do? set the door height? and then what? could you take me through the steps?
                  http://www.mahfuz.arq.br
                    dylan
                    Edson check out ilay7k's post three up from yours. There is a link to a skp explaining.
                    • EdsonE
                      Edson
                      thanks, dylan. but that is not what i asked for.
                        Edson, I set the door height, selected the side of the door opening and then chose the other option in the plugin's menu.
                        • EdsonE
                          Edson
                          this is what happens when i run the script. notice there is no lintel. the result was just the disapearance of a back face and the shortening of the wall on the side where i selected a face to start the lintel from.
                          small room with a door before running the script
                          small room with a door AFTER running the script:
                            Edson, is that your back face color?. Try this. Before pulling the walls up, delete the floor so the walls pull up right side out.
                            • EdsonE
                              Edson
                              thanks, dave. i ran some tests and the problem seems to have been the fact that the faces were reversed for the script to work. leaving the floor on was no problem.
                                Edson, I knew that reversing the faces would fix it but if you had deleted the floor, Push/Pull wouldn't have resulted in the exposed back faces. Glad you got it to work in any case.
                                • E
                                  enhorning
                                  I installed, it showed up in the plugins menu, all seemed well. I draw a simple floor plan and when I select a face and run door by embasure it crashes SU instantly.
                                  Any ideas?
                                  marianne
                                  • I
                                    ilay7k
                                    Hello Marianne!
                                    Try to catch messages from ruby-console(open console, do some actions with script and look at console, what happens...)
                                    Will be nice to have bugsplat-log with ruby?
                                    • Didier BurD
                                      Didier Bur
                                      Of course, because the script uses the normal vector of the selected face to decide in which direction it has to pushpull the lintel.
                                      DB
                                      • E
                                        enhorning
                                        I opened the console and ran the same little model to test lintel and nothing appeared in the console and no Bugsplat appeared. I did get a windows rash report. other than that i had about a 5 second wait before the first crash and then instant on subsequent crashes.
                                        anything else I can do to help diagnose?
                                        marianne
                                        error report.txt
                                        • F
                                          farukahmet
                                          Didier,
                                          Another excellent plugin. What a time saver!
                                          But i have a problem with the window option (door option works flawlessly). It simply does nothing. I tried various "window height" and "sill height" combinations but no success. Do you have any idea what might be the problem?
                                          • I
                                            ilay7k
                                            Hello Faruk, select face(red face, image-description from 1st message of topic) try by right click(context menu) and select "window by..."(for 1st if you define all options of window and sill in plug-ins menu)...
                                            Didier thank you for update!
                                            I got such error when i tried from "plug-ins"-menu
                                            Error; #<NoMethodError; undefined method `wbe_by_embrasure' for #<Object;0x42c92d0>>
                                            (eval);220
                                            (eval);220;in `call'
                                            from context - normal
                                            • 1 / 4
